Question about Lands Phones
Just installed a gigaset a120 trio. Handset volumes set to 5(the highest) Have rung the number but non of the phones are ringing. Have previously set up another gigaset without any difficulty
  • 106 Answers
SOURCE: Problem Siemens Gigaset 4000 and 4200
If you had a storm, and the only handset that works shows line in use, then your base has gone bad and needs repair. The reason the phones are flashing base 1 or something to that effect is because they don't see the base anymore, which typically means no phones will see your base, so its odd that one phone is actually seeing the base. Either way, you can try re-registering the phones to the base, but if you get the line in use after they register (if they will register), then your base is bad. If they won't register, your base is bad. For additional assistance you can go to
Posted on Jun 16, 2008
SOURCE: samsung phone does not ring
thanks for the help it worked
Posted on Jul 11, 2008
when someone trys to call the phone says please dial the desired number
Posted on Jul 26, 2008
  • 39 Answers
SOURCE: uniden 5.8Ghz phone.
You need to reset the main base unit. Unplug the power from the back of the base. While the power is disconnected, press and hold the delete key while reconnecting the power. Wait for a long beep tone. When the display shows 88 or P, press play button one time. If you have a phone without an answering machine, disconnect the power from the back of the base, press and hold find hs button while reconnecting power.
Posted on Mar 17, 2009
  • 25 Answers
SOURCE: Samsum Propel phone only works for calls in speaker phone mode
did you get it wet
1) try holding pound
2) by the camera key theres this tiny phone with waves around that
Posted on Aug 13, 2009
Gigaset A490 speakphone not working
Does the SPEAKER button light up red when you press it?
Does it work on one handset but not the other? Or does it not work on any handset?
It's a relatively common problem with these phones. It's more than likely broken...
Dec 12, 2012 | Siemens Gigaset A490 Twin Cordless Phone
Thank you for these instructions. I have Siemens geigaset A120 with three handsets and one of the handsets stopped working about a year ago and my previous tries att registering it at the base station had failed and I was about to give up and buy a new set for 80 Euro, but I decided to give i one more try at registering and it worked the third time around. So do not give up. When one your hand sets stops working (no dial tone and can not call from it) try re registering as described above.
Nov 23, 2012 | Siemens Gigaset A120 Single Dect Cordless...
HELLO EVRY BODY, We have a cordless phone gigaset 4015 with gigaset confort handset 4000 the only problem is when we receive a call , we can hear only the first ring and the handset still blinking...
First of all you have to change the Dialing mode, DTMF or Pulse, according PABX type, ask to technicians!
Second step is to set up the Flash Time from 80 to 800 ms, again in dependency of your PABX Operating Instructions. Cheers and good Luck.
Oct 09, 2017 | Siemens Gigaset 4015 Cordless Phone
Siemens gigaset 2420. how do i reset pin on desktop base corded station?
  1. I forgot the PIN number on my Gigaset 2XXX system base station. What can I do?
    Please complete the following steps to reset the system PIN on 2XXX back to 0000. On the system base station:
  • Press MENU.
  • Scroll to SYSTEM SETTINGS but do not press SELECT.
  • On the keypad, enter *65# (Star, 6, 5, Pound).
  • It will display "SYSTEM PIN RESET" and return to the idle screen.
  • Note: The base station system PIN will be reset to 0000
  1. I forgot the PIN number on my Gigaset 2XXX cordless handset. What can I do?
    Please complete the following steps to reset the cordless handset PIN on the 2XXX back to 0000.
  • Press MENU.
  • Scroll to MOBILE SETTINGS and press SELECT.
  • Scroll to LOCAL SETTINGS and press SELECT.
  • Scroll to CHANGE PIN and press SELECT.
  • Note: The handset PIN will be reset to 0000
Jan 05, 2010 | Siemens Gigaset 2420 Cordless Phone
I need to get a replacement battery for my Simens Gigaset A120
I usually recommend but I couldn't find this battery there. Here is a link for a very reasonably priced battery for your Gigaset A120:
May 13, 2009 | Lands Phones
Gigaset 8800 PIN reset
  1. Turn the handset off by pressing and holding the PWR key.
  2. While holding down the keys 1, 4, and 7, turn the handset back on.
  3. It will display "Handset Service".
  4. While this message is displayed, type in the numbers 4 6 8 5 4 6 3 (the word "hotline") on the number pad.
  5. The phrase "Settings Reset to Default" for a second or two and the handset will power itself off.
Note: When you turn the handset back on, the handset PIN will be reset to 0000.
Dec 26, 2008 | Siemens Gigaset 8800 Cordless Expansion...
GE 28851 base handset #1, will not save ringer tone or volumn I selected. Brand New.
As it turns out, the primary base handset did save the newer selected ring tone and volume level setting.
However, the base maintains its own ring tone and volume level setting from factory.
Therefore, the base will present its own settings along with the handset setting during an incoming call.
So, one has to lower the volume of the base (in non-talk mode). The base should display in window: LO.
Then, only the ring tone and volume level selected for handset will be presented during an incomiong call.
How did I do????
Jul 09, 2008 | Uniden Cordless Phone
GE 25931 Trio Cordless Phone Answering Problem
Try charging the phone on the main handset - Good luck!
May 21, 2008 | GE 25931 Trio Cordless Phone
Ringer settings on 8825 base unit
You can adjust the volume and pitch of the ringing by pushing Menu, scroll forward to Desk Station Settings, push Select, scroll to Ringer Volume and you can adjust the ringer volume, and in that same area adjust the pitch. So you might want to make line 2 ring lower, and with a different pitch so it is not distracting, but still notifies you of an incoming call that is not line 1. The same goes for the handset.
Apr 18, 2008 | Siemens Gigaset 8825 Cordless Phone
No Power to Cordeless Phone
I have been using siemens gigaset4215 for quite a while if worked well. Couple of days back when I tried to change name and intercom number on two hand sets one working well but other continue displaying 'Searching' and flashing. I tried but could not bring it to normal working mood. Any body has any sugestion?
Aug 14, 2007 | Siemens Gigaset 4000 Phone
Lands Phones Logo
56 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
