After filling my name n password what's next - Computers & Internet
HOW TO PASSWORD PROTECT
Try the following steps:
>control panel
>network connections
>create a new connection
>choose "connect to internet" > Next
>setup my connection manually > Next
>connect using a broadband connection that requires a user name and password > Next
>Then fill in the space and set the user name ad password properly and then follow the setup wizard.
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Nov 11, 2012 | Computers & Internet
How do you lock a folder on a
Here's how(Set for limited access):
Start -> Settings -> Control Panel -> Users and Passwords
On the Users and Passwords window, make sure the "Users must enter a user name and password to use this computer" is checked, then hit "Add"
Fill in the "User Name"(You can fill in "Full Name" or "Description" if you want), hit Next.
Enter the password, hit Next.
Hit "Other" then under the drop down, select "Guest", hit Finish.
or you could download a third party software there a quite a few of them you could buy here is a free copy
http://download.cnet.com/my-lockbox/3000-2144_4-10789387.html
hope it helps
May 22, 2012 | Computers & Internet
How to transfer my roadrunner emails to gmail, just purchased a iphone G4?
If you are just trying to use your RR email account on the iPhone there is really no reason to go through the hassle of setting up a G-mail account to route it through.
If you still want to use G-mail ignore the next part.
On the iPhone select the "Settings application Next select the "Mail, Contacts, Calendars" option Under the subtitle "Accounts" select the "Add Account" Option Select "Other" and under mail select "Add mail account"
Fill out the information that is required to set up an account, "Name, Address, Password, and Description) for example (Billy, Billy1@tampabay.rr.com, 123abc, Main Address)
Click Next
Scroll down to the section labelled "Incoming Mail Server"
Change the "User Name" to your e-mail address And Scroll down to the section labelled "Outgoing Mail Server"
Change the "User Name" to your email address and fill in the password as what you would use to login to the website Choose save in the top right corner of the screen and wait for the information to process, if a dialog box pops up asking you to continue without an SSL select yes and wait for you information to process once more.
This should set up your RR email account on the iPhone4
Feb 23, 2011 | Apple iPhone Smartphone
Step by step guide to installing sap on windows 2003
hi dear
SAP4.7 Installation On Server 2003 SAP 4.7 INSTALLATION GUIDE 1. CREATE C PARTITION 6GB AND D PARTITION 70GB. INSTALL O.S SERVER. SET SYSTEM YEAR TO 2010 OR 2. CREATE LOOPBACK ADAPTER. START→ SETTINGS→ CONTROL PANEL ADD OR REMOVE HARDWARE→ NEXT→ NEXT→ SELECT ADD ANEW DEVICE NEXT SELECT WANT TO SELECT THE HARDWARESELECT NETWORK ADAPTER SELECT MICROSOFT NEXT NEXT FINISH. 3. CREATE IP ADDRESS MY NETWORK PLACES LOCAL AREA CONNECTION RIGHT CLICK PROPERTIES SELECT INTERNET PROTOCOL (TCP/IP)ADDRESS CLICK ON PROPERTIES AND IN IP ADDRESS 200.200.200. 20 AND OK OK 4. VIRTUAL MEMORY MYCOMPUTER RIGHT CLICK PROPERTIES ADVANCED TAB CHANGE SELECT D DRIVE INITIAL SIZE 2000 MAXIMUM SIZE 2000 CLICK SETOK OK OK 5. COPY ALL THREE DVD IN D DRIVE. SEE THAT D DRIVEMUST HAVE ATLEAST 54-55 GB FREE SPACE. 6. JAVA 1.4 INSTALL [FROM DVD 1] JAVA 1.4 DOUBLE CLICK NEXT I ACCEPT NEXT NEXT NEXT FINISH. JAVA PATH MY COMPUTER RIGHT CLICK PROLPERTIES ADVANCED ENVIORNMENT VARIABLE [SYSTEMVARIABLES ] SELECT NEW VARIABLE NAME JAVA_HOME VARIABLE VALUE ----------- START RUN BROWSE SELECT DRIVE PROGRAM FILES ANDPASTE IN VARIABLE VALUE BOX {Enter Path of JAVA) OK OK OK . 7. ORACLE 8I INSTALL [FROM DVD 3 ] ORACLE 4 NT I386 SETUP ORACLE 8I NEXT NEXT NEXTGLOBAL DATABASE NAME ORA NEXT INSTALL FINISH [ OREXIT] 8. INSTALLATION . [FROM DVD 3] KER NT I386 NTPATCH R3 DLLN DOUBLE CLICK ON THIS PRESS OK. KER SAPINST NT SETUP. SAP 4.7 INSTALLATION SELECT THIS AND PRESS NEXT NEXT SYSTEM ID ----- GIVE ANY DIGIT ALPHABETS [EX: SAI] NEXT SELECT CENTRAL INTANCE NEXT NEXT SELECT LOCAL INSTALLATION NEXT NEXT SELECT C DRIVE NEXT ------- GIVE PASSWORD AS 123 IT WILL ASK TWO TIMES THATPASSWORD NEXT 9. AFTER INSTALLATION OF ABOVE STEP GO TO : \ RIGHT CLICK ON USR SHARING & SECURITY SHARETHE FOLDER IN SECURITY TAB TICK ALL ALLOW. GO TO PROGRAMS SAP INST ORACLE KERNEL CLICK ONPREPARE NEW INSTALLATION. THEN AGAIN GO TO PROGRAMS SAP INST ORACLE KERNEL CLICK ON SAPINST SERVE WITH GUI. AGAIN FOLLOWS THE STEP IN STEP 8 WITH THE FOLLOWINGCHANGES. SELECT DATABASE INSTANCE INSTEAD OF CENTRAL INSTANCE SELECT LOCAL INSTALLATION NEXT NEXT SELECT D DRIVE D DRIVE} FOR BOTH OPTIONS NEXT NEXT IN PACKAGE LOCATION GIVE THE ADDRESS OF DB1-----ETC. DB1 EXPORT 1 LABEL.ASC DB2 EXPORT 2 LABEL.ASC DB3 EXPORT 3 LABEL.ASC EXPORT 4 LABEL.ASC EXPORT 5 LABEL.ASC EXPORT 6 LABEL.ASC EXPORT 7 LABEL.ASC NEXT NEXT. SELECT THE OPTION NO MNLS REQUIRED AFTER THIS IT WILL TAKE 15 HRS FOR INSTALLATION. ITWILL SHOW SUCCESSFULLY INSTALLED. 10. GO TO GUI GUI WINDOWS WIN32 SETUP. ã NEXT NEXT SELECT ALL NEXT INSTALL. 11. AFTER THAT CLICK ON SAP LOGON IN THAT CLICK ONNEW ITEMS DESCRIPTION ANY NAME APPLICATION SERVER TO KNOW THISOPEN SAP MANAGEMENT CONSOLE, IN THAT CHECK THE NAME ABOVEPROCESS LIST AND FILL WITH THAT NAME. SYSTEM NUMBER 00 12. CLICK ON LOGON USER ID DDIC PASSWORD 19920706. THEN GO TO SU01 TRANSACTION. GIVE THE USER SAPUSER (this is the user name to logon to sap) THEN PRESS F8. GIVE ANY NAME IN LAST NAME INITIAL PASSWORD REPEAT PASSWORD. THEN CLICK THE TAB PROFILES GIVE SAP _ALL SAP_ NEW & THEN PRESS ENTER & SEE IT WILL ASK THE PASSWORD , THIS IS THE PASSWORD TOLOGON TO SAP, GIVE ANY PASSWORD AND LOG OFF. 13. AGAIN LOGIN TO SAP NEW ID & PASSWORD AND THEN GOTO SE38 AND CREATE A PROGRAM STARTING WITH LETTER IT WILL ASK FORACCESS KEY. IN THAT TYPE 366 87 66 322126 127 8 694. Thank you
Imrna
Pls rank me as possible have nice day
Apr 20, 2009 | Microsoft Windows Server Standard 2003 for...
What to do for gprs activation in nokia 9300
hi,
1. Go to Tools > Control panel > Connections > Internet setup.
2. Select the tab Connections and Select New.
3. The question "Do you want to create a copy of existing Internet access point?" appears; Press No.
4. Choose Next.
5. Enter a name for the connection, for example internet.
6. Set Network-ID to Internet.
7. Set Internet settings type to GPRS.
8. Press Next.
9. Fill in access point name (APN).
10. Leave Username and password blank.
11. Press Next and Finish.
After setting up your phone continue with step 2
Apr 14, 2009 | Nokia 9300 Handheld
New User create without password
Go to Start -> Administrative Tools -> Active Directory Users & Computers
Right click the domain name (eg. company.local) go to new -> user.
Fill in the details go to next. leave the password field blank go next and click finish.
Mar 07, 2009 | Microsoft Windows Server Standard 2003 for...
I have problems to set up my account with Microsoft Office Outlook
If you are using Microsoft office outlook 2007, open your outlook, a wizard will appear, under email accounts click yes,click next, then under auto account setup, click check box on manually configure server settings then next, choose a.) internet email, (if you have your incoming and outgoing mail server), then next, then supply all information needed, account type pop3, name, email address, account name (must be the complete email address) incoming and outgoing then password, then next then hit finish or choose b.) Microsoft exchange (if you have an exchange server and you are on a network or a company) then next, fill out the information needed, your exchange server and your email address then click finish.
If you are using Microsoft office 2003, the process is just the same..
but, if you already have an existing email on your outlook and you want to modify it, go to tools, then email accounts (2003) or tools, option, mail setup, then email accounts, (2007), on the new window, double click the existing mail then supply again all the informations needed: name, email address, account name (must be the complete email address) incoming and outgoing then password. test if successful by sending an email to your own email address
Jan 31, 2009 | Yahoo Mail
Cannot access the internet
For the email:   Configuring Microsoft Outlook / Outlook Express for Dataone: 1. Open Outlook Express --> Click on Tools --> Click on Accounts 2. Click on Mail --> Click on Add -- Click on Mail 3. Fill - Display Name: e.g. A K Sharma 4. Click on Next --> Fill - E-mail address: e.g. aksharma@dataone.in 5. Click on Next --> Select My Incoming Mail Server is a POP3 Server 6. Fill - Incoming Mail (POP3) Server: e.g. wmma.dataone.in/smma.dataone.in/nmma.dataone.in as allotted by Node-Incharge 7. Fill Outgoing mail (SMTP) Server: e.g. wmra.dataone.in/smra.dataone.in/nmra.dataone.in 8. Click on Next --> Fill - Account name: e.g. aksharma@dataone.in 9. Un-tick Remember password --> Click on Next 10. Click on Finish --> Select the Account --> Click on Properties --> Click on Servers 11. Tick My Server requires authentication --> Click on Settings 12. Ensure that Use same settings as my incoming mail server is selected 13.  Click on OK --> Click on Apply --> Click on OK --> Click on Close 13.  Click on OK --> Click on Apply --> Click on OK --> Click on Close Back
  Configuring Netscape Messenger for Dataone: 1. Open Netscape Messenger --> Click on Edit --> Click on Preferences
2.
Click on Identity (under Mail & Newsgroups) --> Fill - Your Name: e.g. A K Sharma
3.
Fill - Email address: e.g. aksharma@dataone.in
4.
Click on Mail Servers (under Mail & Newsgroups) --> Under Incoming Mail Servers - Click on Add
5.
Fill - Server Name: e.g. wmma.dataone.in/smma.dataone.in/nmma.dataone.in as allotted by Node-Incharge
6.
Select Server Type as POP3 Server --> Fill - User Name: e.g. aksharma@dataone.in
7.
Click on OK --> Under Outgoing Mail Server Fill - Outgoing mail (SMTP) server: e.g. smra.dataone.in/wmra.dataone.in/nmra.dataone.in
8.
Fill - Outgoing mail server user name: e.g. aksharma@dataone.in --> Click on OK
Oct 11, 2008 | Compaq Presario 5000 PC Desktop
My Emails Are not coming through
well..this can happen from a password corruption issue..can you log onto the website and get them
Oct 09, 2008 | Computers & Internet
Unable to set up internet connection - option greyed out
in order to connect to internet you require a username and password
that user name and password will be given to you durin first time installation if you dont remember the username and password call up your broad band help desk. they will help with the user name and password.
if you are aware of the user name and password ,
you need the configure the internet setup using the user name and password
i ll give the steps to configure the user name and password in windows XP operating system
1 click on "start" button at bottom left of your desktop
2 click on control panel
3 on left hand side of the window click "classical view"
4 then click on the icon network connections
5 there you will find "create new connection"  or "new connection wizard"on the left hand side just   double click on it
6 a new dialog ll appear click next
7 on the next screen select "connect to internet" and click on next
8 on the next screen click on "setup my connection manually" then click on next
9 on the next screen select the option "connect using a user name and password" and click next
10 you will be asked for ISP name "for eg:fill in AT&T"
11 on the next screen you willlbe asked for user name and password , fill in the respective details
for eg: sam @att.net :username
            ******** :password
12 den click finish
you will find an icon in the desk top by now. just double click on that icon and try browsinn
you must be up and runnin ! ! !
Sep 14, 2008 | Siemens SpeedStream 5260 ADSL LAN Modem...
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
