Question about The Office Equipment & Supplies
Do you stock Meadow print pillowcases to match the duvet set
What is a duvet
Also known as a "comforter". It is used instead of a blanket, and usually covered by a sack-like "duvet cover".
Oct 05, 2014 | Home
My Business Cards
You need to set the print size to match the size of the card.
you either need to resize the document or change your print preferences to match the size of the card.
May 16, 2008 | Avanquest MyBusinessCards (824592)
Z4m printer error condition paper out labels will just keep feeding through ?
Sounds like a miss-match on the labels you are loading and the labels it is set up for. You'll have to go into the printer properties and check (and adjust as needed) the label stock selected to make sure they match. Next check the setting on the printer its self for the same for label stock selected. Most likely you're trying to use a label stock different then it was using before.
Jul 16, 2014 | Zebra Z4Mplus Label Printer
Can I load a duvet?
It could be a problem depending on your drum size. Ive usually found a single duvet will fit but if you have to push the door firmly to close it i'd be tempted to go to the launderette with it.
Dec 04, 2011 | Indesit Washing Machines
HP Photosmart Premium c309a series smudging wedding invitation envelopes badly. I can print the invitations and everything else just fine. Any suggestions? Thank you.
when you go to print your envelope and click the print command - a window will open with the name of your printer and a box that says properties. click on properties. Change the type of envelope stock to match what you are printing on in the next window. If you are using photo paper envelope with a glossy finish, make sure that is the print media you have set for your printer. If not, the ink will just keep smudging. it's very important to match the print stock (matte, glossy, premium ect).
Oct 09, 2011 | HP Photosmart Premium C309A All-In-One...
Cannot print Labels
The printer is setting the size from the position of the tray guides.
If it is reading it as K16 then that is the closest size to the paper you have loaded. The device will oook at the tray and then set it to the closest match this is the function of the Auto size feature.
Try measuring the paper and entering it as a custom size instead. Mimic the setting through the driver of course.
Run it through the bypass tray and be sure to specify the stock type/weight for proper printing.
Sep 10, 2008 | Konica Minolta bizhub C450P Laser Printer
Can't print onto thick card
Have you tried specifying the paper type and weight INSTEAD of the tray. Set the tray properties first, then print. If you leave it on auto tray it will use the tray that matches your paper type and weight.
Jan 09, 2007 | Konica Minolta bizhub C351 All-In-One...
19 people viewed this question
Top The Office Equipment & Supplies Experts
James Cagle
James Cagle
Gareth Cockram
Gareth Cockram
Peter March
Peter March
Level 1 Expert
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
