Question about Zeiss Cameras
Zeiss tenax Do I need special tools to take the camera apart. The take up is not working, or the shutter release, the button that takes the photo.
  • Zeiss Master
  • 5,412 Answers
For a vintage camera such as this, I would suggest a specialist repair facility, not a DIY repair.
Posted on Apr 25, 2017
For use on a non-Hasselblad camera, can I use the aperture preview button (which locks) to set aperture?
There is no communications between the camera and lens. When using a set up like this everything becomes manual and you must remember to stop down the aperture to your taking aperture before releasing the shutter. I don't know what camera or format you are going to use this lens with but assuming it is a digital "bridge" (a camera that is between an amateur and a pro) or a professional the sequence would be the same.
To view, focus and compose the lens would be set in this case F2, to select the correct light meter reading the lens is set (stopped) down to the taking aperture. The modes I've used for this have been mostly manual but lately I found that "AV" worked equally well and the camera metered to the proper exposure. Most times the camera was mounted on a tripod and the shutter was released with a electronic shutter release.
Sequence for taking a photo for me anyway was/is (with the camera mounted on a tripod) focus, compose, stop down to taking aperture, check metering and release the shutter if in AV mode or manual mode to set the shutter speed and release the shutter.
You will find that all makes of digital cameras will function differently so what sequence works for one won't work on others. This meaning I have had digital cameras that wouldn't meter through anything other then the lenses meant specifically for them.
Problems that I've had. Forgetting to stop down to taking aperture (like Duh), not fine focusing (manual), not trusting the in focus indicator, forgetting that the viewfinder is/was only 94% of the scene. Once a little time has been spent with a lens set up like this the rewards are far beyond the trivial annoyances. Have fun with it
Jan 12, 2011 | Hasselblad 110mm f/2 FE Zeiss Plannar Lens
My Nikon Coolpix L3 takes a good few seconds to take a photo. By the time the camera takes a photo the moment is gone. I'm sure it wasnt always like this. Can you help?
This is a common situation with most compact point&shoot cameras. This "shutter lag" is because the camera has to do so much work when you press the shutter release button: focus on the subject, meter the light for proper exposure, and switch the electronics from viewing on the LCD to recording to memory. Larger (and more expensive) cameras have additional hardware to reduce this lag.
You can reduce the lag somewhat by anticipating the action. Press the shutter release button halfway to focus and meter. Keep it pressed halfway until the right moment, then press it the rest of the way to take the picture.
Jan 08, 2011 | Nikon COOLPIX L3 Digital Camera
I have turned camera on and set up to take a photo and the shutter release button will not press in to take the photo. I used the camera yesterday and it worked fine!
Turn the camera on and look into the view finder while you try to press the shutter button. Check the information in the view finder to see whether you are getting an error message. If you see an error message in the view finder, remove the lens cap and proceed to take a photograph but, instead of pressing the shutter button this time, press the button near the top of the camera on the back which says "AF/AE. If the camera takes the photo it means you have somehow initiated the auto focus/auto exposure lock which the camera will not override when attempting to take a photo using the shutter button. When you use the AF/AE button, you override this system. To remedy this issue, when you get the error message try pressing the shutter button again. Also, remove the lens to see if the shutter inside has frozen in the "locked" position. If you find this to be the case you will need to contact Nikon Customer Support. The link for Nikon Support is below. The numbers are half-way down the page.
Oct 31, 2010 | Nikon D40x Digital Camera
How do I load a film into my Zeiss Tenax 11 camera (diagram would be nice)
Turn the bottom buttom (the A-Z one) to where the lines line up and push the button to the side a bit. Then slide the whole back downward,NOW YOU CAN TAKE THE OLD FILM OUT AND LOAD THE NEW ONE....
Oct 05, 2010 | Photography
The shutter release button will not fire. every once in a while it will shoot but most of the time it does not release and take the photo.
The most obvious cause is a failing battery. Your camera has a magnetic shutter release which needs a good battery to work. A tired battery will have a marginal voltage which might not always be adequate to release the shutter. Change the battery to see if there is an improvement, you should use 1 x 4SR44 cell.
If that fails, you may have a dirty shutter magnet but it's rare on the AE-1. If the battery doesn't fix your fault then please report back for guidance regarding shutter magnet maintenance.
Please take a moment to rate my reply.
Sep 19, 2010 | Canon EOS-AE-1 35mm SLR Camera
Re. Contax 167MT problem -- When the depth of field button is pressed the lens does not close down to the set aperture. Also when the shutter release button is pressed the lens does not close down. My two...
The 80s 167MT uses good old fashioned mechanical links between the camera body and lens. Remove the lens, and press the depth of field button. If you don't see the lever that connects the aperture control from in the camera body to the lens move, then something's obviouly broken in the camera body.
Nov 11, 2017 | Contax 167 MT 35mm SLR Camera
Shutter button on my digital rebel xt stopped working. I can press down far enough (halfway) to get it to focus but then it won't click all the way down and release. For several months before this final...
I know it sounds expensive but at least you know Canon will fix it properly with a limited warranty on the repair. Remember, they have to take the camera completely apart to reach that part. If you're interested in seeing how complicated it is, google the words...disassemble a digital camera.
Dec 08, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Cannot open Zeiss Icon Tenax camera. Please tell me how to do this.
I think this camera actually has a back that is a separate piece. It is removed by turning 2 "keys" on the bottom of the camera itself, then it will slide off. The operative word here is "think". It is an educated guess based on working in a camera store many, many years ago. good luck
Nov 03, 2008 | Photography
Shutter release
take it back to the shop
Aug 06, 2008 | Pentax *ist DS Digital Camera
The camera takes too long to take a photo. What should I do?
Press the shutter button halfway and hold it to set the focus, then press it the rest of the way down to take a photo. If you press the shutter button down all the way at once, it takes time to focus and set the exposure before the shutter releases. It may take longer than when pressing the shutter button in two steps.
Sep 12, 2005 | Epson PhotoPC L500V Digital Camera
Cameras Logo
Top Zeiss Cameras Experts
Bern Meister
Level 1 Expert
Tony Parsons
Tony Parsons
Are you a Zeiss Camera Expert? Answer questions, earn points and help others
