Question about Coffee Makers & Espresso Machines
My coffee machine is dispensing hardly any water on either setting
  • 6 Answers
How long has it been since you did a good cleaning? If you can see the opening where the water is suppoise to come out at take a tooth pick or toothbrush and poke thru. Then put vinegar in the water reservoir and turn on machine as if you was making coffee, but no coffee grounds. This will help clean the inside if the machine that you can't actually get to. May need to do this several times if you haven't cleaned in awhile, then run another cycle with just cold water to remove any vinegar taste. Hope this helps, if not it's probably time to get a new machine. Remember to do the vinegar cycle once every couple of months for preventive measures.
Posted on Apr 25, 2017
What would cause the machine to grind the beans but not produce any coffee despite the water tank being full?
Your grinder setting might be too fine. Only adjust while the grinder is grinding -- set to a coarser grind. Have you tried the preground coffee dispenser? Again, use coarser ground coffee in case the sieve is getting clogged.
Mar 27, 2015 | Coffee Makers & Espresso Machines
16 oz setting dispenses 32 oz of coffee
Yes this is a problem and it was fixed in 2014.
Jan 21, 2012 | Keurig 5048 My K-Cup Reuseable Coffee...
I have a Saeco Incanto Classic. There is hardly any water coming through the coffee dispenser even if I only use the preground doser without inserting coffee. While the little water comes out it makes a...
Sounds like the the shower screen under the red o-ring in the brew group needs to be cleaned, you can remove the screen and clean or you can purchase some espresso machine soap puro caff or puly caff, and run it through the brew group using the preground method the clean out coffee oils.
Aug 26, 2011 | Saeco Incanto Classic Espresso Machine
I have the coffee maker set to 2 cups. After 1 cup of coffee is dispensed I get water for the second cup then the machine keeps brewing a 3rd cup of coffee and a 4th cup of water. So instead of 2 cups of...
Yes you programmed it unaware, the machine will follow what you instruct on it. So change the program setting and try it again.
This advice will gonna help you.
Mar 31, 2011 | Miele CVA 4066 Stainless Steel
My Keurig dispenses about 3oz of water on next to largest setting
I JUST fixed (I Hope!) my 11 month old B60 by taking a paper clip and a straightened safety pin to the top of the coffee maker (where the top pin punctures the top of the cup) and the BOTTOM pin which punctures the bottom of the cup. (remove the bottom dark brown holder by pushing up on it).
After one or two attempts, I ran water through it without the coffee cup, then used a decaf cup and brewed it just fine....
Aug 25, 2009 | Keurig Platinum B70 Coffee Maker
Spidem trevi digital plus coffee machine not working as it should
it sounds like you need to go into the programing mode. in there you can set the machine so it grinds when you select coffee. at the moment it is pregrinding this is so you can make lots of coffees 1 after the other
Jan 27, 2009 | Spidem Trevi Digital Coffee Maker,...
Water Leaks from bottom of machine as coffee is dispensed?
I had this same problem. Open the front door, remove the dreg drawer and then remove the brewgroup. In the back you will see a pipe sticking down with an o-ring gasket on it. Below that is a channel and a little opening where rinse water is supposed to flow into the front drip tray. It gets clogged with grounds pretty easily. I filled a hose with some water and stuck it down there and blew through it until you can see water come out the front hole. It's a little hard to describe but I hope this fixes your problem, it did for me. I just have to do it once every couple months.
Dec 07, 2008 | Saeco Vienna Digital Coffee Maker,...
The coffee dispenses really slowly.
if our coffee drip try to ajust how fine you grind and amount of coffee if you grind the cooffee to fine its hard for the pressure water to go truh and clean the machine with a decalcifier to remove the calcium buildup more calcium less pressure you have to clean the machine every other mounth cheers
Jan 18, 2008 | Gaggia Syncrony Compact Coffee...
Saeco magic
I believe the model you have has no user-selectable temperature settings. The manual for the Magic line suggests preheating the cups as the fix. You can use the electronic cup warner OR run your tap/faucet water as hot as possible, fill the cup you're going to be dispensing espresso into with hot water while your Saeco warms up...right before you hit the button to dispense espresso, empty the hot water, dry the preheated cup and you're set! It only takes a few seconds. This way, you waste none of your coffee's thermal emergy on cup heating and your coffee will stay hot longer. Hope this helps!
Jan 02, 2008 | Saeco Magic De Luxe Espresso Machine
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
