How to clean heads on color cartridges to print correctly
    Sergeant:
  • 163 Answers
Your printer will have a Maintenance mode or folder when done you have to look for the alignment mode where you select the correct #
Cheers
Sir J Dana .Hamilton Taylor
IQ397
Posted on Apr 25, 2017
My printer only prints magenta\
A color or photo cartridge is either low, clogged or has run out of one of the basic colors it mixes together to create the colors in your images. The printer cannot print correctly if it lacks one of the basic colors, even if it still contains some of the other colors. The cartridge may also be clogged. The cartridge must be replaced
This may help
You can try to clean the printer head manually. To clean the printer head, remove the ink cartridge from the printer. Moisten a cotton swab by dipping it in hot water or isopropyl alcohol, and then gently wipe the printer head. Do this repeatedly until it softens the dried ink.
For models where the printer head is located in the printer, you can put 7 to 10 drops of isopropyl alcohol in the ink receptacle where the ink flows from the cartridge to the head. Turn the printer to self-cleaning mode. You can also leave it for a few hours or overnight before repeating the self-cleaning mode.
If the print head is located in the cartridge, soak the print head in hot water and let it soak overnight. Dry the print head part using a paper towel and switch it to self-cleaning mode.
If the hot water soak does not work, place the cartridge printer head in isopropyl alcohol and let it soak overnight. Wipe off the soaked area and dry it carefully using a damp paper towel. Turn the printer to self-cleaning mode to remove any dried ink.
For more Help Source... Can You Fix Dry Ink Cartridge eHow
Thanks,
HP Phone Number
Jun 25, 2014 | HP Officejet Pro L7680 All-In-One InkJet...
I'm trying to get my Canon iP4200 to print in BLACK ONLY
Hi . I think the print head may be is clogged. If cleaning didn't correct the problem . Print head need to be replaced
Jun 25, 2017 | Canon PIXMA iP4200 InkJet Photo Printer
Don't print the black color
Doing reference on your issue. Double check the ink cartridge to make sure that the cartridge is correctly installed. Also be sure that the black ink cartridge used is compatible with the machine.
The next thing to do is a cartridge cleaning as the belief is that the print head is blocked. If you have done a thurough cleaning, the next thing to do is replace the black ink cartridge to be certain the ink cartridge is not faulty.
I have included print head cleaning instructions in case you have not done this cleaning process.
here is some information from the Brother support site:
If one or more of the ink colors are missing from pages printed by your machine (i.e. received faxes, copies and/or documents printed from the PC etc), nozzles in the print head may be clogged, or the ink cartridge in question may not be installed correctly. Verifying that the ink cartridges are installed correctly and/or cleaning the print head may solve the problem.
Cleaning the print head may solve the problem. When cleaning the print head, you are given the option to clean BLACK ONLY, one of the three colors (CYAN, YELLOW, or MAGENTA), or all four colors at once. For this issue we recommend cleaning only the affected color. If more than one color is missing then choose ALL.
When the machine completes cleaning the print head, press Color Start. A Print Quality Check Sheet will print.
Brian
Jan 22, 2011 | Canon MX700 Office All-In-One InkJet...
WHILE TEST PRINT CYAN INK NOT SHOWING WHAT SHOULD I DO SIR
This issue will only occur if an ink cartridge(s) is or was installed inthe wrong position (slot) in the machine. When a cartridge is installed, the ink tube system is filled with the ink from the cartridges, to prepare the machine for printing. If the cartridge is inthe wrong position the tube will fill with the wrong color.
NOTE: If you just installed or replaced the ink cartridges and your printed documents are missing colors please refer to the solution - I just installed or replaced my ink cartridge and my printed documents aremissing colors. What can I do? Blank
To resolve this issue you will need to clean the print head.
NOTE: It may require 10 to 15 cleanings to clean the ink tubes and print head. During the cleaning process, the ink in the cartridge(s) will be consumed. Additional ink cartridges may be required to completethe cleaning process.
1. First verify the position of the ink cartridges:
a. Open the ink cartridge cover and check to make sure the ink cartridges are in the correct order.
b. Starting from the left side, the correct order is Black, Yellow, Cyan(blue), and Magenta (red).
- If the ink cartridges are installed in the correct order, close the ink cartridge cover and continue to STEP 2.
- If the ink cartridges are not in the correct order, remove the ink cartridges that are installed in the wrong position by pressing down on the release lever(s), located above the ink cartridge and remove the cartridge(s) from the machine.
Next, reinstall the ink cartridge(s) in the correct position in the machine by gently pushing the cartridge in until it clicks.
When all the cartridges are installed, close the ink cartridge cover.
2. After closing the ink cartridge cover, the LCD will prompt - Did youchange XXXX (XXXX = the color) This message will be displayed for ink cartridge that was removed. Press the - (Minus Key for No). This willkeep accurate data of how much ink is left in the cartridge.
1. Press the INK key.
2. Press OK to select Test Print.
3. Press OK to select Print Quality.
4. Press the COLOR START key.
5. Review the Check Sheet. The colors on the Check Sheet should be in a specific order: Black, yellow, Cyan (Blue) and Magenta (red).
a If the colors on the Check Sheet are in the correct order and are notmissing any dashes, press + (Plus Key for Yes) on the key pad and continue to STEP 7.
b If the colors on the Check Sheet are not in the correct order, are missing dashes or blank or a color other than Black, Yellow, Cyan or Magenta printed press - (Minus Key for No) on the key panel and continueto STEP 6.
6. The machine will need to perform cleanings to flush out the incorrectcolor or dried ink from the ink tubes and print head.
a. The LCD will ask you BLACK OK. If black is fully printed and is the correct color, press + (Plus Key for Yes). If it#s blank, missing dashes or is the incorrect color, press - (Minus Key for No).
b. The LCD will ask you COLOR OK. If any of the 3 colors (yellow, cyan (blue), and magenta (red) are fully printed and are the correct color, press + (Plus Key for Yes). If it#s blank, missing dashes or is the incorrect color, press - (Minus Key for No).
c. The LCD will say START CLEANING + for YES and - for NO. Press + for YES to start cleaning. The machine will go through a cleaning cycle that will take approximately one to two minutes.
d. After the cleaning is completed, the LCD will say PRESS START. Pressthe BLACK START key. This will print out the print quality check sheet again for you to check and see if your print quality issue has been resolved or not
NOTE: If you wait 1 minute after the cleaning cycle is completed, the display will return to date and time. You will need to go back to STEP 3 to print the Print Quality Check Sheet again.
e. If the ink color order is correct and all of the dashes are present, press + on the key pad to select YES and continue to STEP 7.
If the colors on the Check Sheet are not in the correct order, are missing dashes or blank or a color other than Black, Yellow, Cyan or Magenta printed press - key to select NO. Repeat the cleaning process byfollowing STEPS 6a through 6d. You may have to perform this procedure up to 15 times in order to clean the ink tubes and print head
NOTE: During the cleaning process, the ink in the cartridge(s) will be consumed. Additional ink cartridges may be required to complete the cleaning process.
7. Test by printing the document that had the reported problem (wrong color printing).
Dec 08, 2010 | Brother DCP 165C Compact Color Inkjet...
Colors don't print correctly. such as green prints as red. what's messed up?
The color cartridge for this printer has three colors (cyan, magenta, and yellow) within it. So if one runs out or is dried up if throws the color out of wack. Try running the head cleaning first but replacing the color cartridge should correct the problem.
Aug 09, 2010 | HP DeskJet 930c InkJet Printer
Printer is not printing colors correctly. Brown looks red. Is there a way to clear ink heads or ink area. case shows ink spillage, need to clean up area maybe will help with color printing.
You press the ink button and choose cleaning option and test print to see if colors are correct, clean again if colors are wrong. The spillage won't hurt print quality when it's around the cartridge area. If you are using generic inks they sometimes are not the correct color.
Feb 08, 2010 | Brother MFC-440CN InkJet Printer
Brother mfc 3360 model mostly problem is no printout, pls soluti
Hi!
If one or more of the ink colors are missing from pages printed by your machine (i.e. received faxes, copies and/or documents printed from the PC etc), nozzles in the print head may be clogged, or the ink cartridge in question may not be installed correctly. Verifying that the ink cartridges are installed correctly and/or cleaning the print head may resolve this problem.
To verify the ink cartridges are installed correctly follow the steps listed below:
Open the ink cartridge cover and reinstall the ink cartridge. Open each lock release lever and push it until it clicks, and then close the ink cartridge cover.
The LCD may then display:
Did you change xxxxxx? Yes No.
The LCD may display this question for the color(s) that was replaced.
Select Yes or No by pressing arrow keys or 1/2 or "+/-" key.
After all the correct selections are made, the machine will then go into a cleaning.
The machine should begin cleaning automatically, and the LCD will alternately show "CLEANING" and "PLEASE WAIT". When the machine completes its cleaning cycle, the LCD will go back to standby mode automatically. Print the Print Quality Check Sheet and see if all colors are present:
Press the Ink or Ink Management key.
Use the up or down navigation key to select Test Print.
Press OK to confirm your choice.
Use the up or down navigation key to select Print Quality.
Press OK to confirm your choice. Press the Color key to print the Test Sheet.
If one or more of the colors is still missing from the printed page, cleaning the print head may resolve this problem. When cleaning the print head, you are given the option to clean BLACK ONLY, one of the three colors (CYAN, YELLOW, or MAGENTA), or all four colors at once. For this issue we recommend cleaning only the affected color. If more than one color is missing then select ALL.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jun 25, 2009 | Brother MFC-3360C InkJet Printer
I have an Epson Stylus CX5500, i currently replaced the cartridge with Miro Jet cartridge which is compatible with this tpye of printer. i started printing and the colours come ut incorrect. Also how do...
You can clean the heads with software function.
Open epson print center maintenance clean head. Or Right click on printer icon on task bar, Select clean head.
Even though the Miro cartridge is compatible the ink color, texture, drying time, is different. Resulting in colors coming out wrong. Try going to Miro jets site & download printer driver or color correction file for your printer. Most provide them.
Good Luck!
Mar 08, 2009 | Office Equipment & Supplies
Canon pixma ip4000 color not printing correctly with full inks
In both cases be sure using correct ink. Use of generic ink can lead to leakage of catrridge seats do to crossion from inferrior ink quality (per Cannon). Be sure ink in proper locations - see manual. Run the maintenance proceedures: cleaning then print nozzle pattern. If all colors are not proper after two or three cleanings, perform deep cleaning. Print nozzle pattern after each cleaning. This should clear up problem. If not, print head may need replacement.
Feb 09, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Pixma MP830 is printing things green that should be red
when you change all new cartridges (make sure all cartridge ok, and the cartridge pins connection ok) still red color lost, it is the trouble at print head ink chanel some of that is too dry for longer time less using , most CANON printer head is separated from the ink cartridge, two way you may try:
1) take out the ink cartridge, drop down a little the special cleaner (best clean tools buy from dealer), to the head ink chanel hole, then set back the ink cartridge and waiting minutes
2) try put the print head bottom surface touch a little cleaner or water 1-2 hrs, if you can take out the print head unit. still not fixed for some case that should change the print head unit.
Feb 06, 2009 | Canon PIXMA MP830 All-In-One InkJet...
32 people viewed this question
k24674
jasbo
jasbo
