Question about Garden
I am having a problem with the bagger on my Cub Cadet. It gets clogged all the time. I have tried everything, nothing works. HELP!!
    Master:
  • 923 Answers
Welcome to the wonderful world of baggers! Every one that I have ever seen clogs at some point in time.
Posted on Apr 25, 2017
What does the blinking h on the cub cadet hour display mean?
What it is and what it means is absolutely nothing. What it was suppose to mean is time for service when flashing but it has never worked and there is no way to reset. So that being said, if you are having it serviced every so often (25 to 50 hours) depending on the type usage just don't worry. It truly means nothing. Hope this helps you.
May 22, 2017 | Cub Cadet Garden
Will a model OEM 190-621 snowblower fit on a cub cadet LT 1024
Have you tried the cub cadet forum? If not, give it a click:
http://onlycubcadets.net/forum/forumdisplay.php?f=42
Nov 21, 2014 | Cub Cadet Riding Lawn Garden Tractor 25hp...
Trying to jump (with my car, I know it's not good) my cub cadet LTX 1046. Worked a few times. Now the parking brake light comes on when I try to turn it over and the motor won't even try to start. Nothing....
Find the switch attached to the parking brake mechanism. It's probably stuck. Jumping with a car will not hurt it if it uses a 12 volt battery. The car is not "too much power" for it. The mower will only take what it needs.
Nov 03, 2013 | Cub Cadet Garden
My cub cadet will start but it will not stay running. It acts as if it isn't getting enough gas. Help!
Several things to check....air filter being clogged, fuel filter clogged, fouled spark plug, engine could be flooding--clean air filter service choke with carb cleaner-let set, throttle not opening wide enough, plugged fuel cap,
Sep 28, 2013 | Cub Cadet Garden
My cub cadet model 12A-18M7010 will not start. It has an automatic choke. No primer. I've changed the gas, checked the plug, cleaned the carbuerator. What could it be?
Also check the air filter. Some times if the paper filter is wet or clogged it will choke out the machine by not allowing air in to the ignition chamber.
Apr 17, 2013 | Cub Cadet Garden
Zero turn cub cadet mower, deck keeps clogging with grass
do you have the right blades for bagging ?is the deck belt slipping?
Apr 22, 2012 | Briggs & Stratton Garden
Cub cadet lawn mower won't start and i have changed everything
What have you changed?? What model lawn mower is it? Is it a riding lawn mower or a push lawn mower? Does it turn over(engine turning with the starter), or does it do nothing when you turn the key over? I have serviced cub cadets for almost 20 years, from the very first model(1959) to present, and i own 13 different tractors myself. if anyone can help you, i should be able too. i just need more info about the unit and its problems. i look forward to helping you.... -Brian-
Oct 25, 2010 | Cub Cadet Street Sign- tractor lawn riding...
I have a Cub Cadet GT1554. I used it yesterday
Check the seat safety switch and the pto safety switch.
Aug 18, 2017 | Cub Cadet Street Sign- tractor lawn riding...
Cub cadet wont engage blades to cut grassmower iz rtz 50 zero turn tried to move the wires around and checked the 20 amp fuse no shorts. was cutting fine i just stopped to dump the bagger. any help would...
Try this:
With the engine turned OFF, unplug the wire connector at the PTO clutch, and use an alternate 12 volt DC power source and some alligator clips to manually power-up the clutch. If a firm, crispy "Click" is heard each time you "power-on / power-off" the clutch, then safety switches on the tractor are the most likely suspects.
If no firm, crispy "Click" is heard, your PTO clutch needs to be replaced.
On the right-hand side of THIS page, type in (without spaces) RZT50 and you will be given a list to choose your EXACT machine & part number.
Special Note:
If your part number description says to refer to "Service Advisory ...(blah blah)" then you will need to call a servicing dealership for the proper replacement part number.
Hope this helps.
Oct 04, 2009 | Oregon Scientific Oregon Gator Mulcher...
Cub cadet zforce
hello
check mower deck is not caked up with grass if it is it will not get enough air movementto force the grass up the chute
also try cutting in 2or3 passes so that you are not forcing too mush grass up the chute
hope this helps
Mar 13, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
37 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
