Question about The Office Equipment & Supplies
3 known dimensions of lines,2 angles are 90 degrees what is the 3rd angle
5 Suggested Answers
SOURCE: Older Delta 10'' Miter Saw Zero setting is out by 1/2 degree.
Undid the RH fence-bolt in the table behind the fence and tapped the end of the fence forward to make it perpendicular to the blade. Tighten bolt. When you look down on the two fence bolt heads, one is easy to rotate with a socket wrench, the LH bolt head would be very, very difficult to move. Undo the RH bolt to swing the fence angle WRT the blade.
Posted on Apr 09, 2009
drifterK
  • 4924 Answers
SOURCE: I have a irregular triagle
use general Pitagora's theorem ( if you can not just make the measurements) ...I mean get the long one on the ground ..and after that measure with a protractor the angle ..and draw the second one ..when you draw a line from the ends of the 2 of them you will have the 3rd.
or ..this is the Pitagora's theorem in general cases..
BC2=AB2+AC2-2*AB*AC*cosA
meaning
BC2 =48.6sqre+66sqre -2 x 48.6 x 66 x R(3)/2 whwre R(3) is the square root from 3 and R(3)/2 is the cos 30"
and will be with approximation
BC=24.44
Posted on Jan 03, 2011
  • 360 Answers
SOURCE: bottom of screen is projecting
It is called as keystone distortion. To correct the problem press the "Keystone" button on the projector, then press left, right, down & up arrow buttons to adjust the angle at 90 degrees.
Posted on Aug 15, 2011
  • 102366 Answers
SOURCE: finding the length of a triangle
45 tan(37) or about 39.1 feet.
Posted on Mar 29, 2014
What is the cylinderhead bolts torque for Corsa lite 2007
Need to know the engine type really, for the X14XE and Z14 XE Haynes recommend:
This for the 1.4 8v as you did not stipulate the engine, they are all different........
Cylinder headbolts (use new bolts)
stage 1 ... 25 Nm (18 lb ft)
stage 2 ... angle tighten + 90 degrees
stage 3 ... angle tighten + 90 degrees
stage 4 ... angle tighten + 90 degrees
stage 5 ... angle tighten + 45 degrees
Mar 06, 2018 | Cars & Trucks
How many angles does a regular polygon have when its interior angle is 176 degrees
Lots and lots and lots. When you think the angle is nearly 180 degrees or a straight line, it must have lots and lots of sides.
The total of the interior angles of a polygon is given by (n-2)180, so the angle of each interior angle of a regular polygon is given by ((n-2)180)/n.
Now we set this to be equal to 176 and solve for n.
(n-2)180 = 176
n
Multiplying both sides by n, we get (n-2) 180 = 176n
Expanding the left side of the equation, 180n - 360 = 176n
Subtracting 176n from both sides and adding 360 to both sides, we get
180n - 176n = 360
4n = 360
Dividing both sides by 4, n = 90
Thus, you need a regular polygon of 90 sides to get an internal angle of 176 degrees.
Hopefully you don't have to construct it.
Good luck,
Paul
Mar 26, 2017 | Homework
How many sides does a regular polygon have when the interior degrees is 176?
(n-2)180 = 176
n
180n - 176n = 360
4n = 360
Good luck,
Paul
Need torgue specs for bolts on head of my 2000 vauxhall tigra 1.4
Cylinder head bolts (You must use new bolts)
Remember use NEW bolts, these are called torque to yield bolts, they stretch like a linear spring and they only last one use.
Jun 25, 2016 | Vauxhall Cars & Trucks
I want to know the torque opel corsa lite 1.4 cylinder head bolts.
Feb 26, 2015 | Opel Corsa Cars & Trucks
How can you classify a triangle according to it angle? is there a formula for it
Well, there is classification by sides, equilateral with 3 equal sides, Isosceles with two equal sides, and scalene with no equal sides, but you talk about angles, but I wanted to point out equilaterals have 3 equal angles, isoceles have 2 equal angles and scalene have no equal angles.
So, now we talk about angles: a Right trianlge has one angle that is 90 degrees, an Obtuse triangle has one angle greater than 90 degrees, and an Acute has no angles over 90 degrees.
Thus, it is possible to have a (scalene or isoceles) AND (acute, obtuse, or right) triangle, but never an equilateral AND (obtuse or right). The angles can't be equal and 90+ degrees if all three must equal 180 degrees.
Oct 06, 2012 | Mathsoft StudyWorks! Middle School Deluxe...
What are perpendicular lines
Two lines are perpendicular if they belong to the same plane and intersect (cut) one another at right angle. They make a 90 degree angle. If you are doing analytic geometry, two lines are perpendicular if the product of their slopes ia equal to -1.
Other relative positions of lines are parallel (they have the same slope/direction) or they are just secant at an angle not equal to 90 degrees.
Feb 03, 2012 | Office Equipment & Supplies
How can i do because my calculator cannot graph trig trigonometric functions
When dealing with trigonometric functions and their inverses one has to make sure the angle unit is chosen accordingly.
I am including a few screen capture to help you do the graph.
First, in Home screen Run the NewProb command to reset the calculator and ready it as a clean slate.
Set the correct angle unit. By default, after the NewProb command the angle unit is reset to Radian. If you want something else change it. See picture. Select 1:radian or 2:Degree.
I will use Radian first.
Press the key sequence that opens the Y= editor. Enter Y1=sin(X)
Remember after a newProb command unit is Radian, Window is standard.
Here is what you get.
Here are the window dimension that gave this picture
Now I am going to change the angle unit to degree and redraw a better framed graph. (I could have done it with the radian unit too.)
As you can see I played with the window dimensions (Xmin=-3*180=-540 and Xmax=3*180=540. The Xscale factor was set to 90 and the range of y-values was reduced to -1.2 to 1.2)
Before hitting the Graph sequence make sure that the function to be drawn has a check mark to its left (see the 3rd screen capture from the top).
Jul 21, 2010 | Texas Instruments TI-89 Calculator
I am getting the wrong answers with the tan -1 function
That habit of TI, Casio, and Sharp to label the inverse trigonometric functions with the -1 superscript can cause confusions.
  1. The inverse trigonometric functions arcosine, arcsine, and arctangent (labeled by manufacturers as cos^-1, sin^-1, and tan^-1) should not be confused with the other trigonometric functions known as secant(x) =1/cos(x), cosecant(x)=1/sin(x) and cotangent(x) = 1/tan(x).
  2. To avoid errors in the use of the inverse trigonometric functions, one must be careful and set the angle unit to the one required by the problem at hand (degrees, or radians)
  3. To make the trigonometric functions really functions, their range is restricted.
  4. In this calculator arcosine (x) gives results between 0 and 180 degrees (if angle MODE is Degree) or between 0 and Pi radians (if angle MODE is Radian).
  5. The range of results for arcsine(x) and arctangent(x) is between -90 degrees and +90 degrees (if angle MODE Degree) or -Pi/2 and Pi/2 (if angle MODE is Radian)
With this information you should be able to set the angle unit correctly ([MODE][Radian] or [MODE][Degree] ) and interpret the results. If you want to extend the angle to other values, use the periodicity of the trigonometric functions.
Hope it helps
Nov 06, 2009 | Texas Instruments TI-83 Plus Calculator
21 people viewed this question
Top The Office Equipment & Supplies Experts
thetraveler
Level 1 Expert
Folusho Adeyanju
Folusho Adeyanju
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
