Question about Bobcat Garden
How to install belts on bobcat zero turn model 942215
Bobcat 442 ser#522311260.No power to start switch. FA is good
Check your manual. There are many safety switches on those machines. I'm not fimiliar qith that model but on other machines like that you can't start is until door are closed, seat is sensing weight on it, seat belt is on, break pedal is depressed. If any of those fail you won't able to start.
Dec 03, 2017 | Bobcat Garden
I have a bobcat 642 that will not turn left or right. Just bought it at a clearing sale. Do you have a manual for this model please
go to this site and download the underlined manual.:
Dec 06, 2016 | Bobcat Garden
How do I install seatbelt on zero turn?
Seat belt kits are not available for all models. There are seat belt kits for most larger Z-turns. Check with your dealer for part number for your model. Have model and serial number available.
Sep 11, 2015 | Husqvarna Garden
Bobcat Creep, how do I stop it
as the equipment ages so do its springs or detents , some models of skidsteers have a "zero" pressure ballance adjusting bolt on top of the hydrostat drive housing , and some of them don't , they got them dreaded operator interface modules ,you cant do nuttin with !! anyways look real carefull at base of handles mounting you might see a spring or two that you can change for about five bucks that'll get you going
Apr 19, 2015 | Bobcat Garden
The narrow fan belt next to the wider one under the shroud is broke. Bobcat overheats. What is that belt called? How easy to fix?
Hi Ken:
If it's overheating then the water pump and / or the fan are not turning. Should be quite straightforward to replace, especially if you have the broken one to match for the new one.
Mar 30, 2015 | Cars & Trucks
My bobcat has been overheating after 20 minutes and the fan is not turning over what can I do
Have the fan replaced, it prevents it from overheating and will keep your repair cost down.
Jun 03, 2012 | Computers & Internet
Bobcat 48
sounds like the belt is on wrong
Apr 06, 2012 | Bobcat Garden
Garden Logo
35 people viewed this question
Top Bobcat Garden Experts
Daryl Gleaton
Dan Apthorp
Bill Boyd
Are you a Bobcat Garden Expert? Answer questions, earn points and help others
