Question about Water Heaters
WX-203 146S30, 32 Gal WELL-X-TROL Well Tank Stand low pressure upstairs
  • 258 Answers
There is a schraeder valve at the top of the tank. Check the air pressure with a tire gauge. It should be two psi lower that the cut in pressure. eg: If you have a 40/60 pressure switch, the tank should read 38 psi.If it is lower, charge it up with air. If it loses the air again, the tank needs to be replaced. The gauge at the tank is rarely accurate so I would an outside sillcock pressure gauge to determine your system pressure so you can set the tank pressure properly. Good luck!
Posted on May 08, 2017
Water not going into well water tank
Water that goes in to this tank comes straight from pump, check the foot valve on your well might be bleed water back into well. Also check the air bladder on the tank. Make sure it has proper inflation
Aug 23, 2014 | Amtrol WX-302 WX-302 150S1, 86 Gal...
Is the pump running when power is ON?
Put ear against pipe and listen for pump.
Have you installed a check valve?
Check vlave lets water pass through the pipe and enter tank, but the valve closes after pump shuts off and keeps water from falling back down into well.
My AMTROL water well tank is copying the pressure of the prussure switch
Sand the points on the pressure switch
Replace pressure switch
Test you are getting 240Volt to pressure switch
Turn breaker fully off and then fully back on
Replace control box or replace start capacitor:
Drain tank, and replace the air valve
Aug 22, 2014 | Amtrol WX-302 WX-302 150S1, 86 Gal...
Loud banging noise Amtrol WX-203
either solenoid valve is closing or there is a large water hammer occurring
Apr 18, 2014 | Amtrol WX-203 Well-X-Trol Stand Well Water...
Water came out of air valve when I went to check pressure
Tank is waterlogged.
Drain tank, install new air release valve
Sep 17, 2013 | Amtrol WX-203 Well-X-Trol Stand Well Water...
Water pressure decreases as the water runs
Probably a clog in galvanized pipe.
Expansion tank is not whole-house pressure regulating tank. It is localized protection for plumbing exposed to high pressure caused by very hot water.
If you house has pressure regulating valve, then that can be a cause.
For low water pressure in household, the following link might help:
Aug 07, 2011 | Amtrol ST-12-C THERM-X-TROL ASME Expansion...
I am loosing water pressure in my shower so I checked pressure at my ST-12 Therm-X-Trol tank hoping it would be 40 but water comes out of the test point and if you tap the tank it feels like it is full of...
you are correct....the rubber bladder inside the tank has leaked by and filled the expansion tank. it will need to be replaced and you also may find boiler or water heater relief valves may blow off until its replaced
Oct 21, 2010 | Amtrol ST-5-C THERM-X-TROL ASME Expansion...
Water Heaters Logo
81 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
