Fixing pixels in tv has destroyed picture fuzzy
Shows but fuzzy pictures
ChadL777
  • 69 Answers
SOURCE: FUZZY (SNOWY) PICTURE
Well, I can tell you it shouldnt have anything to do with your not having an HD box. The TV does not require a HD signal to give you a quality picture. The HD box only gives you the enhanced HD signal, but should work as any regular TV without it. How do you have it connected?
Posted on Dec 24, 2007
Highdefjeff
  • 124 Answers
SOURCE: Sharp Aquos LC-65D64U Picture Quality
You need to change your TV's settings and enhancements. Directly from the store and out of the box, the settings are adjusted for easiest sell in the store. That means that:
Your contrast is cranked to 100. Move this down to 50 to 60.
Your brightness may also be cranked up high. Lower it to a level nearer the middle range but not so dark as to lose detail in the shadows.
Your TV is set on "Dynamic" or "Vivid" mode. Pick "natural" or "normal" or standard.
Your sharpness is at least on, if not cranked up. Turn sharpness down or off, and the same with "Edge Enhancement" and "VSM", all to off.
Lastly, I bet you upgraded size and you are now sitting too close to the TV. Roughly, if you are sitting closer than 130 inches (about 11 foot) you might do some rearranging or save some money and get a smaller TV.
Posted on Apr 08, 2008
Agent Dort
  • 216 Answers
SOURCE: HDTV has fuzzy picture
Greetings blueberrie,
Many times the cables that you are using can contribute to picture quality. You will want to utilize the best connection possible, in most cases HDMI or component cables. Also, you may want to invest in a line filter, sometimes known as a surge protector. Many of these items are able to control the inconsistencies in power your unit receives, giving you clean power, which will influence picture quality.
I hope this helps!
Dorothy
Go Ahead. Use Us.
Posted on Jun 23, 2008
  • 105 Answers
SOURCE: Fuzzy background on tv picture
This is probably a combination of 2 things. In both causes 1 and 2 below, I would suggest checking the TV with a BluRay Player with BluRay disc connected using an HDMI Cable. If you complain about this, then the TV is probably not that great. Expect a $200 jump to a better model at the least (but this depends on what you have now). Honestly, this is fairly normal and wont change much with the next TV.
CAUSE 1: Motion BLUR
Motion blur occurs when fast moving objects are displayed on LCD TVs. Basically, it takes time for the LED lights that make up the picture to turn ON and OFF, when and object shown on the TV is moving faster than the LCD TV can turn these lights ON and OFF, you see the trail left behind as the lights dim to OFF. This look like blur because you see the current image and the trail of the old images. 120HZ and 240HZ LCD TV are supposed to improve this but honestly, they are at times 300+ dollars more and not really worth it. Very little difference except in some few cases.
CAUSE 2: Digital TV
Digital signals are hit or miss. Good or BAD. If you are watching Cable, Satelite or Antenna; it is likely you are seeing some BLOCK NOISE. This block noise is caused by missing information or Noise in the video signal. This will cause the picture to Pixilate (you see blocks and things start looking blurry too). This happens with poor signals. This also happens with the HD channels when they have more information than bandwidth (more data than that have space to send it...image shoving an elephant into a VolksWagon Beetle)
Posted on May 27, 2009
kashanahmed4
  • 53 Answers
SOURCE: The picture is very fuzzy (pixelated) when you first turn power o
this problem occurs usually in the power supply change or check the power supply borad
Posted on Dec 18, 2009
Fuzzy picture
Sounds like an AGC [Automatic Gain Control] problem with its video IF stage circuit. Contact any service technician, or service center. This is not a user repairable fault.
Gopakumar Gopalan Google
Feb 09, 2014 | Sony FD Trinitron WEGA KV-27FS100 27" TV
TV showing color pixels but no picture and no sound
Well at least you didn't pay for the TV. Your panel is defective. Cheaper to buy a TV than to fix.
Mar 20, 2013 | Televison & Video
Dec 18, 2009 | Samsung LN-S3241D 32 in.LCD HDTV
TV shows on half screen. other half fuzzy
You have some cold solder joints on the PC board. Flux and re-flow all of the electrolytic capacitors connections..
Aug 29, 2009 | Televison & Video
New vizio 26'' hdtv seems sharp from a distance, but pixalated and
it is important to understand the difference in digital cable and high def. high definision is on a fiber optic display alwing milions of pixels per square inch on your tv. the resolution effects your fuzzy picture you are recieving . the only real way to fix that fuzzy dull picture is to get a HD box from your cable provider and an HDMI cable to conect it to your HD TV. this is the only connection you will need for picture and top line sound. In the end the fee is usually $9.95 or less a month and it is well worth the difference in quality of TV viewing.
Mar 16, 2009 | Vizio VA26L 26 in. LCD HDTV
Picture has blue,green,and red phantom lines on the screen
Sounds like a convergence problem. Are you interested in fixing this yourself? If so you will need to know how to solder well and use a meter. I can assist you as much as you need through the process. If you post a picture of what the screen looks like we can know for sure what you have going on. If you call a repairman to fix it he will charge somewhere between $300-$500 to do the repair. Let me know if you need more help!
TIm Nolan
Sep 12, 2008 | Mitsubishi WS-65869 65" Rear Projection...
Fuzzy picture
You need to test it using a DVD player or Blueray player.
If you still get the problem, call that tv service company back and tell them the problem is with the TV.
Get them to test it while you're watching so you can point out the fault to them.
If it works great with a DVD player, then the fault is likely with your Sky box. Here you would really need a second portable TV to test your sky box with. This would confirm the fault is not in the TV.
May 06, 2008 | Televison & Video
Dec 24, 2007 | Memorex MT1701 17 in. HD-Ready LCD...
Fuzzy picture with DVI input from NVIDIA PC Card
I have the same TV and I found that increasing the DPI percentage (Dots Per Inch) you could reduce the fuzzy stuff, but in its still no where close to being the same quality as VGA. Hope that helps.
Nov 17, 2007 | Philips 23PF5320 23 in. HD-Ready LCD...
Plasma TV
If you mean the picture froze or formed fuzzy pixelated picture and crackling, this will be due to a poor aerial signal to the tv, but if you mean the screen rolls with pink/white patchwork type squares and shows the picture in the background, all be it fuzzy, then that's the same fault as I am getting and have had to report the fault to LG as I am on my second TV. If it is the problem mentioned in the first sentence, it is happening to our friends in OS and they have been told by specialist aerial fitters, the signal is too weak for the tv.
Mar 16, 2007 | LG 50PX4DR 50 in. Plasma TV
Televison & Video Logo
Top Televison & Video Experts
