Question about Westinghouse 24 in. MDP531 RF Free-standing Dishwasher
Hi I have a westinghouse 904. It stopped working. I found that it wasn't heating the water. The elemet looked fine so we replaced the thermostat The one that has the safety switch and now it goes to wash then it works for 5 seconds then stops. I have tried to use all settings including eco but stops at the same place everytime. It then flashes on normal.
  • 52 Answers
Elements often have no visible sign when they go bad ....they need to be checked with an ohm meter ....check and replace if circuit is open
Posted on Jul 25, 2009
I've been working on a 1997 Suburban 1500, It
After you replaced the thermostat did you run the engine with the radiator cap of for 20-30 minutes? If you did not then chances are you have an air bubble in your cooling system. If you remove your radiator cap and run your engine for 20-30 minutes that should solve your problem. Be sure you have extra water or coolant on hand when you do this because you may lose some during this process. If you want you can look in the tips section of this site. I have a step by step instructions as how to do this on there. I hope this helps you out.
Aug 31, 2011 | 1997 GMC Suburban
Hi, I've recently found that my westinghouse
if the back wall of the freezer is iced up the problem is most likely the defrost thermostat.
May 06, 2011 | Westinghouse Refrigerators
1999 chevy cavalier. wasn,t getting heat to inside. put in new thermostat. heated up fine for a couple of miles, then cool air. shut off when got back home. anitfreeze was bubbling back out of reservoir....
make sure you get ALL the air out run it without cap until you see water circulate turn heater to hot NO FAN ABOUT 5 MIN close cap ,see if that works
Nov 29, 2010 | 1999 Chevrolet Cavalier
Hi, I recently got my 2005 Audi A4 2.0 TDI serviced by an AUDI garage. They replaced the timing belt and water pump as well. After I left the garage i realised my heating wasnt working correctly....
i would get a water pump from the dealer and install it, In some cases i found that after market water pumps don't have the same clearance between the pump housing and the propeller.this causes less water flow.
Nov 20, 2010 | Audi A4 Cars & Trucks
Stops mid cycle often
Hi there, did you ever find out what was wrong with your dishwasher? I have a Westinghouse 904 doing the same thing but when we moved into this house the manual was long lost. Any thoughts would be greatly appreciated.
My email address is shaneane@clear.net.nz
Jun 02, 2009 | Westinghouse Dishwashers
Dishwasher not emptying
either the pump is not working or the discharge hose is clogged, if you have an air gap on the sink take the hose off and hold it down see if the water comes out by tself if so the pump is bad if not the drain is colgged take out the bottom tray you will need a 1/4 inch nut driver take the plastic screen cover plate off clear it of debris, there is a sharp metal blade in there so be careful, after cleaning it out turn on to rinse and see if it drains if not you will need to either replace the dishwasher or the pump, dollar for dollar new dishwasher time
May 30, 2009 | Westinghouse 24 in. MDB421 RF Built-in...
No solution as yet, will most likely replace the dishwasher.
May 31, 2008 | Westinghouse 24 in. MDB421 RF Built-in...
How to replce westinghouse 904 lower inner door seal
i don't think so if i remember its fairly easy open the door and take out the two screws at the bottom of the inner panel then slide the outer panel down to unhook it then take it off and you will be able to see the gasket
Feb 17, 2008 | Dishwashers
Dishwashers Logo
622 people viewed this question
Top Westinghouse Dishwashers Experts
Denis FixYa...
Denis FixYa...
Are you a Westinghouse Dishwasher Expert? Answer questions, earn points and help others
