Question about PfaFF Sewing Machines
My pfaff 1475cd is missing in the bobbin stitch very slack tried a few things even got a new bobbin case machine serviced last sept bobbin chamber oiled and cleaned regularly thank you.
  • PfaFF Master
  • 12,036 Answers
This looks like bird nesting (also called thread nesting) or what I refer to as thread barfs. It occurs most often when the top thread is not seated completely in the tension disk.
Remove the top thread from the machine.
ALWAYS RAISE the presser foot and rethread from the beginning.
Verify the thread path is correct.
Set the top tension to the midway point (which may need to be tweaked for your particular machine).
It may also help to pull the bobbin thread up to the top of the fabric, holding both thread tails in the left hand while hand-rotating the handwheel or slowly begin stitching with the foot control through the first couple of stitches.
Posted on Apr 25, 2017
  • 106 Answers
SOURCE: picking up bobbin thread
First easy thing to check, are you using the correct length needle.
If this is not the problem then somehow the needle bar has moved and the the needle depth is to high or the timing is wrong..
Unless you really know what you are doing then I am afraid a sewing machine tech needs to reset the needle depth and subsequently the timing.
Posted on Mar 30, 2008
  • 6 Answers
SOURCE: timing my pfaff 332 sewing machine
There are two parts to the sew hook on that machine. The outer part has the hook point that grabs the thread off the needle. Then there is an inner part which has a post in the center of it that the bobbin case fits on to. The inner part should be held in place with an arm that has a bump on it. It keeps the inner part from spinning around. Sometimes this arm slips loose and a notch in the inner part of the hook assembly slips out from under the knob on the arm. If this is what is happening, you need to loosen the screw holding the arm in place and reposition the notch of the inner part of the hook back under the bump on the arm. There needs to be clearance between the notch and the bump for the thread to pass between the two. And the bump should be in line with the needle when it is in its lowest position.
If this doesn't solve the problem you need to take the machine in for repair.
Wayne
Posted on Mar 12, 2009
SOURCE: janome straight stitch loose
I don't know if this is the right answer for any of you, but thought I'd put my 2 cents worth in. Often this can be the bobbin in backwards. It needs to unwind a certain way depending on the machine. I've heard a phrase for this: Mind your p's and q's which means some wind off to the right like a q, others to the left like a p. Mine has to unwind one way then be slipped backwards into a little slot or it does that loose bottom thread looping and bunching someone here mentioned. It seems everytime I get that problem I rethread the top thread 100 times before it clicks again and I remember it could be the bobbin thread. Either your manual will tell you the correct way, or you could experiment and try one or the other. Once you figure out whether you're a p or a q, mark it on your machien somewhere to remind yourself.
Good Luck and Happy Sewing!
Posted on Apr 04, 2009
Mimito7
  • 128 Answers
SOURCE: Tension Problem on Pfaff 2034, bobbin loops
Rule of thumb.. Loops on the bottom, problem on the top. Loops on the top, problems on the bottom.
Set your upper tension at 4, and rethread the machine from the top. Just before you thread the needle, but the presser foot down. If the thread pulls right thru easily, then the thread is not thru the tension wheel right. Because, if you can't pull the thread thru with the presser foot down, you have it threaded right.
Posted on Apr 25, 2009
bargainbox
  • 1388 Answers
SOURCE: Kenmore model 385.1764180 bobbin jam
Use a Ball Point needle for stretch fabrics....Janome Blue Tip # 11 are excellent....
Please TRY the solution BEFORE giving your considered rating.
Specific detail on bobbin case adjustment (with picture) near halfway down reply, the remainder will help you achieve a balance of top and bottom tensions.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
.bargainbox.com.au
Posted on Aug 02, 2009
I got pfaff expression 2 not stitching i have rethreaded changed needle reloaded bobbin cleaned out all of bobbin area
If the thread is not picking up the bobbin thread and you have installed a new needle, then your machine is not in time. Search for sewing machine timing or take it for service.
Dec 24, 2016 | PfaFF Sewing Machines
How to wind the bobbin on a pfaff 1475cd
here is a link for a manual--it should have the information in it that you need
Pfaff 1475 Creative CD Instruction Manual
Dec 17, 2014 | PfaFF Sewing Machines
Pfaff 1475 manual
Not sure if your model is the creative 1475. The closest I can find at a service website of Pfaff is 1473. Check if this is similar to your model and it shows where the balance wheel goes.
http://new.pfaff.com/SiteMedia/PFAFF/Products/Machines/Support-manuals/Creative_1473-manual-EN.pdf
Also see this Youtube video showing how to insert the bobbin after threading.
Pfaff Creative 1473 CD sewing machine in action
otherwise you will have to buy service manual for eBay
PFAFF CREATIVE 1475CD Sewing Machine Service Manual
Aug 12, 2014 | PfaFF Sewing Machines
It wont stitch tee/shirt material it misses stitchs
If machine misses stitches consistently, it can be several things.
Needle not installed correctly, not threaded correctly, Bobbin case not installed correctly, make sure the bobbin itself is inserted correctly and spinning in the correct direction.
Finally, machine may need service the timing is off. All actions of a sewing machine are carefully "timed" to form a stitch while sewing. Sewing things that were too heavy for the machine or you hit the bobbin case while sewing can knock the machine out of adjustment.
Let a professional do the maintenance on your machine. Some may opt to show you how to do more in depth maintenance yourself at home.
Cheers,
Feb 01, 2013 | Sewing Machines
My needle has started hitting on the bobbin case in the mahine,can anyone tell me how to fix this problem.
Could be a couple of things:
Could be a bent needle? please change it for a sharp new one and make sure it goes in correctly, flat shank to the back.
Bobbin case dislodged or not in correctly ; I think these are vertical rotary hook machines with the bobbin inside a removeable bobbin case? Check that you have put the case in correctly, there is usually a long finger on the case that latches into a point on the rotary hook, holding the case in the correct position. Probably also a latch on the front of the bobbin case, which you use to fit it into place and remove it.
Lastly could be that the machine timing is out. Manually turn through a stitch sequence with no thread or bobbin, the needle needs to be at its lowest point down into the bobbin area when the rotary hook brings the thread around to catch at the back of the needle.
If you suspect it is the timing, you may want to get a technician to do this repair but certainly try the first two items first.
Oct 13, 2011 | PfaFF Creative 7570
Are pfaff 1475cd sewing feet compatible with pfaff 1151 machine
Hi. Some Pfaff machines have something called an "IDT" which looks rather like a small, black walking foot behind the pressure foot, to help feed the fabric evenly. Pfaff machines with this IDT need "IDT" pressure feet. (I can't find a listing of which machines have this and which don't, so you'll have to look at your machines or check your manuals.) If both machines have the IDT, then the feet are compatible. If neither has the IDT, then the feet are also compatible.
Hope this helps!
Happy Sewing,
Robbie
Mar 14, 2010 | PfaFF Sewing Machines
I'm trying to do shirring?
My machines has a shirring foot, so I don;t have the same machine. However, I do not think that elastic thread will work in the bobbin. Have you tried it the other way around? Do you have your manual?
Aug 07, 2008 | Sewing Machines
Sewing Machines Logo
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
