Question about Kenmore Washing Machines
The drain pump/motor in my kenmore 46742 makes a loud humming noise when the water is being drained. Do I need to replace the drain pump/motor?
The water drains as it should; no issues yet. I pulled the toe panel and checked the drain basket--no foreign objects of any kind.
    Sergeant:
  • 163 Answers
Http://download.sears.com/own/46742e.pdf
The pump could have a build up in it. The Sears manual is attached. is it secured and rusted off or suspended by the hoses?
Regards
Sir J Dana Hamilton Taylor
IQ 397
Posted on Apr 25, 2017
LG- Front Loader making loud deep humming noise prior to draining.
I had the same problem. Loud noises during draining operation. It turned out to be the drain pump motor. The impeller that pumps the water wears out on the shaft, and then starts to flop around creating vibrations, and in turn the noises you hear. The pump is a very inexpensive part. $35-50. There is some work involved to get to it, and to replace it, but not overly complex. Just watch the motor wire connections. Take a picture with your camera/phone of the connections. I would recommend watching the youtube video in the link provided on how to get to the motor, as some of the steps can be challenging, especially the drum seal retaining ring removal and reinstallation steps. https://www.youtube.com/watch?v=8cPl22OC9f4 .
Good luck.
Apr 14, 2014 | LG Washing Machines
Ariston li 700
follow the steps and fix it. God bless you
Drain Pump
If the dishwasher is loud during operation, the drain pump might be defective or might have some debris in it. This is a common problem.
Circulation Pump
If the dishwasher is loud during operation, and the noise is a continuous drone similar in speed to the circulation pump sound, it's likely that the circulation pump motor bearings have failed. Once this happens the circulation pump will have to be replaced, the bearings are not repairable.
Drain Impeller
If the dishwasher is loud during operation, the drain impeller might be broken, or there might be debris in the pump. Generally, to gain access to the pump the top of the pump housing will have to be removed.
Pump and Motor Assembly
If the dishwasher is loud the motor bearings, drain impeller or wash impeller might have worn out. All three of these components are part of the pump and motor assembly. It may be possible to replace one of the impellers, but the motor bearings cannot be repaired. In that case the pump and motor assembly will need to be replaced.
Wash Impeller
The wash impeller is a small, plastic blade. The motor spins the impeller forcing water through the spray arms to clean the dishes. If one or more blades has broken off of the impeller the dishwasher is loud. The impeller can also scrape against the pump housing if it is damaged, warped or bent.
Circulation and Drain Pump Motor
If the dishwasher is loud during operation, and the noise is a continuous drone similar in speed to the motor sound, it's likely that the circulation and drain pump motor bearings have failed. Once this happens the motor will have to be replaced, the bearings are not repairable.
Water Inlet Valve
The water inlet valve is an electrically controlled water valve. When it is new, the water inlet valve is very quiet. Over time, the diaphragm inside the valve deteriorates and deforms. This deformation interacts with the water rushing in and can cause a loud vibration, buzzing, squealing or other noises. If the dishwasher is loud during the filling cycle, replacing the water inlet valve may solve the problem.
Jul 06, 2013 | Dishwashers
I have a kitchen aid dishwasher KuDR01TJBLO noisy when draining
see this causes and fix it. God bless you
Drain Pump If the dishwasher is loud during operation, the drain pump might be defective or might have some debris in it. This is a common problem.
Circulation Pump If the dishwasher is loud during operation, and the noise is a continuous drone similar in speed to the circulation pump sound, it's likely that the circulation pump motor bearings have failed. Once this happens the circulation pump will have to be replaced, the bearings are not repairable.
Drain Impeller If the dishwasher is loud during operation, the drain impeller might be broken, or there might be debris in the pump. Generally, to gain access to the pump the top of the pump housing will have to be removed.
Pump and Motor Assembly If the dishwasher is loud the motor bearings, drain impeller or wash impeller might have worn out. All three of these components are part of the pump and motor assembly. It may be possible to replace one of the impellers, but the motor bearings cannot be repaired. In that case the pump and motor assembly will need to be replaced.
Wash Impeller The wash impeller is a small, plastic blade. The motor spins the impeller forcing water through the spray arms to clean the dishes. If one or more blades has broken off of the impeller the dishwasher is loud. The impeller can also scrape against the pump housing if it is damaged, warped or bent.
Circulation and Drain Pump Motor If the dishwasher is loud during operation, and the noise is a continuous drone similar in speed to the motor sound, it's likely that the circulation and drain pump motor bearings have failed. Once this happens the motor will have to be replaced, the bearings are not repairable.
Water Inlet Valve The water inlet valve is an electrically controlled water valve. When it is new, the water inlet valve is very quiet. Over time, the diaphragm inside the valve deteriorates and deforms. This deformation interacts with the water rushing in and can cause a loud vibration, buzzing, squealing or other noises. If the dishwasher is loud during the filling cycle, replacing the water inlet valve may solve the problem.
Sep 28, 2012 | KitchenAid Dishwashers
My Kenmore dishwasher is making a combination grinding/humming noise during the draining cycle
see this causes and use the common sense. God bless you
If your dishwasher seems noisy, check these: Water-inlet valve Motor Heater fan Pump Water-inlet valve An aging water-inlet valve can sometimes fail slowly, rather than all at once. It can shudder on and off rapidly, causing the incoming water lines to shake, rumble, and rattle--sometimes violently. If yours is doing this, replace the inlet valve. Motor If it's the motor that's noisy, either of these may be the "culprit:" As motor bearings wear out, they can become quite loud when the motor runs. They wear out quickly if they frequently get wet, because the water washes away the motor bearing grease. Bearings can get wet if the spin seal is defective. Then there will also be water leaking onto the floor beneath the dishwasher. Replace the seal if it leaks (read about the main tub seal in the "It leaks" section, later). If, from beneath the dishwasher, you can see a round, plastic disc that's mounted to the top of the motor (a "slinger"), it may have broken free of the motor shaft. If so, it could be rattling around the shaft while the motor is running. If that's the problem, you need to replace the motor. Heater fan If the heater fan bearings are rusted or worn, they may squeal, or scrape loudly during the drying cycle. If this is the problem, replace the fan motor. Alternatively, the fan blade may be loose. If so, you need to replace it. Pump Small fruit pits, toothpicks, and fragments of glass sometimes get stuck in the pump. When this happens, open the pump and remove the debris. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. To get to the pump, you usually need to remove the lower rack, the spray arms, and the spray arm support from the inside of your dishwasher. A dishwasher pump isn't obvious. Look for an impeller--a round, plastic fan blade-type device that spins around and pushes the water toward the drain. When you can see the drain impeller, you should be able to see the clogging debris.
Sep 19, 2012 | Kenmore 24 in. 17482 / 17484 / 17489...
I have a Kenmore top loading large capacity washer model 1028882791. It began washing as usual then began to making a loud humming sound. The agitation stopped. It only makes a loud humming sound. I...
The humming sound is coming from the drive motor running but unable to drive the agitator nor the basket to spin. The drive motor is definitely running as the drain function works because of the fact that drain pump is directly coupled with the rear spline of the motor. The drain pump works in either direction as long as the motor runs. The problem is obviously a broken motor coupler which transfers the mechanical energy of the motor to the transmission. The solution then is to replace the broken coupler. Click on the link below for the detailed step-by-step procedure in replacing the motor coupler.
Replacing Motor Coupler on Kenmore and Whirlpool Top-Load Washing Machines
Jan 13, 2011 | Kenmore Washing Machines
Kenmore Washer makes loud noise when draining
check and clean the pump. possible coins in it
Feb 07, 2010 | Washing Machines
Kenmore Elite (Calypso) Top loader Will start and fill up w/ water, and wash for a while. During the washing process it makes a humming noise and then the display gives a "ob" reading. I have replaced the...
The OB indicates and out of balance condition has been detected by the motor control.
One thing about the OB error is that the lid must be opened to clear the error and allow the washer to advance to the next part of the cycle. If the lid is not opened to adjust the clothes then the OB error will happen again.
If the OB error was cleared and the OB occurs with an empty load then the motor control has failed.
The drain pump must work. The image below shows how to run a diagnostic test to check the drain pump. Follow the instructions in the image below and check the drain pump operation. If the pump runs and the water does not drain then the sump is clogged. If the pump hums but does not run then the pump needs to be replaced.
http://media.fotki.com/1_p,wkktswgwqtqrbwfxgtqsskgwtqkq,vi/gftrgbbtfxfffgqskfk/1/1303472/5961857/image48348img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 18, 2009 | Kenmore 23822 Top Load Washer
Washing Machines Logo
32 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
