Question about Briggs Garden
I am looking for installation instructions for part number 192931 (kit9ampreg)
This repair kit to prevent the voltage spike to the coil to eliminate failure. This is for a Murray Riding lawnmower, Briggs and Stratton motor.
  • 15 Answers
SOURCE: briggs and stratton lawnmower 4horse power engine needegap specs on coil and points
That's easy man! You will always hear, "You sir, need to gap this or that at EXACTLY .00071542 inches per square meter".
The actual "poor boy fix"-
Put your magneto back on there, and stick a business card from your wallet in between it and the rotor. Let the magneto pull itself to it, you center it, and give it just a hair of breathing room (to slide the card back out). Tighten 'er down, and you got it.
1.- If you can't pull the card out, it is too tight.
2.- If you pull the card out easily, too loose.
3.- JUST enough to pull it out, and have it drag just a bit on the way out is JUST ENOUGH!
Remember, on 4-strokes, they ARE forgiving, and can do miracles even if you try your best to destroy them.
Posted on May 30, 2009
mowerman1857
  • 389 Answers
SOURCE: murray 42'' riding lawnmower owners manual
www.murray.com
Locate the tag with your model and serial number on the tractor. Be sure you get the number EXACT or it won't work.
Go to Murray's website and download it. They usually have parts listings at the back of the Owner's Manual
Posted on Oct 04, 2009
  • 583 Answers
SOURCE: Briggs & Stratton Briggs Stratton Intek V -
these are common for doing this ,if you dont want to pull it down and hone the cyl. then i would use a heavier oil say 20w/50and that will probabley solve your problem
Posted on Oct 25, 2009
  • 24 Answers
SOURCE: I need a wiring diagram
This wiring diagram is from a 15HP but it should be the same as your engine.
Posted on Jul 12, 2011
BAMOUT
  • 2478 Answers
SOURCE: how to change oil for briggs and stratton lawnmower
There a plug on right side of engine close to bottom. Remove it
to drain old oil.
Posted on Nov 23, 2012
Balance shaft repair replace on PT Cruiser
the balance shafts may be out of balance
if guides and chain worn or
some work was done wrong during a timing chain and guide replacement
to get to them ....lots of work
balance shafts are lower part of engine block
number 6 in picture one
front parts of the motor has to be removed
same job as a timing chain and cog kit replacement
I prefer balance shaft elimination option myself
balance shaft elimination kits are available for that motor
elimination kit
Nov 02, 2016 | Cars & Trucks
My tv looks like 3d how do i fix on my own
install a convergence repair kit most models use the Sony convergence repair kit number 1 from www.tvrepairworld.com which has the parts and the CD with instructions.
Oct 20, 2011 | Sony KP-65WS510 65" Rear Projection...
I have a senco coil roof nailer that all of a sudden is leaking air big time and will not coil and fire nails. What parts do I need to replace.
depends on where the air is leaking from. If you go to senco.com and type in your model number you can look at a breakdown and they will list the rebuild kits specific to the leakage, they make an upper o ring kit and a lower kit for this problem. Let me know if you need more assistance or where the air is leaking along with the model number and I will find a number for the rebuild kit. Also the senco kits have detailed instructions on how to install them.
Apr 04, 2011 | Senco Tools & Hardware - Others
The coil keeps burning up on the motor
If you are referring to the ignition coil, that is generally a sign that "voltage" is being applied "to it". Not sure if anyone has been messing with the wiring, changed an ignition switch, etc. There is a single "ground" wire that hooks to a spade terminal on the coil. This is for grounding only, if something gets crossed and battery voltage goes to this terminal it will blow the coil about as fast as you turn the key. Hope this helps.
Feb 25, 2011 | Mtd Garden
I Have a Maytag MAH7500AWW one of the MOV component on the mother board burned and the machine does'nt work anymore. I'm looking for the replacement piece but nobody has it around here, they all told me...
An MOV is a "metal oxide varistor". This is a very common heart of a surge suppressor, which can be used "across the line wires" to prevent harmful voltage spikes from adversely affecting equipment. Most of the time however, an MOV will sit idle in a circuit for years, then one day, it gives its life blocking a voltage spike. You use the equipment the next day like nothing happened. Everything works fine - until the next voltage spike.
Your MOV has already activated, and is no longer able to provide the protection it once had. As a result, the next voltage spike passes unobstructed by the failed MOV into the circuit ruining the circuit.
The problem is that the MOV never told you it failed. Many times, a number of MOVs are installed all at once - each one fails at each subsequent voltage spike. It could take years, decades or more before the last MOV fails - likely long after the warranty is over.
You can probably see that the failed 50 cent MOV isn't the problem any more. It was *before* the circuit failed, but you never knew it had failed. Now, the latest voltage spike fried the circuit and it will require wholesale circuit board replacement or labor intensive troubleshooting to locate and replace all the failed parts on the circuit board.
You're better off buying a used board or an entire used machine until you can fix this one.
I hope this helped you understand about MOVs, and that replacing this part will not restore the machine to working order.
Sep 09, 2010 | Washing Machines
Picture faded model number is fp4620w103
This sounds like the coolant fluid needs to be changed - the coolant turns milky after awhile and you'll get a dull image.
Google TV repair world . com and look for philips/magnavox coolant replacement:
PHILLIPS CRT Coolant Replacement Kit This is the complete coolant kit for Phillips CRT rear projection televisions. Kit contains 48oz of top quality High purity optical grade coolant with complete detailed instructions produced in clear easy to understand terms with detailed photos and illustrations that takes you through the process step by step safely dischargeing the CRTs and eliminating the need for complete realigning proceedures.Restores the vibrant colors and focus issues commonly associated with coolant that needs replacement
Oct 18, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
HP6150 - won't turn on after the last thunderstorm. It's not a circuit breaker or GFCI problem. Power cord has a green light, which is on.
Lightening does hit power lines, and cause voltage spikes; these voltage spikes do burn out electronic equipment. Surge protectors are used to prevent these voltage spikes from burning out electronics
Jun 11, 2009 | HP Photosmart C6100 All-In-One Printer
Coils keep burning out on 12.5 hp briggs &
Hello:
>>Have you Replaced the Coil with a New One?
>>If No, then Replace the COil and your Problem will be Corrected. The Ign Mosule inside the Coil is Heating Up and Shorting Out. This Causes the No Fire when Hot Problem.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 15, 2009 | Garden
Amplifier blowing
Looking up South African voltages, they vary from 220 - 250 volts at 50 cycles.
You probably also have voltage spikes from sudden load changes within the complex (air conditioners, washing machines, dryers, etc.
I suggest your complex invest in a good voltage regulator transformer. It should not need to be rated more than about 500 watts. I would guess the cost to be about $150-200 USD.
If this is more than you want to spend, try a spike suppressor, power strip first.
Feb 11, 2008 | Televison & Video
Garden Logo
64 people viewed this question
Top Briggs Garden Experts
Mike
Matt Olenzek
Matt Olenzek
Are you a Briggs Garden Expert? Answer questions, earn points and help others
