Question about Refrigerators
Bluestar ductble ac showing HP Lp - Refrigerators
3 Suggested Answers
  • 45582 Answers
SOURCE: My bluestar split ac 3.ton showing on display light blinking..what is problem
could be a control board either in the inside unit or the outside unit
could be a simple start/run capacitor for the out side unit
best get a technician out to check it out so that you get the correct diagnosis and quote for repair.
Posted on Sep 16, 2015
Blue star ac working after hp lp cf what is complete display blinking
what is a blue start?
what is AC (alternating current)?
what is LP (line printer)?
what is CF (Cold Fusion)?
add some English nouns please.?
tell the service tag lines1, 3 and 5. and win a trip to Mexico.
as seen here.
http://partsurfer.hp.com/search.aspx
Aug 14, 2017 | HP Computers & Internet
Sep 16, 2015 | Heating & Cooling
Bluestar split ac indoor unit making abnormal noises. I have a 5 star 1 ton bluestar ac model 5HW12ZBI. It makes noise (kit -kit) when the ac trips off. The noise is minor during day time but it Ibecomes...
From your details i can observe the blower motor bearing worn out. or its side bushes in which there is small bearing that may be worn out. Replace it. Finally check for correct voltage too.
May 07, 2014 | Heating & Cooling
Bluestar rangetop clicks several times before igniting
Do other appliances in your home using LP gas work properly? If so, then this is probably an air/fuel mix problem on the burner(s). If this is a new rangetop there should be directions with the range and the LP conversion kit to instruct on proper adjustments. Be certain the correct LP orifice was installed for each burner (they likely have different BTU ratings for different sized burners) and the ignitor post is clean and spaced properly to burner. Then adjust the air mix to achieve a blue flame with just a tip of yellow. Delayed ignition usually results from the wrong air/gas mixture which doesn't ignite until too much fuel has accumulated. In many locations the company you purchase LP gas from will have someone who can check and adjust this. If the range was shipped from the factory as LP gas ready, then you can also contact your dealer and request assistance.
Feb 25, 2014 | BlueStar RGTNB364GHCSSLP 36" Pro-Style Gas...
LP HP CF Blue star
11TR Blue star Ductebal AC LP HP CF porbalem
Jun 12, 2012 | Heating & Cooling
LP,HP AND CF APPEARS ON HANDSET AFTER RUNNING THE UNIT IN BLUE STAR DUCTABLE UNIT. PLS SOLVE IT
after starting of ac units it shows lp hp but once reset than the lp hp thing goes away what is the reason for showing lp, hp in the morning when started first time in the morning
Apr 28, 2011 | Heating & Cooling
Norcold n1095 not working on AC...works fine on LP
Yes. LP is direct heat to the exchanger. The thermistor operates through the control to the electric heater.
Apr 22, 2009 | Dometic NDR 1292 Refrigerator
Refrigerators Logo
43 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
