Question about Garden
What type of oil does the yard works 4 ton log splitter use
2 Suggested Answers
  • 163 Answers
SOURCE: what type of oil does the 4 ton yard works log splitter use
The manual is here, it should say. ATF is used in industrial applications.
Automatic Transmission Fluid)
Sir J Dana Hamilton Taylor IQ 397
Posted on Apr 25, 2017
What type of oil does the 4 ton yard works log splitter use
Apr 25, 2017 | Garden
Works for 15 min and then ,the ram moves to log and stops,checked fluid ok, voltage 115 ok
My thought is that there is air in the line. I had problem like that with my splitter. To cure it I had to stand the splitter on end because the oil fill is at the wedge end. I filled it. set it back horizontal and cycled the ram full length 3 times. I stood it on end again and could add more fluid. When I filled again it was now full of fluid and works properly. It also could be that the splitter is not powerful enough to split that size log down the middle. I must take a smaller bite then it works.
Dec 13, 2015 | Earthquake 5 - Ton Electric Log Splitter
Wood splitter is pushing hydrolic fluid out fill tube on the return stroke
make sure that the ram is in the fully retracted position
empty oil reservoir until the oil level is at the required position normally about 1/4 inch below filler plug
if oil is added with the ram at any extension then the extra oil will be pushed back into the reservoir and over flow out
Jun 19, 2015 | Swisher 28 Ton 11.5 HP Log Splitter -...
Adding hydrolic oil to yardworks 4-ton wood spliter
Replace the Hydraulic oil in the log splitter after
every 150 hours of use. Take following steps to
replace it.
  1. Make sure all moving parts stops and the log splitter is unplugged.
  2. Unscrew Oil Drain Bolt with Dipstick to remove it.
  3. Turn the log splitter on the Support Leg side over an 4 liters capacity container to drain the hydraulic oil off.
  4. Turn the log splitter on the the motor side.
  5. Refill fresh hydraulic oil at the volume as per the hydraulic oil capacity of a particular model indicated in above specifications table.
  6. Clean the surface of Dipstick on the Oil Drain Bolt and put it back into the oil tank while keep the log splitter vertically.
  7. Make sure the level of the refilled oil is just between 2 grooves around the Dipstick.
  8. Clean the Oil Drain Bolt before thread them back. Make sure they are tightened to avoid leakage before place the log splitter horizontally.
Periodically check oil level to ensure it is between
2 grooves around the Dipstick. Upon Lower oil
level, oil refilling is required.
Sep 22, 2013 | Hardware & Accessories
Just got a log splitter cantget started motor running it moved and blew fuse
Hi, not much info to go on here, but;
have you ensured that your outlet automatic fuse (if applicable) will handle the current of the electric motor? Check ratings. If motor rating is close to automatic fuse limits, you will need a "slow" type auto fuse or use a larger capasity outlet. This the first thing to check before looking further at the splitter itself, assuming that it is the fuse of your outlet that you blew?.
Jul 14, 2011 | McCulloch 4 Ton Electric Log Splitter #...
I have a 4052 mcCulloch 4 ton log splitter. What kind of oil does it take for the hydraulics
Not having a mcCULLOCH manual I dont know what they reccomend,but on mine I just use HI grade industrial/commercial hydraulic fluid. I have been using this for 15 years and have had no trouble. I change oil and filter every year. Thank you.
Nov 06, 2010 | McCulloch 4 Ton Electric Log Splitter #...
Garden Logo
270 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
