Question about Ryobi Saws
How to lower table of a ryobi table mitre saw model stm-305
SOURCE: changing the saw blade on a Ryobi Mitre saw
There may be a push button type blade lock, and on many of these saws the retaining bolt for the blade is backwards threads, e.i., looking at the top of blade retaining bolt, turn it clockwise to loosen. This would normally tighten, but in the case of many of these saws, it loosens it.
Posted on Feb 09, 2009
  • 86 Answers
SOURCE: ryobi bt 3000 table saw belt installation diagram
The BT3000 actually has TWO v-belts! Here's a link at the end of this solution to an exploded diagram. Basically you have a major disassembly, but it really isnt that complicated.
More great info on the BT3000 is available from the web site http://bt3000.com/
I have a BT3100 saw, and it is a good tool, but does require attention in maintenance procedures, but Ryobi did outline the necessary steps in their manuals. The above website also has the owner manual if you need one.
  1. Unplug saw
  2. Remove the blade
  3. Lower mechanism all the way to the bottom
  4. Flip over saw and lay on it's top
  5. Remove the blade guard panel opposite the motor
  6. Unbolt the motor assembly and remove the belt cover
  7. Replace the broken belts
  8. Re-assemble (be careful not to cross-thread the bolts in the aluminum housings!)
http://bt3000.com/Manuals/BT3000-Parts-Manual.pdf
Posted on Mar 22, 2009
Editor925
  • 285 Answers
SOURCE: How do I replace my mitre saw blade?
It should still easily fit a 5/8" blade. The arbor shape shouldnt have any effect on the type of arbor hole needed on the saw blade (only round arbor holes are made on saw blades. You will probably find the arbor securing nut has a shape that fits into the flat gaps between the saw blade and the arbor when fixed. So grab a 5/8" round arbor saw blade and give it a go. It should work fine.
It is the arbor nut that secures the blade onto the arbor via friction which holds it on.
Please rate this solution on FixYa!
Posted on May 29, 2009
SOURCE: How do I change the blade on my Ryobi 10" table saw?
The manual is posted on line. Changing the blade does not require turning the saw over, blocks of wood or vice grips. The advice listed above is potentially damaging to your equipment.
http://www.raygirling.com/ryobi/ryobi.htm#settadj
Posted on Sep 24, 2009
  • 8404 Answers
SOURCE: Ryobi 10 in Portable Table Saw modl #BTS12S won't turn on
Look for a trip switch on the saw motor
Posted on Nov 02, 2009
I have a Ryobi mitre saw EMS 1442L that has a stripped output assembly gear. According the parts listing this part is no longer available. Does any other model part fit this?
it may be worth investigating if later driven and pinion gears will fit the shafts of your unit
It is a way that ryobi has of making older unit obselete
if you research the gears by shaft size , number of teeth diameters thickness etc you may get something but look for matching gears and not just the stripped gear
you may get gears from another manufacturer/model to suit
Dec 13, 2017 | Ryobi Saws
How to lower toptable of a ryobi table mitre saw tms-305
http://ryobi.co.za/product/table-and-mitre-saw-combination-1800w-tms-305/
this saw has a 2 inch capacity. if you have say a 3 inch piece you use 2 passes of 1-1/2 each
regards
sir dana
Apr 25, 2017 | Ryobi Saws
Ryobi mitre saw jamming when cutting
There's a normal adjustment process of squaring the blade to the table, page 19 of your manual. If the blade is not square to the table then it will bind. Here's the link for the manual, see page 19.
http://manuals.ryobitools.com/system/files/400/original/TS1342_942_eng.pdf?2011
Dec 21, 2013 | Ryobi ZRTS1342L Factory-Reconditioned 14...
BLADE ALIGNMENT
bent blade...?
Sep 10, 2012 | Cars & Trucks
I have a ryobi 10" mitre saw and i took the guard
I don't know but if you have figured it out let me know. I have same prroblem.
Apr 19, 2011 | Ryobi 10 In Miter Saw With Laser
Spare parts for the ryobi cms812 compound mitre saw
Hi adamocka,
This website ships parts for my ryobi table saw much quicker than others.
http://ryobitools.com/support/parts_batteries
Give it a go!
Hope this helps,
Handie Andie
Mar 26, 2011 | Garden
I need to change the blade on a Ryobi TS 1300 table top mitre saw. I am needing some directions.
You can get the manual on the link below. on page 13 will tell tell you how to change blade.
http://dl.owneriq.net/d/d088bccc-fead-4473-8063-ddd58e6e961b.pdf
Good Luck and please rate 4 thumbs up for the free answer.
Jul 04, 2010 | Saws
Saws Logo
42 people viewed this question
Top Ryobi Saws Experts
enb54
Level 1 Expert
Jim Thurston
Are you a Ryobi Saw Expert? Answer questions, earn points and help others
