Question about The Office Equipment & Supplies
Can I get the past question and answer paper for mnur1e 2015/2016
Hi I need to find June past exam papers for grade 10. Please supply with info
You are cheating yourself by not studying and working to do your best. Find the answers yourself and you will be rewarded in life.
Jun 02, 2017 | Computers & Internet
Paper jam I've cleaned sprayed,etc must be something I can't see w/o going deeper. How do I remove cover to get to paper rollers in MX340
Removing the covers is not the answer. Most jams on rear feed printers/faxes are due to some object falling in the sheet feeder. When you pull the paper back out (Very slowly) of the sheet feeder after it has jammed , you will see a nick in the paper. This is because the paper is hitting something and cant get past it. put the paper back in the sheet feeder and the nick will indicate where the object is. Find a large paper clip and unwind it and bend the top of it to 90 degrees. use this to hook the object out and then tip the printer upside down and watch it fall out. Good luck
Dec 11, 2016 | Canon PIXMA MX340 Wireless Office...
Need help to recover with my accounting and math subject as I am very week in these subject.
hi, go to your library and see if they have any books there which may help you. "hsc essentials business studies" by clive a lincoln & michael lembach oxford university press, melbourne, 1994 pp48-57 could be helpful.
if you are able to find past past examination questions you should try to answer these using information in your text books and other reference books.
i was once in a similar situation, having missed very many classes and having done no reading at all in a particular subject for the dip a.i.i. i got hold of the past five years examination questions for the course. the weekend before the final examination i assumed that i was the person preparing the examination paper for the current year's examination. then looking at the course syllabus and the questions asked in the previous five years i prepared questions for the current year. i then studied and tried to answer these questions that i had prepared during the entire weekend. luckily the questions i had created and learned to answer covered the areas that were questioned in that final examination. i gained a high distinction in that paper.
Jan 21, 2015 | Computers & Internet
Epson xp 305 what is the heaviest card it will print on ? I have tried with quite thick card changed the settings to premium glossy photo paper (as there is no card option ) and it just wont pull through...
The driver? Are you serious? I have the same issue. The problem is the XP-305 and the DX8400 (I have had both) will not MECHANICALLY take 260gsm photo paper and struggles with virtually any card. I'm sorry but copying and pasting a standard answer to up your Post level is annoying. There is NOTHING to suggest the OP is having any issues with anything else other than the issues outlined. It seems to be unable to "grab" the paper. It can be tricky with 240gsm but 260gsm seems impossible.
Apr 20, 2014 | Office Equipment & Supplies
Brother MFC-9840CDW Tray 1 paper jam
The problem is the spring that is located below the lever right in front of the clear plastic roller has lost its spring. If you remove the spring and stretch it a bit it will resolve the problem.
Jun 12, 2012 | Brother MFC-9840CDW Laser Printer
I have a watercolour painting that has ''cockled'' can I paste this onto Board, or Iron ?
I went directly to the Paper Makers, and expect their answer soon . I do not want to incur expense with yourselves, so cancel my query Thanks D.G.
Sep 17, 2009 | Computers & Internet
Jammed paper in printer
There is usually a back door that is supposed to be used to properly clear a paper jam, but it depends on the make and model of printer you have. You should be able to go to the online support site for the manufacturer and search support under paper jam for your model and they'll have detailed instructions.
Or write back with that info and we'll get a link for you...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
May 25, 2009 | Office Equipment & Supplies
Paper will not feed
There is a gear that normally breaks, or cracks and it does not finish feeding past the print head, no parts are available for it unless you find one for sale with a different problem, you are stuck
Jan 13, 2009 | Lexmark X83 All-In-One InkJet Printer
21 people viewed this question
Top The Office Equipment & Supplies Experts
thetraveler
Level 1 Expert
Folusho Adeyanju
Folusho Adeyanju
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
