Question about Water Water Heaters
I am looking for a replacement water heater that is in the $500-$600 range. My current water heater is Lochinvar DVN-041. Any ideas?
  • Water Master
  • 2,413 Answers
You can replace with any brand and size to suite your need. But I believe they don't sell you and let you to install by yourself.
You have to buy it in and pay installation fee then they'll
bring in and install for you.
Good luck
Posted on Apr 25, 2017
5 Suggested Answers
  • 317 Answers
SOURCE: 2 month old Lochinvar Electric 30 gal heater hot
is it a new may go away after a while...its sulfer....sometimes when you drill well too deep you get sulpher water......
Posted on Nov 17, 2009
SOURCE: Rheem tankless water heater eco180-dvn has flash
Rheem wants customers to call trained service technician since error codes are start-place for troubleshooting, and problems can be combination of issues.
Risk of CO poisoning from improper vent, or clogged drain line causing damage to heat exchanger, and risk of homeowner working on complicated gas-burning appliances are reasons why Rheem instruction manuals recommend yearly maintenance by trained technician.
That maintenance would typically cover most common error code issues, and homeowner could gather tips and information from service tech.
Open following links for Rheem troubleshooting resources:
Posted on Jul 13, 2011
  • 92 Answers
SOURCE: My Lochinvar water heater will not shut off and
If you mean that it does not turn off the power, shut down the breaker. I guess that when you said "overflow" you were talking about the P and T valve blowing off.
You need to replace the themo stat right away, change upper and lower. You can buy a kit from any hardware box store that will have the uppper and lower in a kit.
You need to be very careful of this is that valve was not opening up to let off the pressure that tank can blow up and its a rocket I have seen 4 that have done that in my 40 plus years of doing this and each time. Well its bad.
Be safe be careful
Take a second to rate us so we know if we ase doing a good job fo you :)
Posted on Sep 11, 2011
  • 5245 Answers
SOURCE: where can i get parts for the richmond rmtg 53 dvn gas tankless hot water heater
Call Rheem:
Rheem is Richmond, Ruud, Paloma etc.
Posted on Dec 03, 2012
Why do they keep leaking
-havent had any leak, need a little more info on where it is leaking from though
Jan 27, 2016 | Lochinvar SIT119 113 Gallon Squire...
What should I do if my pilot light is out
There should be an electronic igniter with instructions on how to start it right on the heater.
Feb 24, 2015 | Lochinvar Shield Water Heater
I keep getting the word temp o/shoot when i turn on
Means that the boiler has over heated to quickly and the delta T is too high.
- no water in system
- proper water flow not present
- air in system
- bad sensors
Nov 24, 2013 | Lochinvar Water Heaters
Reem hot water 180 dvn water pressure drop
1) Copy following link for detailed troubleshoot walk-thru:
2) Today's new water heaters come with heat traps or heat trap inserts, so manufacturer can claim higher energy savings. But these things restrict water flow and clog, and reduce pressure, and whistle, and generally cause problems for some installations.
3) Add comment and say what you discover.
Dec 09, 2012 | Water Heaters
Please help me to download an instruction manual for a Rheem 24 continuous flow hot water unit. I cannot find mine. The Unit's serial number is-- DAUHO9A24. My immediate problem is that the hot water...
manual above.
I professionally recommend that you get a Plumber/Gasfitter, to check this over, as this isn't usual, and I wonder if there are not "Other" problems too... with anything that uses Gas one has a responsibility to the entire family to have it professionally checked over, in my humble view..
Mar 08, 2011 | Rheem Tankless Hot Water Heater...
2 month old Lochinvar Electric 30 gal heater hot water has rotten egg smell. Do not have water softener system. Well water with a lot of iron.
Nov 16, 2009 | Emerson InSinkErator W-152 Point-Of-Use...
Water Heaters Logo
49 people viewed this question
Top Water Heaters Experts
D. E. Hev
Are you a Water Heater Expert? Answer questions, earn points and help others
