Question about HP Office Equipment & Supplies
How to bypass the HP Lp - HP Office Equipment & Supplies
Blue star ac working after hp lp cf what is complete display blinking
what is a blue start?
what is AC (alternating current)?
what is LP (line printer)?
what is CF (Cold Fusion)?
add some English nouns please.?
tell the service tag lines1, 3 and 5. and win a trip to Mexico.
as seen here.
http://partsurfer.hp.com/search.aspx
Aug 14, 2017 | HP Computers & Internet
How do u know weather to put it on HP or LP an where to set them at
Keep 1 post per subject open please! It is confusing to follow! The HP is High pass and LP is Low pass, HP is for tweeters and LP is for Sub woofers!
Nov 18, 2014 | Kitchen Ranges
LP HP CF Blue star
11TR Blue star Ductebal AC LP HP CF porbalem
Jun 12, 2012 | Heating & Cooling
Safety valve releases on stroke of motor when it gets around 145 P.S.I. replaced safety valve and still the same. please help
IS this a 175 psi unit. What was the safety valve psi that was replaced. I recommend removing the heads and checking the valves. Suspect you will find one of them bad.If safety is past the hp head remove and check hp valves first. If safety is after lp head check it first. I have seen and lp valve break and pieces carry over to the hp side. So if lp valve bad you may want to inspect the hp side also. Good luck!
Jul 21, 2011 | Campbell Hausfeld Air Tools & Compressors
LP,HP AND CF APPEARS ON HANDSET AFTER RUNNING THE UNIT IN BLUE STAR DUCTABLE UNIT. PLS SOLVE IT
after starting of ac units it shows lp hp but once reset than the lp hp thing goes away what is the reason for showing lp, hp in the morning when started first time in the morning
Apr 28, 2011 | Heating & Cooling
Lp switch open, can it be bypassed?
there is a reason why it is open either because it has failed or because inducer motor is failing as long you know its the switch you can bypass it. But replace asap as this shuts the furnace down if the inducer fails
Dec 17, 2010 | Heating & Cooling
For my mode should it be hp or lp
hp they provide lp, lp is tust an lp.... so your mode should be lp
Feb 23, 2010 | Alpine MRD-M1000 Car Audio Amplifier
FISHER PAYKEL DISH DRAWER U3 FAULT CODE
LP is a setting for Low pressure. To reset your pressure to HP, hold the Programme and Eco touch switches simultaneously for 5 seconds. Once the setup mode is entered a beep is emitted and
the LCD is red with ‘HP’ or 'LP' displayed. Push the Start/Pause button to alternate between HP and LP. and push the power button to exit.
Sep 14, 2008 | Fisher and Paykel 24 in. DD-602 Built-in...
My baby q is sick
Since 1995 all regulators (the part that attaches to the gas tank to regulate the flow of gas) have included a safety device that restricts the flow of gas in the event of a gas leak. This safety device can be inadvertently activated in two ways, putting the grill into what is commonly called “bypass”. The first way for the device to be activated is to leave one or more burner control knobs in the “ON” position when the LP cylinder valve is opened. The second is not to wait long enough to “start” the grill after opening the LP cylinder valve. The safety device in the regulator is activated each time that the LP cylinder valve is opened. The device resets itself when the gas pressure equalizes between the closed burner control valve and the regulator, through the hose. If a burner control knob is turned on before the gas pressure can equalize, the device will remain in “bypass”. The length of time necessary to wait to “start” the grill after turning on the LP cylinder valve is dependent on the length of the hose and outside air temperature. It is always good practice to wait a few seconds after opening the LP cylinder valve before turning on the burner control knob to start the grill.
Keep in mind that the safety device reacts to a gas leak. If a grill is in bypass, the gas connections and hose should be tested for leaks with a soap and water solution.
If the grill is in bypass, after checking for gas leaks do the following to get the grill out of bypass:
To reset the gas safety device:
Open the barbecue lid.
1. Close the LP tank valve.
2. Turn your burner control knob to the OFF position.
3. Wait at least 5 minutes if the barbecue had been lit, then
4. Disconnect the hose from the LP tank.
5. Turn your burner control knob to the HIGH position.
6. Wait at least 2 minutes, and then turn the burner control knob to the OFF position.
7. Re-connect the hose to the LP tank.
Re-lighting the barbecue:
1. Open the barbecue lid.
2. SLOWLY open the LP tank valve all the way and wait 1 minute.
3. With the lid open, turn the burner control knob to the HIGH position.
4. Ignite the grill by pushing the crossover ignition button.
5. Close the barbecue lid.
6. The barbecue should reach 500 to 550 degrees in 10-15 minutes.
When you are done grilling:
1. Turn all burner control knobs to the OFF position
2. Turn off the LP tank valve last.
* Always follow the re-lighting instructions whenever you use the adapter hose and larger tank.
Feb 16, 2008 | Weber Q Grill
89 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
