Question about Samsung Televison & Video
Our Samsung flat screens picture looks like X-rays. Some pictures are worse than others. Picture is only thing that's effected. Is tv going out or can it be fixed
  • 56 Answers
Replace tcon board.
Posted on Apr 26, 2017
I have a 40inch Samsung le40r88bd that keeps flickering and is getting worse is there an easy fix?
EASY How to Fix Samsung LCD TV Flashing Flickering ...
? 3:43
https://www.youtube.com/watch?v=i-jQZ-TQdgU
Jun 4, 2012 - Uploaded by Tampatec
How to Fix Samsung TV Flickering Blinks Flashing Flat Screen Picture EASY most common way MODEL ...
Flickering picture
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsMar 13, 2013 - A flickering picture on your TV can be caused by the following conditions: Television settings; Incoming signal issues; Electronic interference ...
How to fix Samsung LN46C630 screen flickering issue
Jan 16, 2016 | Samsung Televison & Video
What do you think is wrong with my television, it has sound but no picture. How can I fix the problem?
Hi there
I would go to menu on the remote , from there to picture go down the list, if you do not find anything there to help you. Go to Support and to the E manual .
26053790-x3zeawgeewbvgdzeyuixqaom-4-0.jpeg Kolbrun
Jan 14, 2016 | Samsung LN52C530 52" LCD TV
Samsung flat screen tv no picture sound only, I have checked all connections and remote still same problem.
The T con board is faulty. It is the board with flat ribbon cables going to the bottom of the screen. It is not hard to replace this board. You can get one from here:
TV Parts Universal TV Stands DLP Chips ShopJimmy
Jan 01, 2016 | Samsung Televison & Video
My samsung LN-S2651D Comes on with perfect picture then after 5 minutes or so picture strarts to get white snow going down the screen
Tuner fault. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts there.
Mar 24, 2014 | Samsung LN-S2651D 26 in. LCD Television
Picture doesn't fit the screen
Its a function of the source and the tv picture settings. Go to the source (direct tv, cable, co-ax?) menu , settings and look for screen display sizes.
Your remote has a red dot "wide" button which will also have a screen size effect. You can cycle through the formats
For further info why not read/print out the manual?
http://store.vizio.com/documents/downloads/hdtv/L32/Manual.pdf
Mar 19, 2014 | Vizio L32 32 in. LCD HDTV
Best picture settings
Hav a samsung ps51d495 if ya remotes same try these two things hold down the return button and popup comes up diagnosis sreen may do on yours 2nd one hold down the exit button and a popup come up sayin rest thing come up or go to ya menu do factory rest
Jan 03, 2014 | Samsung PS50Q97HDX 50 in. Plasma TV
Why is the picture bigger than the screen?
Check the picture settings. If picture is zoomed, the effect will be like this.
Mar 21, 2013 | Vizio M550NV 55 in LCD HDTV
I have a new 40" Samsung 120 tv and blu ray player. when playing movies the picture has the soap opera effect. I have turned of the auto motion plus and the picture still looks terrible. What else can I...
You didnt specify what type of samsung TV you have but the are picture presets for most of the ones i have come across, they are named in this format Dynamic, Cool, Smooth etc, they are presets so you can select the closest to the effect you want and then from there fine tune the picture with the brightness, contrast options, Hope this helps...
Oct 26, 2010 | Samsung Televison & Video
I have a Samsung LN46C650 and sometimes the picture goes black and the audio cuts out for a second or two. It occurs at least once a day but it happens at random so I cannot duplicate the situation. I'm...
I have the same problem. At first the tv would just blink occassionaly and the sound would cut out just like yours. We realized if we turned the tv off then back on, it would be fine. Well, that's not working anymore, and as opposed to a blink, the tv picture is cutting off all together, can't imagine it will do anything but get worse. I called Samsung about another problem I had with the tv, the autofit screen size selectioon was great, however over time, on some channels there got to be a progressivley larger white line at the top of the screen. At first we could adjust the picture up to completely close the line. Now it is too large to cover up. Samsung said, "that's normal."....progressively worse performance?
Sep 06, 2010 | Samsung LN-T4665F 46 in. LCD Television
Samsung le40a lcd - picture quality
Hi - I have some suggestions. The following factors effect picture quality:
1. Source (because LCD TVs have much higher picture quality than traditional CRT "Tube" TVs, the worse your source material, the worse it looks on a LCD TV).
DVD and Sky/Digital TV should look excellent on this TV when connected with a good quality Scart lead (nothing too expensive, but a Oxygen Free Copper Gold lead may help) directly into one of the TV's Scart inputs (avoid using "switching" boxes for multiple equipment).
Also, bear in mind that this is a HUGE screen (40 inches I think) and will REALLY show up bad source material.
The best advice I can give is, if you have HD-ready equipment use HDMI connections for everything (ideally with an HD-uplscaling DVD player which will "improve" the quality of standard DVDs on the TV - I recommend models by Philips) and check that you are in "Movie" or "Cinema" mode on the TV.
Make sure that all of your equipment, like your Sky digibox, is set to 16:9 mode (not 4:3) aswell to preserve the true widescreen aspect ratio.
Hope that helps!
Dec 31, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Televison & Video Logo
Henry  Thomas
Henry Thomas
