How do I open the bottom of my logic l8114wm16 washing machine to clean my filter thank you
johnychel
  • 796 Answers
SOURCE: spinning cycle
Keeping in mind that the soap & bleach gets dispensed into your wash on the second to last rinse cycle and that most all rinse cycles are in cold water. Is your cold water valve screen plugged causing your washer to rinse poorly? Are you using the HE detergent? If not maybe the washer is sudsing up to much and having a hard time rinsing all the suds and bleach out and leaving the clothes soapy.
Fill the washer up with no clothes in it on a cold/cold wash setting does it take a long time to fill the washer up? Also when it is full and agitating is there suds in the washer?
Last suggestion is if the drain is hose is a lot higher than the top of the washer it might have a hard time draining out all of the soap water before the next load
Posted on Mar 23, 2008
  • 8 Answers
SOURCE: i have a servis easi
HI THIS SOUNDS LIKE IT COULD BE THE CARBON BRUSHES IN THE MOTOR SO YOU NEED TO CHECK THEM OR GET SOMEONE TO DO IT FOR YOU IF THEY ARE LOW (APPROX 5MM LONG OR LESS) THE MACHINE WILL TUMBLE BUT WONT SPIN IF THEY ARE LONGER THAN THAT THOUGH IT COULD WELL BE A CIRCUIT BOARD PROBLEM WHICH UNFORTUNATLEY IS A COMMON PROBLEM WITH THIS BRAND IF THIS IS THE CASE BE PREPARED TO SPEND A LOT OF MONEY ON A REPAIR AS THEY ARE EXPENSIVE!
Posted on Jul 30, 2008
mikedurland
  • 481 Answers
SOURCE: Samsung washing machine filter
it has a self cleaning filter. if you want to clean out the tub and filter thoroughly then:
  • run a cycle with no clothes using hot water and a gallon or two of bleach.
  • after the tub has filled up add a teaspoon or less of dish liquid like palmolive. this acts like a surfactant for the bleach.
  • make sure you also run an extra rinse cycle to make sure you have all the bleach out of the machine before putting clothes in.
Posted on Aug 04, 2008
EsWorld
  • 1618 Answers
SOURCE: Gaggia Syncrony logic rapid steam machine leaks water from bottom
Check the chamber under the white plastic valve behind the brew unit, it might be blocked with coffee.
Posted on Apr 16, 2010
Whispis2
  • 192 Answers
SOURCE: Cannot get out and clean
Manual is here...
https://portal.bsh-partner.com/TCcustomBSH/controller/download_file?PDFOBID=rhdu2Hjcdcso0pdmdb---hNm&UMOBID=rhdu2Jhcdcso0pdmdb---hNm
Go to page 26 for instructions.
Posted on Mar 20, 2011
I have a LG Fuzzy Logic WF-T5001PP washing mashine. It is taking longer for the water to enter. Does it have a water inlet filter that I can clean?
HI... If u see your backside of your machine there is a inlet valve (water inlet valve) open that water tube and see one small netted filter is there you just remove that filter outside and clear that filter with a tooth brush and insert it again....
Jan 15, 2017 | LG Washing Machines
My LG washing machine model-fuzzy logic WF-s6607tc, is not spinning
The filter for your empty pump is probably clogged. The machine can't drain the water in the alloted time because it is draining to slowly through the clogged filter. The machine won't start the spin cycle if all the water hasn't been evacuated. You will need to find and clean out your empty pump filter (Probably behind a little door at the bottom of the machine.
Jun 23, 2011 | LG Washing Machines
My washing machine model: Fuzzy Logic WFT10C31EP. Problem: When I start the machine, water does not fall into the tub although water pressure from the source is excellent. Only spin is...
It sounds like the water inlet valve is not functioning like it should. It is supposed to open to allow water to flow in when the Control Board gives the signal to open. First, try cleaning the Water Inlet Valve Filter. Turn the water supply off and remove the Water Supply Hoses. You will see the filter inside the Valve. Clean it out, and reconnect the hoses. Try washing again. If no water flows into the machine, you will need to replace the Inlet Valve/s. Try running an empty wash with just cold water, and then try running an empty wash with just hot water. If neither are working, you may have a control board fault. If only one side works, replace that sides water inlet valve.
Feb 28, 2011 | Daewoo Washing Machines
Upon selecting a wash cycle and closing the door the machine starts normally (heating water stage) but never clicks to allow water in and wash the dishes. Fails to advance to the wash cycle and just runs...
Not knowing the make or if the machine is logic controlled, it’s very hard to diagnose. If it’s a logic controlled machine, my guess is the board is bad.
Jan 27, 2018 | Bosch SHV46C03 Built-in Dishwasher
WATER COMING INTO THE MACHINE IS VERY SLOW. HOW
Most machines have an inlet filter which requires periodic cleaning. If the water hose connection screws onto the rear of the machine, unscrew the hose at the washing machine, remove the filter, rinse, clean and replace.
Apr 06, 2010 | Washing Machines
Hi, My zanussi washing machine model z221w does not seem to be draining properly - any ideas? Also I want to check the filter at the bottom rhs of the machine but I cant seem to open it can you help? A...
If you have located the filter at bottom right front of washer, firmly grasp filter handle, and turn anti-clockwise to remove and clean. if it does not come out, then something is jammed in filter, so just keep trying to pull it out.
Please rate my solution.
Thanks.
Nov 06, 2009 | Washing Machines
How do I open the filter on a hotpoint aquarius WF 321 1200 spin washing machine?
there should be a hatch on the front at the bottom right hand corner! open the hatch and you should see something that looks like a dial turn this anti clockwise. if it does not turn you will have to apply pressure. this could possibly break the componant! don't worry this often happens they are easily replaced from your local domestic appliance repair centre
Oct 16, 2009 | Washing Machines
F04 error message on a bosch exxcel 1400 washing machine, then the water wont drain away
This error indicates an obstruction in the water pump. . Tip machine back so you can fit a bowl under the bottom right hand side. Flip back cover at bottom right to reveal pump filter access - unscrew (quite a bit of water comes out so have the bowl ready).
Sep 26, 2009 | Washing Machines
Hi i have an indesit wd12x washing machine that does not drain the water. How do i get to the filter to clean it? Thanks
Your model of washer dryer is fittted with a self cleaning pump, and may not have a filter fitted.
To check if it has, remove lower plinth at bottom of m/c, and if there is a plastic panel there ,remove that as well.
If there is a filter fitted, you will see it at the bottom right front, it has a round cover, unscrew anti clockwise, remove and clean filter.
Pleas leave a fixya rating if you consider my solution appropiate to your query.
Thankyou.
Jan 29, 2009 | Indesit W 123 Front Load Washer
Code on display OE
Just got the same problem. Found out there is a filter on the bottom of the machin that collects everything. It was plugged bad. There is a door on the front bottom left open door unscrew filter (the bigger object in the door.) Clean filter and wala.
Oct 24, 2008 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
