Question about In Office Equipment & Supplies
What order does color cartridges go in a Fs-05016n
  • In Master
  • 3,895 Answers
  • Mindi Fitzpatrick
    Mindi Fitzpatrick Apr 27, 2017
    Great Help! I always have a hard time pulling the manual up for some reason, appreciate your help very much
Where is developer unit in kyocera fs 1370dn
the developer unit for this printer looks like this.
26367533-y50xtmg3b3sor10el1acrrt1-1-0.jpg The unit can be found under the toner cartridge.
Here is a link on how to remove the toner cartridge.
okm2000 de Kyocera FS 1370DN 1370 1350 1320 Tonerwechsel Kopierer Drucker...
Best regards,
Nov 22, 2016 | Kyocera FS-1370DN
My cartridge is full of toner but the printer says it needs to be replaced, how do i reset the cartridge?
You can't. The toner levels are calculated and approximated. Make sure you use genuine Kyocera toner and replace it.
Sep 27, 2013 | Kyocera 1T05JK0US0 Model TK-152K Black...
I HAVE JUST REFILLED MY LEXMARK X2550 PRINTER COLOR CARTRIDGE NUMBER 35, BUT A MASSEGE ON MY PC SAYS: "Invalid Cartridge". How do l get it to be recognised so that l can use it?
35 is color ink cartridge .. high yield,
A new color print cartridge needs to be installed.
If available, click the Continue button on your computer screen to print using the
black (or photo) print cartridge. (The Continue button is available only at the
beginning of a print job.)
Note: A variable amount of ink remains in the color print cartridge.
Follow these steps to replace the color print cartridge in your printer:
1 Cancel the print job if not already canceled.
2 Replace the color print cartridge with a new cartridge. For more information,
see "Removing a used print cartridge" on page 35 and "Installing print
cartridges" on page 35.
3 Print again.
To order supplies, click Order Ink on your computer screen. You can also see
"Ordering paper and other supplies" on page 40 in this guide.
Troubleshooting 54
manual =
Installing print cartridges
1 If you are installing new print cartridges, remove the sticker and tape from the back and bottom of the cartridges.
1 2
Warning-Potential Damage: Do not touch the gold contact area on the back or the metal nozzles on the
Maintaining the printer
list of ink cartridge part numbers,6970,204812589_653399443_1037657543_en,00.html?tabId=7
Dec 23, 2010 | Office Equipment & Supplies
This issue will only occur if an ink cartridge(s) is or was installed inthe wrong position (slot) in the machine. When a cartridge is installed, the ink tube system is filled with the ink from the cartridges, to prepare the machine for printing. If the cartridge is inthe wrong position the tube will fill with the wrong color.
NOTE: If you just installed or replaced the ink cartridges and your printed documents are missing colors please refer to the solution - I just installed or replaced my ink cartridge and my printed documents aremissing colors. What can I do? Blank
To resolve this issue you will need to clean the print head.
NOTE: It may require 10 to 15 cleanings to clean the ink tubes and print head. During the cleaning process, the ink in the cartridge(s) will be consumed. Additional ink cartridges may be required to completethe cleaning process.
1. First verify the position of the ink cartridges:
a. Open the ink cartridge cover and check to make sure the ink cartridges are in the correct order.
b. Starting from the left side, the correct order is Black, Yellow, Cyan(blue), and Magenta (red).
- If the ink cartridges are installed in the correct order, close the ink cartridge cover and continue to STEP 2.
- If the ink cartridges are not in the correct order, remove the ink cartridges that are installed in the wrong position by pressing down on the release lever(s), located above the ink cartridge and remove the cartridge(s) from the machine.
Next, reinstall the ink cartridge(s) in the correct position in the machine by gently pushing the cartridge in until it clicks.
When all the cartridges are installed, close the ink cartridge cover.
2. After closing the ink cartridge cover, the LCD will prompt - Did youchange XXXX (XXXX = the color) This message will be displayed for ink cartridge that was removed. Press the - (Minus Key for No). This willkeep accurate data of how much ink is left in the cartridge.
1. Press the INK key.
2. Press OK to select Test Print.
3. Press OK to select Print Quality.
4. Press the COLOR START key.
5. Review the Check Sheet. The colors on the Check Sheet should be in a specific order: Black, yellow, Cyan (Blue) and Magenta (red).
a If the colors on the Check Sheet are in the correct order and are notmissing any dashes, press + (Plus Key for Yes) on the key pad and continue to STEP 7.
b If the colors on the Check Sheet are not in the correct order, are missing dashes or blank or a color other than Black, Yellow, Cyan or Magenta printed press - (Minus Key for No) on the key panel and continueto STEP 6.
6. The machine will need to perform cleanings to flush out the incorrectcolor or dried ink from the ink tubes and print head.
a. The LCD will ask you BLACK OK. If black is fully printed and is the correct color, press + (Plus Key for Yes). If it#s blank, missing dashes or is the incorrect color, press - (Minus Key for No).
b. The LCD will ask you COLOR OK. If any of the 3 colors (yellow, cyan (blue), and magenta (red) are fully printed and are the correct color, press + (Plus Key for Yes). If it#s blank, missing dashes or is the incorrect color, press - (Minus Key for No).
c. The LCD will say START CLEANING + for YES and - for NO. Press + for YES to start cleaning. The machine will go through a cleaning cycle that will take approximately one to two minutes.
d. After the cleaning is completed, the LCD will say PRESS START. Pressthe BLACK START key. This will print out the print quality check sheet again for you to check and see if your print quality issue has been resolved or not
NOTE: If you wait 1 minute after the cleaning cycle is completed, the display will return to date and time. You will need to go back to STEP 3 to print the Print Quality Check Sheet again.
e. If the ink color order is correct and all of the dashes are present, press + on the key pad to select YES and continue to STEP 7.
If the colors on the Check Sheet are not in the correct order, are missing dashes or blank or a color other than Black, Yellow, Cyan or Magenta printed press - key to select NO. Repeat the cleaning process byfollowing STEPS 6a through 6d. You may have to perform this procedure up to 15 times in order to clean the ink tubes and print head
NOTE: During the cleaning process, the ink in the cartridge(s) will be consumed. Additional ink cartridges may be required to complete the cleaning process.
7. Test by printing the document that had the reported problem (wrong color printing).
Dec 08, 2010 | Brother DCP 165C Compact Color Inkjet...
Kyocera laser printer toner refill
refill...uh oh probably wouldnt try it..there's is like only 1 company that does kyocera refill KATUN... you can try to find that on the most likely willl have to buy actuall kyocera toner..
Jan 24, 2010 | Kyocera FS-C5015N Laser Printer
I need to order a new color cartridge door latch. where do i find one?
Here is the part number you need.
Link below where you can order.
Cartridge latch (Color) - Holds color ink cartridge in place
Dec 14, 2008 | HP PSC 500 All-In-One Printer
Top In Office Equipment & Supplies Experts
Level 1 Expert
Tygh Duval
Tygh Duval
Are you an In Office Equipment and Supply Expert? Answer questions, earn points and help others
