Question about Electrical Supplies
Wiring diagram for forward livewell rocker switch
squipps
  • 204 Answers
SOURCE: our fellowes shredder runs in reverse
Sounds like the rocker switch is turned around. I would just change it or re lable the switch
Posted on Dec 18, 2009
Natemane
SOURCE: ROCKER SWITCH DIAGRAM
On the top of the switch (inside the heater) there is a common connection.....even though it looks as if it is connected (electrically), it isn't electrically affected by the switch; it's just used as a post. It's just the place where the striped wire connects to the "common" point for the heater coils (they are in a parallel). Also, while you're in there you might want to put some electrical grease on the exposed conductors.....mine had quite a bit of corrosion (which was the reason for the failure). I had to replace 3 of the female connectors.
Posted on Jan 01, 2010
  • 41 Answers
SOURCE: Need wiring diagram for Rainbow D4C vacuum to
You can get a wiring diagram at http://www.rainvac.com/schematic.html
You can get all of the manuals, and the full breakdown schematics, of every model there.
If you need me to tell you which wires go where, exactly on the switch, let me know. I am a Rainbow vacuum expert and know everything about almost every model ever made.
If you have any more questions, let me know.
Thank you,
Posted on Jun 13, 2010
e-Guru
  • 3917 Answers
SOURCE: what is the wiring diagram
Hi
Please check the bellow links if it helps:-
http://www.bcae1.com/switches.htm
http://www.wiringdiagrams21.com/2010/12/26/windlass-3-terminals-electric-motor-wiring-diagram
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Jan 14, 2011
  • 3287 Answers
SOURCE: wire diagram for 9' ATV Rocker Winch Handle Bar Mount Remote Control Thu to the winch
Here's the owner's manual - it includes wiring & installation information:
http://mediacdn.shopatron.com/media/mfg/4377/media_document/4398/10991.pdf
If you're looking for information that is not provided in the manual, you should contact Superwinch directly:
In the USA:
Superwinch, Inc.
Winch Drive
Putnam, CT 06260
U.S.A.
Tel: (860) 928-7787
Fax: (860) 963-0811
e-mail: info@superwinch.com
Elsewhere:
Superwinch, Inc.
Unit D, Union Mine Road
Pitts Cleave Ind Est
Tavistock, Devon
PL19 OPW England
Tel: 44 (0) 1822 619222
Fax: 44 (0) 1822 615204
e-mail: sales@superwinch.net
I hope this helps & good luck!
Posted on Jan 13, 2012
Live well pump Key Largo boat what switch turns it on& off
On some boats there is a manual handle to direct water to either wash down or livewell. If you hear a pump running, but no water in livewell, look for that manual handle in the hose plumbing.
Sep 10, 2017 | Boating
I need the wiring diagram for the wiring on my Princecraft DLX Restorer boat. My marine lights, livewell and bilge pump are not working.
Lee,
No such animal exists. They are not wired via a diagram at the factory. Your best bet is a simple light up circuit tester which are only a couple bucks at places like Harbor Freight. All auto stores will have them as well. Then just follow the wiring from each component switch (turned on) to any splices, fuse panel, etc. and see where it is powered and where it is not. You should be able to isolate it. Since you have 3 components not working, I would start at junctions where multiple wires connect such as Ground, fuse panel, behind dash, etc.
Aug 01, 2016 | Boating
My 2008 rocker c keeps blowing fuses for the headlight, might I need a new one/
Hi Ivan, you have a hard/dead short that should be easy to find generally they are the easiest. Time to get out your test light and connect it to the power side of the, circuit breaker or the blown fuse receiver, start by tracking the out bound wire towards the ignition switch and beyond if necessary, when the test light quits lighting you are very close to your short. For a free wiring diagram please visit the website below and good luck.
Harley Davidson Wiring Diagrams and Schematics
Jul 28, 2012 | 2008 Harley Davidson FXCWC Softail Rocker...
Triple rocker switch to control 3 function bathroom fan/light
I suggest you cut 3 pigtails out of your black wire (about 5-6" each and strip them so you can put a nut to tie them all together on the main wire, then do the same for your grounds using green 5-6" strips of wire and then connect all 3 switches with the pigtails to their proper locations. This WILL fix your problem.
Mar 08, 2010 | Leviton 1755 Triple Rocker Switch Decora
Aug 27, 2008 | Lakewood Heating & Cooling
Electrical Supplies Logo
80 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
