Question about The Office Equipment & Supplies
All the lights on the right side are on. What dose this mean?
The number 1,1 1/2, 2, and 3 are on and there is a humming sound coming from the typewriter
MicrowaveSvc
  • 9085 Answers
SOURCE: MICROWAVE NOT WORKING PROPERLY
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
Let us know if the hard reset does not fix it.
Otherwise, it sounds like a bad door switch or door switch mount.
Posted on Aug 21, 2008
  • 3594 Answers
SOURCE: Wheelwriter 2
1 &2 lights blinking indicate bad keyboard, Check the ribbon connectors on the keyboard, if they are OK see my tip under WW1000
DickyO
Posted on Oct 31, 2008
  • 3594 Answers
SOURCE: Beeps and Flashing Lights
It sounds like a keyboard but you didn't give a make or model, if it is an IBM Wheelwriter see my tip under WW 1000
DickyO
Posted on Nov 25, 2008
roy7777
  • 109 Answers
SOURCE: a dashboard light
IT SOUNDS LIKE NOT A PROBLEM IT IS AN UNUSED CIRCUT AND THE SLUG PROBALLY FELL OUT
Posted on Apr 12, 2009
  • 3594 Answers
SOURCE: Lights stay lit.
Do all the lights stay on? if so it's not completing the power on reset. Try this remove the batteries turn the T/W off for 30 sec., Restart.
THE MEMORY WILL BE CLEARED!!
DickyO
Posted on Apr 12, 2010
The tcl light comes my dash what's dose mean ?
That would be the "traction control light". There are a couple of times you could see it. When you first start your car, when you push the TCL button or when there is a problem with it. You should take it to a qualified machanic and have it checked out or you can verify what I have told you in your owners manual and then take it to a qualified mechanic.
Apr 12, 2015 | Cars & Trucks
Humming noise coming from my 1994 cadillac deville especially during the hotter months
Late model Cadillac Deville's and Seville's may experience a humming noise in the passenger compartment when the heater is on high and the blower is set on a medium to high speed.
GM has determined that the most likely cause of the humming noise is from the positioning of the blower motor within the HVAC housing, causing a restriction of the incoming airflow. (GM TSB 03-01-37-001)
The recommended repair for this symptom is to reposition the blower motor.
1. Remove the right side sound insulator.
2. Loosen the three blower motor retainer bolts. (Do not remove bolts)
3. Shift motor as far as allowed toward the vent tube.
4. Re-tighten the retainer bolts.
5. Re-install right side sound insulator.
Jun 11, 2010 | 1994 Cadillac DeVille
NOT a 4wheel drive...same sound and hubs/rotors are newish
sounds like a wheel bearing but to be sure jack up the truck and wiggle the tire from top to bottom if it moves then it is a wheel bearing
Aug 03, 2009 | 2005 Ford F-150
MY LG fridge model GR- M562 YLY
If you pull frig out from the wall, so that you can get behind it you will see a diagram with information on it. It states what happens with what test.
TEST1-All display lights come on
TEST2-Number 22 22 appears
TEST3-Number 33 33 appears
I have a question is your frig making a loud humming sound or a screach. If so it means that the fans need replacing.
Jul 21, 2009 | LG LRTBC1825T Top Freezer Refrigerator
Humming on drivers side
Does it sound at all like a fan? My Honda will auto start a fan that continues to cool the engine after I come to a stop as well. Is it possible you might be hearing the same thing?
Jul 20, 2009 | 1997 Honda Accord
A dashboard light
Apr 10, 2009 | 1996 Volvo 850
Hum in sound volume
It could be a few things. The first thing you want to look at is make sure that the microphone is muted in the mixer controls of your audio cards. These settings are located in the control panel. If you need the mic, look under the advanced settings under it and disable the 20 db option for it.
If that doesn't work I have a few other ideas.
Mar 17, 2009 | Proscan 32LB30QD 32 in. LCD TV
Poor sound quality
Hi, I sent an email regarding the issue to OnCorpus (the company who makes ProScan)
This is what I got back:
Thomas,
Follow these steps to correct humming issue:
1. Turn tv on
2. Input mode should be tv
3. Turn volume to zero
4. With remote enter 9 8 7 6
5. A menu will appear on left side
6. Arrow down to backlight and with right arrow key move number from 81 to 83, press menu button twice,
7. Turn up volume and listen if hum is gone.
John
jd@oncorpus.com
I can't confirm if this works at this moment since I don't have access to my TV.
Thomas
Feb 11, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Aug 20, 2008 | Daewoo Microwave Ovens
Top The Office Equipment & Supplies Experts
James Cagle
James Cagle
Gareth Cockram
Gareth Cockram
Peter March
Peter March
Level 1 Expert
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
