Question about Garden
I need a wiring for a kohler cv20s, i am putting it on a tail mower and all i need is starter and charging hooked up
boscia
  • 163 Answers
SOURCE: charging wireing diagram on craftman 42'' riding lawn mower 19.5'' briggs motor
the charging system runsfrom a stator which is underneath the flywheel and runs to a rectifier/regulator module and to the battery. it will power the blades if it is an electric clutch system and also the fuel plunger system on the carbuerator
Posted on Nov 30, 2008
  • 148 Answers
SOURCE: fuel gas cap craftsman 2902202221 model cv20s
If you are looking for a fuel cap go to www.searspartsdirect.com.
Posted on Aug 20, 2009
wadembly
  • 513 Answers
SOURCE: The battery is not charging from the lawn mower,
they have a stater that usually sits under flywheel for the charging system
Posted on Jun 28, 2010
  • 146 Answers
SOURCE: how can I test a riding mower regulator? (puts out
Simplest test is to leave it on the engine, battery hooked up normally. Run the engine at normal full speed (not just idling) and use your voltmeter to measure the voltage across the battery with your DMM. If you measure 13.5 to 14 volts, your rectifier/regulator is probably OK.
It can't easily be tested off the mower. You'd need a source of AC at 24 volts to simulate the motor's stator winding, and a load that draws about 23 amps at 12 volts.
Don't forget a bad battery can cause failure to charge - it's not always the regulator.
Posted on Jul 16, 2010
  • 41 Answers
SOURCE: Have a Husqvarna model 968999102
The starter should have two wires, a power and a ground. The power you can splice to the power wire coming from the battery. The other wire needs to be grounded to a bare metal part. Usually just installing it under an existing bolt works fine. Just be sure to clean the spot with a wire brush and a rag so it gets a good clean connection.
Posted on Mar 03, 2011
Starter kicks in but wont turn engine acts like too much compression,battery is fully charged
Very can be if it is an OHV engine that either the valves are needing adjusting or the decompressor has failed.
Most 4 cycle small mower engines have decompressors to help with the starting, These are only active at start-up and does not effect normal engine compression when running.
May 18, 2015 | Cub Cadet Riding Lawn Garden Tractor 25hp...
How do I wire a 18hp Briggs & Stratton engine to a craftsman GT5000 lawn mower
I dont have all your anwers. In my experience, Kohler frequently has wires to start, run and stop the engine. They also frequently have a low oil and/or high heat control (engine shut down). Also expect a wire from the charging system. On your tractor, you probably have similar plus 'operator presence' wires. These wires require to you to be sitting in the seat for the machine to operate - a seat switch for example. On my tractor, I can depress the 'brake' (which isnt exactly a brake in fact) and the engine will run when I dismount. However, if the mower is engaged, no matter what, if I get off the tractor, the engine shuts down.
You will have to determine what every wire is for and connect it properly. You may lose some engine 'functionality' or tractor safety features. It is never easy to put a Ford starter on a Chevy. Good luck with your project.
Thanks for your interest in FixYa.com
Dec 02, 2012 | Garden
How do I connect wiring on Kohler CV16S motor to craftsman mower that had a B&S YBSXS.7242VFmotor?
You need to know which ones are the kill wire, charge wire and starting wire for both side of the harness and make you own connector.
Dec 06, 2017 | Garden
Have a Husqvarna model 968999102 walk behind mower. having to change engines and putting on a Kohler with a starter. I need to know how to wire up the starter since the old engine did not have one. I have...
Mar 03, 2011 | Husqvarna Garden
18hp kohler engine (grasshopper) won't start. Single click from starter/solenoid when key turned. Battery new/charged.
I have a duetz-allis mower with 18hp. kohler eng. won't start, have new seloniod, new circuit breaker, getting fire to switch & out. Still won'tstart
Aug 04, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Fuel gas cap craftsman 2902202221 model cv20s kohler pro
Aug 14, 2009 | Craftsman Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
