We have a XMT 300 and the display seems to have quit. Occasionally it will read -1
2 Suggested Answers
  • 1326 Answers
Coould be excitor coils, relay or main control board. Have to have em all tested to narrow down.
Posted on Sep 22, 2009
Burning up tips fast with Miller S-22A
tooslow and probaly too close to work piece try turning heat down a little also make shure you have a good ground/ maybe angle your gun a little more
Dec 17, 2012 | Miller Welding Tools
I have a miller xmt 304 i bought it used. i have a 12vs wire feeder on it and im not getting power to it. any suggestions on what the problem could be
Ok, let troubleshoot this one.
There is only two connectors on your 12VS wire feeder; the lead cable that goes to the + side of the XMT welding machine and the VS cable (Volt Sensing) that goes to you work piece joining the ground cable (don't forget the ground clamp).
a) The mode switch on your XMT must be on V-sense feeder.
b) Your 12VS feeder depending on what kind of wire you are using (innershield) negative side or gas wire + side.
That's it. If there i no spark, there is something wrong with your XMT.
If this was useful to you please vote. Thanks.
Apr 01, 2011 | Welding Tools
Alesis RS300 Reference Amplifier Channel malfunction...
You say "it seems like". Do you mean to say it is intermitent, or did it start cutting out and then finally fail? If that is the case I would look first to replacing the relay in contention in this thread.
It's a cheap fix and will eliminate one potential cause. The Radio Shack part is widely available.
My RS-300 had started dropping the left channel, but occasionally both. It is possible that the relay has failed on one side and thus you have a dead channel...I did the fix and am now quite happy with the amp
Dec 26, 2009 | Alesis RA-150 Amplifier
Sep 22, 2009 | Welding Tools
Nokia 6301 won't turn on properly..
Your display circuit is broken, even if the LCD-panel,
seems to be ok the display is damaged.
This is a very common problem in Nokia phones.
The only way to fix this is to change the display.
You need a T-6 Torx Skrewdriver to do the job.
You can find displays for fair price at :
This is your solution! Please vote!
Feb 01, 2009 | Nokia 6301 Cellular Phone
Sola SL D-104 Digital Frame Reading Flash Drive Pictures
I too gave a Sola SL D-104 for Christmas with 580 pictures on an 8 GB flash drive. I had no problem with the frame reading and displaying all pictures in continuous slide show plus looping at the end and starting over. Simply use the "Slideshow" button on the remote. Perhaps there were hardware problems with the drive or the frame. My 580 .jpg photos only used about 0.9 GB, so it might be easy to try another drive for only 300 shots. Were they all .jpg formats? The frame is fussy as to file format. Hope that helps.
Dec 18, 2008 | Cameras
In the - IND. XMT JOURNAL - the destination number is wrong
to set the com journal, press function-7-4-set-1-2-set-2-set-stop
to check the phone number you could look in function-7-1-set- keep hitting set till you see the phone number
Dec 09, 2008 | Panasonic Panafax UF-585 Plain Paper Laser...
HP psc 1315v (printer, scanner, copier) Will not print
The test page printing out every time it gets turned on is the printer's way of telling you it wants to be calibrated. Lay the test page on the scanner (follow the pictures on the test page) and scan it in. This should fix that problem and the "occasionally after waiting, something prints" problem.
Unfortunately, I don't have an answer to the "E" on the display or check printer cartridge light. Hope this helps!
Sep 06, 2008 | HP PSC 1350v All-In-One InkJet Printer
Minolta x-300
The X-300 is very similar to the X-700 minus a few features like program 'P' mode. The VF displays are very similar for metering and exposure. You can read the users guide for the X700 here on
Mar 03, 2008 | Cameras
Televison & Video Logo
Top Televison & Video Experts
