SOURCE: Ice maker water wont shut off continues to run even when tray is full
The ice maker water fill solenoid may be leaking by and needs to be replaced. If you disconnect the water line from the solenoid and you see it continues to flow water then that valve is not seating properly. Another slight possiblility is the ice maker motor module gear is stuck in the fill position. See the attached link for a diagram. If the geared wheel just happens to get stopped in the "fill" position it will fill with full force water. If there is only a trickle of water then the soleinoid valve is the more likely source of the problem. http://www.partselect.com/Schematics/Maytag/AA56-20.gif http://www.partselect.com/Schematics/Maytag/AA56-16.gif
SOURCE: Ice Maker water keeps running
Bad I/M, won't shut off after harvest and continues to restart cycle. Heater in I/M should warm up thermostat after first harvest and stop unit from recycling.
SOURCE: ice maker continualy runs even when ice tray is full
theres aproblem here, I dontquestion that your hearing something operating, but if the valve is being activated, its going to fill with water( thats what it does!) so if your not geting water every few minutes something else is"buzzing"i would look elsewhere fro your problem doesnt sound like the valve
SOURCE: Ice maker won't shut off when full
check the Shutoff Arm:
An arm extends away from the ice maker over the ice cube bin. During each ice making cycle, the arm rises up and then drops back down after the new ice is dumped into the ice cube bin. As ice accumulates in the bin it prevents the arm from dropping back down. When the arm is high enough, the ice maker shuts off and no more ice is made until the ice level in the bin drops.
The ice maker can also be turned off manually by lifting the arm all the way up into a locked position (shown below
The arm is supported at one or both ends. One end extends into the back of the front support (see photo above). If it is not securely in place, it could cause the ice maker to malfunction. Confirm that the arm is securely in place.
For proper operation, confirm that arm is in the lowered position and that nothing is blocking it from normal movement.
To test the shutoff function, lift the arm up into the manual shutoff position. Recheck the unit later to confirm that no ice is being made.
If unit continues making ice even when the shutoff arm is in the up (off) position, refer to the diagnostic table or for a modular ice maker, replace the control module.
check the Shutoff Switch:
Before testing the shutoff switch, unplug the refrigerator to avoid an electrical shock hazard.
There are two types of ice makers, those in which all of the parts can be individually replaced and those in which some of the parts are clustered together into a control module. To determine which model you have remove the outer face plate. If there is knob, pull it off first, then pry off the face plate with a small screwdriver.
Modular units have holes in the module's face plate for test probes. If you see several holes, each marked with a letter, it is a modular unit. Component units (like the one shown below) usually have exposed gears and don't have holes for test probes.
Modular units do not use a separate shutoff switch. Instead follow this link to view instructions for checking the shut off arm.
SOURCE: ICE MAKER MOTOR RUNS CONSTANTLY AND WONT' TURN OFF ICE IS FULL
You can take the cover off of the icemaker and with a pair of needle nose plires take off the dile and clean with an eraser. You probly can see the problem when you get the dile off. Let me know if that is works. Has worked for me in the past.
