Question about Martin Music
I have an aria brazilian rosewood acoustic looks like a guild and a martin mated and had a baby. numers stamped on inside bracing wood are g40794 and 9270
Tell me about this guitar
Pretty broad question. It's a parlour guitar, made in China. They are very highly regarded, well built, and can be used for most acoustic applications, though I've heard fingerstyle players especially like the tonality. Solid spruce top, rosewood sides, and a 3 piece rosewood/maple back, with a mahogany neck and rosewood fingerboard. It's got a 1 11/16 nut and a nice TP4T electronics package.
If you want more information on that specific guitar, email Tak with your serial number, and they will give you a production date.
Oct 06, 2015 | Takamine EG416S New York Styled Acoustic...
What does the serial number 171756 on a Martin D28 Guitar mean?
That serial number would correspond to a guitar built in 1959. The model will be either be stamped on the neck block seen from inside the guitar or on the label visible through the sound hole. Martin's phone number is 610-759-2837 and they may be able to provide more specific info.
Oct 02, 2014 | Martin Guitars Martin D28 Dreadnought...
For model years 1970 to 1979, the only information available is the first and last serial number produced- no model names or numbers are available. 1973 serial numbers are 75603 to 95496, so your guitar serial number would be towards the end of 1973 in Westerly, RI.
The value is hard to say- the instruments from that era can be valuable: instruments of that era have sold on EBay from between $800.00 to over $2,000.
As always, it's worth exactly what someone will pay for it- Good luck!
Jun 16, 2014 | Guild F50R Vintage Jumbo AcousticElectric...
How old is my Guild AD406699
Guild started making the GAD series in China in the early 2000's.
The earliest mention I can find of the GAD D25 is 2007.
Hope this helps!
Mar 03, 2014 | Guild Gad25 Dreadnought Acoustic Guitar
Acoustic top crack
Your best bet is to send it back to Martin. Normally the top can be repaired if it's a linier crack along the grain line, but to do the job correctly the top will need to be re-finished. Plus if the crack is more complicated, like if the bracing is involved it's best to pay the ptrice to get it done right.
Mar 02, 2014 | Martin D16gt Dreadnought Acoustic Guitar
How do I change the battery in a martin drs2 guitar
if you look inside the cavity you will see a black nylon insert that is velcrod to the base. simply pull it off its velcro , swap the battery out , and then revelcro it. Super simple.
Nov 09, 2013 | CF Martin 000X1AE Java Mahogany Acoustic...
I pressume that martin thinline preamp pick up has two pick ups ?
your pressumption would be correct. The Thinline 332 runs under the bridge saddle, and the Piezo is attached ti the inside of the guitar body, tilt your guitar and have a look inside, you may be able to see it.
Jun 29, 2012 | Martin Thinline 332 Plus Piezo Acoustic...
I have a 1996 Martin D42. The top is caving in slightly. It seems the scalloped bracing is scalloped too much and the back half of the top is being pushed down by the pressure on the bridge. Any...
You should take it to a Luthier to get an estimate for repairing it before the damage becomes unrepairable. Also verify you are using the CORRECT tension strings.
Apr 13, 2011 | Martin D 42 Dreadnought Acoustic Guitar
How old is my Guild Guitar model CE100-D
Try this link:http://www.guildguitars.com/support/contact_us.php
Aug 11, 2010 | Guild Gad25 Dreadnought Acoustic Guitar
Sound hole
Did you buy it new, Life time warrenty. This is a common problem with finishes due to humidity and wood moisture at manufacturing.
Check with Martin they are very cool about this stuf.
Mar 24, 2010 | Martin LXM "Little Martin" Acoustic Guitar
Music Logo
Top Martin Music Experts
David Baisa
freddybrass
Level 1 Expert
Are you a Martin Music Expert? Answer questions, earn points and help others
