Question about Kitchen Appliances - Others
How can i replace heater element in rice cooker?
SOURCE: Panasonic SR-MM10NW Neuro Fuzzy 5-Cup Rice Cooker
After extensive web search, this seems to be the only Website listing Panasonic parts:
http://www.partstore.com
Posted on Oct 25, 2008
  • 6 Answers
SOURCE: Rice cooker stopped working
Sounds like the Thermal Fuse inside is blown unscrew the 2 screws on bottom of the cooker you should see a small 2.5 inch insulation wrapped wire leaving a ceramic mounting block to one of the element poles. Now you take off the nut and unscrew it from the pole. Cut off the insulation and underneath will be a Thermal Fuse. If you have a Ohm Meter or a continuity tester attach each lead to either side and it probably will test negative. Part # is written on the Thermal Fuse. Probably a
SEFUSE
SF188E
192C
10A
250V
They are for sale on ebay for $9.99
I'm trying to get mine cheaper elsewhere
Posted on Jan 09, 2009
  • 54 Answers
SOURCE: Need instructions for National Rice-O-Mat Rice Cooker SR 10GHN
You can just go to a web site and look search for Rice Cooker Steamer. And find some important information.
Posted on Jan 11, 2009
SOURCE: Rice cooker power cord
Thank you. I resolved the problem myself. I found a power cord from my slow cooker and it works.
Posted on May 05, 2009
pabloloco
  • 2335 Answers
SOURCE: Rice Cooker Instructions
For Queenmom and anyone else looking for the manual for a Black and Decker Flavor Scenter Handy Steamer Users Manual, I just stumbled across one. Here's the link:
http://useandcaremanuals.com/pdf/HS90038.pdf
I hope that helps.
Posted on Sep 19, 2009
Hi i need to find the wattage for my cooker pls it is dfs903 thank you
a cooker
wattage should be close label near to the 240 volts
heater elements go from 2500 watts to 1800 watts
the oven bulb is 40 w
list of parts for it has pictures to compare yours
Find Gas Cooker Spares Electric Cooker Spares
is this the beast ......dfs903
Delonghi Professional DFS903 90cm Cooker 26321246-i2ml2krc5iwy0vdznkpglsjk-1-0.jpg
Oct 21, 2016 | Kitchen Appliances - Others
I have a rice cooker and steamer can I make rice pudding in it and how would I do it
no to rice pudding the steamer is not designed that way the mixture of liquid would seep through the steam holes at bottom and cause damage to the element
Sep 09, 2016 | Kitchen Appliances - Others
Every time I cook rice in this rice cooker, the rice is burned & I have to throw it out. Help.
The Manual for the Rival RCS200 Rice Cooker can be found here:
http://www.rivalproducts.com/manuals/MANUALS/RCS200_43_68557881.PDF
Make sure you are following the directions for the correct amount of water to rice.
It could be that your unit is not switching from cooking to warming at completion of the cooking cycle. It should automaticaly turn to the Keep Warm Setting when it detects a temperature of 212 degrees F.
The manual advises that there are no servicable parts. If this is a new appliance I would recommend returning it to the point of purchase. If this is not possible try contacting Rival Customer Service to see if they are willing to assist with replacement or repair: See here:
https://secure.rivalproducts.com/ContactUs.aspx
Oct 26, 2011 | Rival RCS200 20-Cup Rice Cooker
My toyomi rice cooker model trc56,when plucked in nothing works???
The heating element is probably bad...
Here is a tip that I wrote about rice cookers and the amount of rice and water needed...
How much Rice and Water go in the Cooker
http://www.fixya.com/support/r5396567-much_rice_water_go_in_cooker
heatman101
Aug 10, 2010 | Kitchen Appliances - Others
3 CUP AROMA RICE COOKER WILL NOT HEAT --ONLY 4 MONTHS OLD
1. Is the cooking pot filled with water? If there is no weight, it will not turn on.
2. Is there a pilot light? If no power, you have a unit that was probably returned by someone else.
3. The heating element/plate thermal fuse may be blown. Either replace the fuse or the whole unit.
Mar 06, 2009 | Kitchen Appliances - Others
Farberware 10 cup rice cooker blows fuse after replacement
yeah it has a short in it or just a wire lose from the heater.
open up and check. If you have an ohm meter check the heater. It should not be infinit
Jun 17, 2008 | Rival RC160 16-Cup Rice Cooker
Kitchen Appliances - Others Logo
23 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
