Question about Pool & Spa
Spa won't start after cleaning. What might be wrong?
    New Friend:
  • 66 Answers
After draining a spa it is common to get an air lock in the plumbing. Depending on the manufacturer or plumbing configuration will determine the easiest way to accomplish this. The concept is the same, help the water to start moving. Either relieve the air down low, i usually loosen the pump drain plug until water sprays out or force water through the plumbing in the natural direction of water flow. Those little 24 hour circulation pumps are usually the biggest culprit for this problem.
Posted on Apr 27, 2017
Recirculation pump not starting
need to check the contacts in the relays themselves.. see if they need cleaned to make better contact.. may use a small fingernail emery board..or fine sandpaper to clean them..unplug the unit first..
Jan 18, 2014 | Pool & Spa
Won,t pump water
have you tried sending it to a shop to see what's wrong. it might just be the motor has burned out.
May 15, 2013 | Pool & Spa
Raypak spa heater pr5 service code message
check pressure switch if no voltage both sides of switch bad switch or plugged copper line or loose wires
Oct 02, 2012 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Flo code is on and pump won't start up
Flo = Improper flow or pressure switch malfunction or Flow switch malfunction (system specific).
Before you purchase a new pressure switch:
- Clean or replace your filter cartridge (if its older than 1 yr).
- Check that all slice/gate valves are up/open.
- Check water lines for blockages incl. suction cover & ensure sufficient water level in spa.
Jan 29, 2012 | Qca Spas Majestic Series Aruba Xl Hot Tub
My pump works on low speed but not high speed
these are a bear to work on.. there are start switches inside of the motor, and will break if you even look at them wrong.(fragile) you can try compressed air to blow out the trash that might be in the switch..or unhook power cord of the motor from the motherboard and remove the pump and motor from the spa , bring it to your local pool pump moor repair guy with free testing have it tested. if removing wires from motor YOU MUST REINSTALL THEM EXACTLY AS THEY CAME OFF ! OR YOU WILL BURN UP THE expensive 2 speed motor .. jay Florida
Dec 20, 2011 | Pool & Spa
We have an Jandy Ji8000. We have really enjoyed having it for years. Just lately, the filter goes on at the wrong time. If we try to turn it off at the panel in the house, it will not turn off. We have to...
Look up Zodiac Pool systems, on the web site you can find a list of service providers in your area. You may be looking at replacing your automation at this point.
Hayward flo pump motor repair
What exactly is wrong with your pool pump? If it won't start at all, check for improper or loose connections, blown fuses or tripped breakers, and open your switches and replays. Manually check the rotation of your motor shaft. Make sure that there is free movement and no obstructions. If the motor hums, but won't start, check for obstructions and check the Centrifugal switch to see if it is stuck in the open position. If you have low flow, check pool pumps for clogged or restricted strainer/suction line and discharge line of filter. You could also have an air leak in suction (bubbles issuing from return fittings). Low voltage could cause loss of suction. Check for plugged or restricted impeller.
Jun 02, 2010 | Hayward 1hp Power Flo Matrix Above Ground...
My dreammaker spa has power and lights but the pump won,t turn makes a sound for a few seconds like it is trying to turn over then it was recently running .
Sounds like the pump is jammed or the motor bearings are frozen. If you can take it apart, try the pump first. The bearings on modern motors are pretty reliable. Get everything cleaned and lubed and put it back together. Good luck...Lee
Jan 14, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
Pool & Spa Logo
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
