Question about Amana Washing Machines
Hi My front loader amana (nfw7200tw) will wash and spin and the water won't drain out. We having trouble doing the diagnosis test. What to do? Help
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 12 Answers
I had a front loader one time. There is a small filter before water pump. Look there. It's vert tricky. It is so full(coins, maybe).I believe that to be your problem.
Posted on Apr 25, 2017
SOURCE: LTF2140E Front loader washer
My Frigidaire front loader washer model LTF2140E doesnt want to drain the water when set to wash (heavy-normal-quick selectors). It washes put thats it. I have to switch the selector to drain/spin then rinse/spin cycle to finish the load. I checked the drain hose for any clogs....everything is clear. Any suggestions? Also,iIs2.gif their any reset buttons for this type of washer?
Posted on Dec 19, 2007
SOURCE: Frigidaire front loader washing machine won't spin...
just had my frigidaire fronter loader repaired,,try the door switch ...mines wouldnt spin clothes were soaked did everything else fine... what may have happen is when the spin cycle is ready to do its part it double checks to see if door is locked but with a bad switch it sends the wrong signal and computer this the door is open so it shuts off....well gl mines is running got lots of laundry to do,.,,,hope this helps
Posted on Sep 24, 2008
SOURCE: won't drain or spin
Sounds like the lid switch which is only about 30.00 to fix if you do it yourself. It's a little difficult but it's much better than replacing or having someone come in and do it
Posted on Mar 11, 2009
SOURCE: Amana NFW7200TW washer - door seal ring has detached
The ring is a clamp that keeps the rubber part, called the bellow, attached to the front panel of the washer. To reinstall hook the edge of the bellow around the lip of the opening in the front panel (the hole through which you put your laundry). Then take the clamp and seat it in the groove of the bellow behind the lip of the front panel. The spring on the clamp should pull the bellow tight to the opening of the panel.
Like so:
Posted on Dec 11, 2010
The problem is a faulty Door Latch Assembly. The same thing happened to my Frigidaire front load washer. The part is easy to install, costs about 60 dollars and can be picked up at most appliance repair stores . To access the switch just remove the wire around the front drum gasket, peel back the rubber gasket beside the switch assembly then remove the two screws holding it in place. remove the three wire connector blocks and swap in the new switch. My washer was giving me error code 41 witch is a faulty control board. But the problem was in fact only the switch...
Posted on Dec 28, 2010
Amana nfw7200tw will not run. all wash settings read 1 extra minute. Is this a code or something like that?
have you tried unplugging and resetting the computer, it seams hung in the last cycle, can you open the door and remove all inside, reset it again and try it, the washer sounds like it has water in it and needs to drain first,if it is full of water you have to drain it, by moving it and taken the drain hose off the pump,if that's the case i recommend flushing the inside with hot water and some bleach right through the front door or reservoir on top,after you get it emptied, the water sensor may be full of soap, by the way the soap your putting in this machine should only be about a 6th of a cup, I know it sound crazy but a half or a 3rd is to much, for the sensors, try this an get back to me,Matt
May 01, 2015 | Amana NFW7200TW 3.5 Cu. Ft. Front Load...
Hi, I have an Amana front load washer NFW7200TW that will go through entire cycle but won't spin- cycle ends and clothes are very wet. Unlike the other posts I read, mine shows no error code nor does the...
I have a similar problem with a Kenmore top loader washing machine.It turned out a problem with the main shaft of the drum; it wears out and caused drag on it. at one point i installed a washer or spacer between the shaft and drum it worked for a while and the problem came back again. it is a mechanical problem and it is present with other brands that share the same drum and shaft.
Finally I end up buying a different brand this time a LG .
Mar 08, 2015 | Amana Washing Machines
Washer has code nd wont drain and signals long beeps ,replaced pump and have the same problem hoses drained and didnt see any obstructions,old pump looks ok,matt
you probably used too much detergent or the wrong type. These new front loaders take no-suds detergent, a shot glass half full worth. The suds get in the water level tube and the level sensor and everywhere else, and cause mayhem. Run some loads with no detergent at all to try to clean the suds out. If the thing works like it should sometimes, it's a cheap fix. The brain power to find a problem and fix it for good, not so cheap. Water Level Switch 25315479-zejmo41uy3tce5x43qikgza0-5-0.jpg
Dec 10, 2014 | Amana NFW7200TW 3.5 Cu. Ft. Front Load...
My amana nfw7200tw needs a new drain pump. ive been online trying to find the best deal and i acaully have found a few (for a really great price) that pop up when i type in the washer model # and the
make sure it a drain pump, they same will fit Samsung ,amana and Maytag, make sure it not just stopped up remove it and look at the impellers, i put one in to find out it was the water sensor was soaped up and telling the washer it was full when it was empty and i would get a nd on the front , no drain,Matt, need the answer to fix that let me know.
Sep 21, 2014 | Amana NFW7200TW 3.5 Cu. Ft. Front Load...
The little door that opens to let water into machine(front loader) does not open. Why?
Links to sears parts direct. First link is to download manual, see page 11 Clean dispenser.
NFW7200TW10 AMANA RESIDENTIAL WASHER Manual
Second link is to parts diagram. images can be changed in size.
Second image from left is the dispenser.
AMANA Residential Washer Parts Model NFW7200TW10
Sears offers trouble shooting help also look for trouble shooting in user manual.
Sep 21, 2014 | Amana Front Load Washing Machine Washer...
Amana washer model NFW7200TW drain filter
Go to www.repairclinic.com and enter NFW7200TW. You will be presented with a list of common repair parts and may be able to view a generic Amana video showing disassembly and parts identification.
May 17, 2012 | Washing Machines
Front loader won't spin and is filled up with water. Won't drain.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
May 15, 2011 | Kenmore Energy Star 44092 Front Load...
My ge front end loader washer won`t spin water or pump water out
heatman101
Jan 29, 2011 | GE WSXH208A Front Load Washer
My amana front load washer wont spin and is showing an "nd" error message. what does this mean and how do i fix it?
Hi
Thanks for using FixYa. From what I understand the error code ND means “No Drain issue”. You’ll need to check for any restriction in pump assembly. It can also be due to a restricted drain hose or loose wire at pump. If after cleaning the drain hose the issue is not resolved then it means the pump has gone bad and unfortunately needs to be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 28, 2010 | Maytag NFW7200TW Front Load Washer
Washing Machines Logo
50 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
