Question about Crock Pots & Slow Cookers
My zojirushi cooker error h 04.How to fix it?.
Model is NP-PA10
I have an E01 error code on my West Bend slow cooker, how do I fix it?
Find out what the error code alludes to and rollup sleeves and .....................Could be something as simple as an open heating coil.
Feb 05, 2017 | West Bend Crock Pots & Slow Cookers
Instruction book for Rival 3100 crock pot slow cooker? where can I get it. Thanks. FRNAPG@aol.com
You can download it from this site:
http://kitchen.manualsonline.com/np/usermanuals/mfg/rival_1/3122_ch__crockpot
Hope that helps.
-S
Also, for security reasons, you may want to avoid putting your email address to a public question :)
Mar 18, 2011 | Rival 3122 CH 2Quart Slow Cooker
E01 code on west bend slow cooker - how can I fix
Your crockpot is giving you an error code EO1. Now you need to know how to get the code off of your crockpot so that you can use it.
Here is a tip that will tell you how to fix the EO1 error code.
West Bend Crockpot EO1 Error Codeheatman101
Jan 14, 2011 | West Bend 84496 6-Quart Slow Cooker
West Bend Slow Cooker error code: "E01". - holding "cook" button while plugging/unplugging did not fix the problem.
if you put something frozen or cold in it and let set for awhile without turning on then you must take it out let unit get room temp. then start it . E01 error means the unit is too cold to start.
Dec 22, 2010 | West Bend 84496 6-Quart Slow Cooker
Displays e4 wont work
Removed the 3 screws on the bottom. There is a relay near the circuit board. Kind of looks like an old morse code relay. Just tapped out "E 4" in morse code. Plugged it in and it works fine.
May 13, 2010 | Wolfgang Puck 5-Quart Electronic Pressure...
My Wolfgang Puck pressure cooker shows 'E4' in the display.
There doesn't seem to be any legit way of fixing this. I tinkered with the pressure sensors and valves, kicked the pressure cooker a few times, still the E4 error presented itself.
I was able to bypass the E4 error by completely bypassing the electronics and wiring the heater coil to get power whenever the pressure cooker is plugged in. It was a very simple job, anyone with any electrical experience can do this.
The only problem is that it is a safety concern as there is no way for the heater to turn off even if pressure is getting to be way too high. There may be a pressure relief valve in the lid but the heater coil won't shut off, so don't leave it unattended! But at least this way to you can still pressure cook.
Pics of process:
http://s909.photobucket.com/albums/ac295/danwat1234/fixing%20the%20pressure%20cooker/
May 10, 2009 | Wolfgang Puck 5-Quart Electronic Pressure...
E4 on the Woldgang Puck Electric Pressure Cooker
I fixed mine by elevating it 4 inches (E4) and dropping it on the counter. Something needed a little impact adjustment!
Mar 18, 2009 | Wolfgang Puck Electric Pressure Cooker...
Crock Pots & Slow Cookers Logo
97 people viewed this question
Top Crock Pots & Slow Cookers Experts
tsalagi152
charles
Irene Tulloch
Are you a Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
