Question about Ovens
Hi, my eoc 69400x won't heat up on fan or conventional modes. Grill is fine. Is it the element?
5 Suggested Answers
  • 1462 Answers
SOURCE: oven no heat
for king louie
fault is the circular element round the fan. take off the back plate inside the oven and you can often see the damage but not always. to get at the terminals, remove the rear cover and test for continuity across the element with a multimeter - remove any connections before doing this and note down where they go
for tarzantony.
i can't remember where the cutout is but probably on top of the oven or close to the fan on bthe back. just trace the wiring from the element and it should lead you to it
Posted on Jul 06, 2008
  • 190 Answers
SOURCE: Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Posted on Jul 09, 2008
    • 250 Answers
    SOURCE: When the oven is turned on the lights and fan
    Sounds like the element, its thermal fuse, or relay/contactor is not functioning. You should check those, or have a professional do it if you're not comfortable with that.
    Posted on Dec 02, 2010
    • 1711 Answers
    SOURCE: My oven does not heat up when in fan oven mode,
    From your descritpion and if you already replace elements there are two options.
    One is that there is an open curcuit either by a loose contact from selector switch to the elements this can be check with a mutlimeter.
    The second option the selector switch itself is mulfuction and this normal after long time use since it consist with power contacts they fail to conect after long and you will need to replace it. If your familiar with electric then you can check it with power on and multimeter to see if it conects the elements or not. This operation need extra extra safety and experience.
    We have here one side just to see what part you need the cooker selector multifaction switch
    Posted on Aug 25, 2011
    When the oven is turned on the lights and fan activate but the rear element does not heat up. When turned all the way to conventional grill mode the grill element operates correctly.
    Dec 02, 2010 | Ovens
    Hotpoint sy36x grill element works fine but when switched on to oven it doesnt heat up, fan working.
    it seems to me that it is a fan oven and the top element won't heat up you need a new fan oven element. it is a round element that sits behind the back grill surrounding the fan...
    richard saupe
    appliance repairman
    Mar 14, 2010 | Hotpoint SY36 Style Line Stainless Steel...
    My oven is a la germania f6 50 l2x i want to know the meaning of the symbols on my oven
    Oven functions
    Oven light.
    Upper and lower heating elements.
    (Conventional cooking).
    Upper and lower heating elements with fan.
    (Fan assisted cooking).
    Lower heating element with fan.
    Inner grill heating element.
    (Radiant grill).
    Full grill heating element with fan.
    (Fan grill)
    Rear circular heating element with fan.
    (Fan forced cooking).
    Oct 10, 2009 | Ovens
    Not heating in fan forced mode
    Possibly your fan element has blown. Try and take the cover off that coves the fan inside the oven itself and use a torch to look at the element to see if it looks out of shape etc.
    Jun 15, 2009 | Fisher and Paykel OS302SS, Stainless Steel...
    Oven no heat
    check fan element hasnt blown remove back plate in oven after switching off from mains of course and remove the retaining screws and you will see a fan and around that the element it will be obvious to see if its blown as there will be a hole on the casing if so replace and viola.
    Jan 16, 2008 | Neff B1641 Single circotherm super...
    Ovens Logo
    22 people viewed this question
    Top Ovens Experts
    Dan Webster
    Dan Webster
    Are you an Oven Expert? Answer questions, earn points and help others
