Question about GE Refrigerators
I have a ge fridergerator that has ice maker not working and freezing up still keeps ice box cold just doesn't make ice help
  • 161 Answers
SOURCE: GE model TFX22R ice maker problem
First clean out the condensor coils. If you have pets it should be done at least 3 times a year. The other possible problem is if the gasket in either the fridge or freezer is worn out or has a gap it will not cool properly. Check that the fan underneath the unit by the condensor coils is running when the compressor is . Some smaller refrigerators have only condensor coils on the back and no fan. These units should have room for air flow on top and sides not built in flush with cabinets. Buy a thermometer for both the fridge and freezer compartments. You run the risk of food poisoning if the fridge temp can not be kept below 40 degrees. Freezer temp should be able to keep at least 0 - 5 degrees. (Ice cream is a very good indication of proper temp. It is the first thing that melts. Ice maker is a close 2nd.)
If these things don't work call for repair. Don't risk losing all your food!
Posted on Jul 03, 2008
mikedurland
  • 481 Answers
SOURCE: ice maker tube freezing up
  • change the water valve on the back of the machine.
  •  the water valve is slowly leaking water up to the icemaker where it freezes and builds up ice, blocking the water flow.
Posted on Jul 05, 2008
Healeyman
  • 1198 Answers
SOURCE: Ice maker is freezing up
The solenoid valve can leak slightly to make your problem. To check it, undo the tube from the solenoid to the freezer with the solenoid unplugged, and the water pressure on. Any leakage is bad, replace it.
Posted on Jan 24, 2009
  • 219 Answers
SOURCE: Refrigerator not making alot of ice cubes
a bad valve will make them stick togather and sometimes hollow but the ge is well known for the back board being bad
Posted on Mar 19, 2009
  • 389 Answers
SOURCE: I have a liebherr freezer with ice maker. ice maker broken
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Posted on Apr 21, 2010
GE side by side refrigerator-freezer daily makes loud grrrrrnng noise. Sporadic. Comes from area just above ice maker. Makes no difference if I turn ice maker off. Any ideas what is causing this?
Many ice maker sporadically turn to keep ice from freezing together and becoming a solid block of ice. This would occur even if the ice maker is turned off in order to keep the ice already made from freezing. It is generally short and not that loud. I'm surprised you find it disturbing.
Jun 27, 2016 | GE Refrigerators
GE refrigerator PFCS1RKZSS no ice
check for ice build up in the lines to see if that's blocking the air. Make sure your water and your solenoid are working.
Dec 11, 2015 | GE Refrigerators
HAVE GE PSS26MSRSS SIDE BY SIDE THAT WILL NOT FREEZE COLD ENOUGH OR MAKE ICE
Hi , you probably need a repairman to check the freon level and test the thermostat
Jun 19, 2015 | GE Refrigerators
GE ice maker
If the freezer is cold enough to freeze food hard, look for a problem in the water line, water inlet solenoid valve, or possible ice build up on the ice maker itself that does not the allow the ice maker to complete it eject cycle and start a new ice making cycle.
Jul 14, 2014 | GE (PSS26MSRSS) Side by Side Refrigerator
My Frigidaire refrigerator works find; Freezer stays cold but doesn't freeze food or ice
Its defrost assembly parts issue or the compressor is getting waek indication.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 23, 2012 | Refrigerators
Ge refrigerator is not cold enough and ice is not working
What is the model number?
The ice maker will only run if the freezer is at the correct temperature.
Do you see any ice buildup on the back wall of the freezer or behind it?
Nov 27, 2012 | Refrigerators
Freezing food and leaking water
faulty water valve will cause the issues with the ice maker fill tube , possible faulty air damper will cause the fridge to get too cold
Jan 07, 2008 | GE PSS25NGM Side by Side Refrigerator
Gsh25vgpccc ge side by siderefrigerator
well if you keep that damper open im sure everything in your refrig- will freeze is the temp- in the freezer o.k. if you have an ice maker is it working properly because if your freezer does not maintain the right temp your ice maker wont work. if so you might have a bad temp control (thermostat)
Dec 23, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Fan is Running
Your refrigerator isn't defrosting. When you melted the ice on the coils in the freezer you might have noticed a glass tube with a wire going into each end this is your defrost element that is probably bad. If it tests out good then your problem is either in the defrost thermostat, or the motherboard that tells your fridge when to defrost.
Nov 14, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Frigedair refrigator
My GE Side by Side refrigerator is about ten years old. the refrigerator side stopped working and is warm. The ice box side is cool but is not as cold as it usually operates.
Nov 07, 2007 | Whirlpool GD5SHAX Side by Side...
Refrigerators Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
