Question about Water Water Heaters
WX-203 (146S30), 32 Gal WELL-X-TROL Well Tank (Stand) i want to make sure that its the correct pressure between 30 = 35. Our water pressure in low upstairs
  • 252 Answers
SOURCE: adjusting pressure tank set at 48 lbs and pressure
Pressure tank should be charged to 2 pounds less than your lowest pressure (ie28psi). Must be set with system under no (0) pressure.
Posted on May 19, 2009
gary1121
  • 332 Answers
SOURCE: can a insinkerator hot1 be hooked into a low
there shouldn't be a proble it actually would work less if you are getting low pressure,, but how did you come to the conclusion that it is low pressure,, do yo have a guage, you should not loose that much pressure on any fixture
Posted on Jun 06, 2009
  • 4 Answers
SOURCE: I am loosing water pressure in my shower so I
you are correct....the rubber bladder inside the tank has leaked by and filled the expansion tank. it will need to be replaced and you also may find boiler or water heater relief valves may blow off until its replaced
Posted on Oct 21, 2010
heatman101
  • 43501 Answers
SOURCE: I replaced cpvs after freeze.
The most likely thing in the kitchen sink is that the aereator on the end of the faucet is plugged....take it off and see if you have at least cold water pressure...
As far as the hot water goes...there is dirt either caught in a valve or in the heat check on the hot water heaters... many hot water heaters have ball checks built in to them and the smaller hole can become clogged with dirt...the freeze likely released a bunch of junk into you system...
heatman101
Posted on Dec 17, 2010
SOURCE: rheemglas fury model # 41V50
I have a 50 gl rheem the pilot it doesn't stay lite.
Posted on Jul 21, 2011
WX-203 146S30, 32 Gal WELL-X-TROL Well Tank Stand low pressure upstairs
There is a schraeder valve at the top of the tank. Check the air pressure with a tire gauge. It should be two psi lower that the cut in pressure. eg: If you have a 40/60 pressure switch, the tank should read 38 psi.If it is lower, charge it up with air. If it loses the air again, the tank needs to be replaced. The gauge at the tank is rarely accurate so I would an outside sillcock pressure gauge to determine your system pressure so you can set the tank pressure properly. Good luck!
Apr 25, 2017 | Water Heaters
How can I tell if pressure pump is bad or if I have water leak.
pump is producing pressure so it is ok
loosing pressure indicate pipes leaking or non return valve leaking
Feb 21, 2018 | Amtrol WX-203 WX-203 146S30, 32 Gal...
Water not going into well water tank
Water that goes in to this tank comes straight from pump, check the foot valve on your well might be bleed water back into well. Also check the air bladder on the tank. Make sure it has proper inflation
Aug 23, 2014 | Amtrol WX-302 WX-302 150S1, 86 Gal...
Is the pump running when power is ON?
Put ear against pipe and listen for pump.
Have you installed a check valve?
Check vlave lets water pass through the pipe and enter tank, but the valve closes after pump shuts off and keeps water from falling back down into well.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
My AMTROL water well tank is copying the pressure of the prussure switch
Sand the points on the pressure switch
Replace pressure switch
http://www.amazon.com/dp/B000BQSERE/?tag=waterheaterti-20
Test you are getting 240Volt to pressure switch
Turn breaker fully off and then fully back on
Replace control box or replace start capacitor:
http://www.amazon.com/dp/B0060C7GFO/?tag=waterheaterti-20
Drain tank, and replace the air valve
http://www.amazon.com/dp/B000BQYKJK/?tag=waterheaterti-20
Gene
Aug 22, 2014 | Amtrol WX-302 WX-302 150S1, 86 Gal...
Loud banging noise Amtrol WX-203
either solenoid valve is closing or there is a large water hammer occurring
Apr 18, 2014 | Amtrol WX-203 Well-X-Trol Stand Well Water...
Water came out of air valve when I went to check pressure
Tank is waterlogged.
Drain tank, install new air release valve
Sep 17, 2013 | Amtrol WX-203 Well-X-Trol Stand Well Water...
Water pressure decreases as the water runs
Probably a clog in galvanized pipe.
Expansion tank is not whole-house pressure regulating tank. It is localized protection for plumbing exposed to high pressure caused by very hot water.
If you house has pressure regulating valve, then that can be a cause.
For low water pressure in household, the following link might help:
http://waterheatertimer.org/Low-hot-water-pressure.html
Aug 07, 2011 | Amtrol ST-12-C THERM-X-TROL ASME Expansion...
I am loosing water pressure in my shower so I checked pressure at my ST-12 Therm-X-Trol tank hoping it would be 40 but water comes out of the test point and if you tap the tank it feels like it is full of...
Oct 21, 2010 | Amtrol ST-5-C THERM-X-TROL ASME Expansion...
Water Heaters Logo
Top Water Heaters Experts
vince
80stech
D. E. Hev
Are you a Water Heater Expert? Answer questions, earn points and help others
