I am no longer receiving Free Slot plays. - Audio Players & Recorders
I am unable to surround when I have XBOX and Blueray via 2xHDMI and 2xOptical, I am only able to get 1 device to work at a time, pleast help
This is normal. You cannot run 2 optical inputs at the same time. You can only use one or the other. For example . . if you are playing your xbox, you would use that corrosponding optical. When you are done and whant to watch your blue ray, you would have to change inputs to that corresponding optical.
May 10, 2012 | Yamaha RX-V365 5 Channels Receiver
I cannot hear anything unless its on speakerphone and the person on the other end can hear every thing
Your earpiece is bad and needs replacing. Though this might not be effectively replaced by you, you may have to take the phone to a lcal repairer to fix. But in the mean time, you can conveniently make and receive calls, without a third party totally eavesdropping with the aid of a hands - free device.
I hope that solves your problem?
Take care.
May 21, 2011 | Samsung Hue (SCH-r500) Cellular Phone
I need to connect to a Marantz SR-19 a record player How do i do it
On the back of the receiver there are connections, usually record player should be hooked up on Phono slot. If Phono is not available, trying using Aux or another slot that isn't being used. After hooking it up, remember the place you hooked it up, turn on the turntable, play a record, then hit the button on the receiver where the turntable is hooked up.
Sep 20, 2010 | Marantz SR-19 Receiver
Program Play of Title 32 Prohibited
NO. it will most likely be either a limitation of the player or a faulty/incompatible disc.
A very quick test is to play the disc in another slot and see if the problem moves with the Disc.
Mar 17, 2010 | Televison & Video
I have a hyperbeam laser disc jukebox,and it was on free play when i bought it years ago.it's no longer on freeplay and i dont remember how to do it.any help would be great
camino69 my juke box has a black switch on the upper right side by the coin receiver. it looks operates like a car door lock. If yours is in this approximate location try switching it to the oposite position.
Oct 27, 2009 | Audio Players & Recorders
Play gbc games on ds
you mean a proper shop brought gba game? just pop it into the longer slot on bottom of ds and off you go.
Apr 10, 2009 | Nintendo DS Console
Hooking up dvd, tape, karoke machine to denon reciever
What happens when you select options from the front of the reciever?....accordianman
Sep 07, 2007 | Denon AVR-2106 Receiver
23 people viewed this question
 Grubhead
Grubhead
