Question about Water Water Heaters
Brand new rennai tankless hot water heater installed on newly built home. Rl75e model need to purge for the first time
  • Water Master
  • 3,315 Answers
Gas line I take it . You will need to purge from the outlet of the meter first to make sure service line and meter are clear of air . And then close to the heater make sure its well vented and no source of ignition soap test any joints you loosen .
Posted on Apr 25, 2017
My rennai tankless water boiler light blinking good to Se to sefc back good continuous
Find your water heater model on line and follow the mfg. code info for the code you are getting.
Oct 10, 2013 | Water Heaters
Eletric water heater not heating up to 125
Include product brand, model and type for best possible answer.
Include if this is new installation, or installation that worked before and stopped working.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 03, 2012 | Stiebel Eltron Stiebel TEMPRA24PLUS Eltron...
How do you insulate a tankless water heater for winter
If you have tankless electric, it can simply be insulated... but tankless electric are seldom mounted outdoor.
Service bulletin says: "the only way of assuring protection is to completely remove the heater during those times the area may experience freezing temperatures.
There are tankless with built-in heater for exterior installation.
Check your manual, or add a comment with specific model number and maybe I can find the information.
Here's why they install tankless outdoors: Because tankless burn more fuel per gallon of hot water. This requires larger gas line and larger vent pipe than typical tank-type gas water heater that is usually installed indoors.
They install tankless outdoors, so there is no need for expensive vent pipe, and because there is ample incoming air to support combustion.
So if tankless does not have factory-installed internal heater, then the unit can freeze easily when the combustion draws in cold air.
Of course you can put heat-tapes on the pipes but the heat exchanger inside will quickly freeze during periods when hot water is not being used, and combustion is not taking place.
You can move the tankless installation inside and use correctly-sized vent and intake pipes directly through the wall. This will generally protect tanklesss from freezing if room is heated adequately.
Sep 26, 2012 | Rinnai Webstone The isolator EXP tankless...
Tankless Water Heater
Yes you need to delime tankless each year.
http://waterheatertimer.org/pdf/Bosch_Descaling-heat-exchanger.pdf
http://waterheatertimer.org/pdf/Rheem-De-lime-tankless.pdf
Contact Bosch for exact repair information. My records show following number for tankless gas: 800-642-3111
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
Sep 20, 2012 | Bosch Water Heaters
How to instal tankless hot water
Open following link for installing tankless electric water heater:
http://waterheatertimer.org/How-to-wire-Tankless-electric-water-heater.html
Dec 01, 2011 | Rheem Tankless Hot Water Heater...
Can we install a a ptg 74pvp tankless hot water heater in a closet? Would we need to install grating in the closet wall to provide more fresh air?
Rheem Tankless Water Heater Selection and Installation Videos
  • Introduction - time 04:11
  • Pre-Qualifying the installation - time 01:13
  • Selecting the Right Product - time 01:48
  • Key Differences Between Tankless & Storage Heater- time 01:27
  • Choosing the Location - time 01:20
  • Installation: Major Components - time 00:58
  • Installation: Tools Required - time 00:48
  • Installation: Mounting the Heater - time 01:15
  • Installation: Plumbing & Gas Connections - time 04:29
  • Installation: Side Wall Vent Termination - time 02:41
  • Outdoor Installation - time 01:21
  • Connecting the Remote Control - time 01:42
  • Turning on the Water Heater - time 01:00
  • Commercial vs. Residential Products - time 01:47
  • Manifolding Multiple Units - time 01:43
  • Troubleshooting & Additional Support - time 01:01
Feb 02, 2011 | Rheem Tankless Hot Water Heater...
Need to turn on several different hot water sources to get my heater to fire up. My faucets are low flow, so for some reason the heater will not fire unless there is more demand. It is brand new out of...
When a tankless is installed, they are usually set up with a recirc. Theis keeps the water continuously heating to some degree.
When a tankless is installed into a home it has nothing to heat the water that is sitting in the pipe from its faucet to its heat source. Now as soon as you turn on the faucet, you have to let all that cold water run out until the newly heated water comes out from when you started the faucet.
You could measure the volume until heat and it will be pretty much the same every time for a given faucet.
The fact that your faucets are low flo is only part of the factor involving time it takes to get hot water. Another factor is volume. The diameter of your pipes makes a difference. You can remove the low flo restrictor from the faucet farthest away to speed up the process at least a little.
Jan 04, 2011 | Bosch & Tankless LP Hot Water Heater
No hot water
Aquastar 1600H NG Natural Gas Tankless Water Heater Bosch AquaStar Model 1600H NG Natural Gas Whole house tankless gas water heater, 117,000 Btu input, natural draft with hydro-generated ignition. Provides endless hot water for one major application at a time . Can replace 40-gallon storage tank water heater. Optional Accessory: Model AQ1- Power vent with built-in... More freeze protection when venting horizontally. Capacity: 1 to 2 Bathrooms Dimensions: 8.75D x 18.25 W x 29.75H Weight: 40 Max GPM @ 45F Rise: 4.2 Energy Factor: NG .80 LP .84 Minimum Input: 28,000 Maximum Input: 117,000 Vent Size: 5 Gas Connection: 3/4 Water Connections: 1/2 Warranty: 12-year warranty on heat exchanger, 2-year on parts Features: Endless hot water Can save up to 50% off utility costs annually Perfect for one major application at a time No standing pilot, hydro generated
Mar 01, 2009 | Bosch 1600H-NG Natural Gas AquaStar...
No instant hot water
If you have a tankless hot water heater, you may still need to install an expansion air chamber to stop the "water hammer"; If you have a tanked hot water heater, you will never get instant hot water like with a tankless unit.
Dec 30, 2008 | Water Heaters
Water Heaters Logo
Top Water Heaters Experts
vince
80stech
D. E. Hev
Are you a Water Heater Expert? Answer questions, earn points and help others
