Question about Microwave Ovens
Clarke IG2200 generator manual
Having problems inverter circuit board cooked copper coil any one got a second hand board ? For Clarke IG2200 inverter.twin socket
    Sergeant:
  • 163 Answers
Code h98 Panasonic could it be a fuse?
H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit. It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
(Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these inverters. You can find an authorized US Panasonic servicer here. In Canada, you can find an authorized Panasonic servicer here.)
See if this describes what's happening:
  • Put in time, push start and unit runs for 2 seconds, relay clicks, unit goes off. Cook time on display goes off and clock time comes back. Bad upper interlock switch and charred connector
If so, see my help files here, here, and here. Otherwise, if the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
For more free DIY and other help & advice, feel free to contact me.
William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 13, 2017 | Panasonic Microwave Ovens
Panasonic Microwave Oven starts for 5 seconds then shuts off
If it stops after exactly 7 seconds, it has a problem with the inverter.
If the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
Dec 25, 2012 | Microwave Ovens
My timer stops after 5 seconds.
Since no model number was posted, I have to give a general answer.
Since it was posted under Panasonic, I'll assume it's a Panasonic.
See if one of these describes what's happening:
If so, see http://031d26d.namesecurehost.com/mwd/safety.txt
http://031d26d.namesecurehost.com/mwd/disassembly.txt
http://031d26d.namesecurehost.com/mwd/doorsw.txt
If it stops after 7 seconds, it has a problem with the inverter.
Sep 26, 2011 | Panasonic NN-T990SA Microwave Oven
Time set does not complete
You didn't mention your brand or model number, but I'll assume it's a Panasonic since you posted this under a Panasonic category.
If so, see http://207.234.249.73/mwd/safety.txt , http://207.234.249.73/mwd/disassembly.txt and http://207.234.249.73/mwd/doorsw.txt
If it stops at 16 seconds and is a sensor model, it probably has a defective humidity sensor.
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter, controller, magnetron, or a bad connection from one or the other.
Display codes H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
That may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
May 26, 2010 | Panasonic NN-T994SF Microwave Oven
Power to microwave but does not cook food
May 26, 2010 | Panasonic NN-H264 Microwave Oven
My panasonic inverter microwave model no NN-T523M switchs off after 5 secondsno matter what setting. the digital screen says consult manual, which has been misplaced
You can find Panasonic owner's manuals here.
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
If so, see http://207.234.249.73/mwd/safety.txt http://207.234.249.73/mwd/disassembly.txt http://207.234.249.73/mwd/doorsw.txt
If you decide to replace your inverter, you can order Panasonic parts from Encompass here or you can call them toll-free at 866-779-5835.
May 15, 2010 | Panasonic Microwave Ovens
Black screen and a note
If so, see http://www.microwavedisplay.com/safety.txt , http://www.microwavedisplay.com/disassembly.txt and http://www.microwavedisplay.com/doorsw.txt
May 22, 2009 | Microwave Ovens
Microwave turns off by itself after being on for 3 seconds
If so, see http://www.microwavedisplay.com/safety.txt and
Mar 03, 2009 | Panasonic NN-S532 1200 Watts Microwave...
Panasonic inverter microwave
If the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle. It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Dec 26, 2008 | Microwave Ovens
If I put in cook time 3 minutes it only cooks for about 10 seconds then turns off
According to a recent report we received, if it stops after 7 seconds, it has a problem with the inverter.
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer.
Aug 28, 2008 | Panasonic Microwave Ovens
Microwave Ovens Logo
50 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
