Question about Zanussi Dishwashers
Zanussi tempoline dishwasher no power ..no lights..known good socket and fuse
5 Suggested Answers
  • 3 Answers
SOURCE: Right turn or brake light not working
Questions? Do any of your brake lights work? Including Center Stop? Do your parking/taillights lights work? All your bulbs are multi-filiment bulbs that work through mulitple sources. Knowing which bulbs are doing what under all conditions might help narrow down the problem. Meanwhile, check for continuity between, stoplight switch and multifuntion switch (white wire). Also, check DrkBlue/White from MFSw. to Boby Control module. BE SURE to use a low inpedance tester to protect your modules. The DrkBl/Wh wire is your rigth side input. I may be a good idea while testing these wires to wiggle them to look for intermitent shorts.
Posted on Jan 30, 2009
SOURCE: NO TAILLIGHTS, FUSES AND BULBS
it sounds like the ground wire for the rear lights has either come loose or is corroded.
Posted on Feb 22, 2009
MNfisherman
  • 11896 Answers
SOURCE: brake lights aren't working
Likely the switch behind the brake pedal is out of alignment or is faulty as long as fuses, bulbs, and relay are good.
Posted on Jun 10, 2010
  • 6277 Answers
SOURCE: live in Bulgaria bought a
Sorry but this forum does not supply manuals direct; it's just made up of ordinary guys and gals, probably at home, with experience of addressing problems and helping for free on the web ;-0)
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
John C
Posted on Feb 26, 2011
Failure to start cycle
WHAT IS THE EXACT BRAND/MODEL AND NUMBER OF YOUR APPLIANCE...?
DID YOU TRY TO RESET THE UNIT, BY UNPLUGGING IT FOR A WHILE INTO THE POWER OUTLET...?
Sep 24, 2008 | Zanussi 24 in. DE6544 Built-in Dishwasher
My cig lighter dose't work in my 1992mitusbishi Galant
possible blown fuse or bad ground check wiring to make sure all wires are pluged in if so replace lighter
Feb 08, 2016 | Cars & Trucks
How do I fix my electrical problem.My taillights and brakelights are not working All other lights are working.Fuses seem to be working alright.
Troubleshoot your lights
Fixing lights can be difficult:
You have a tail or brake light that doesn't work, but you replaced the bulb and no change. You'll have to troubleshoot, so buy a simple volt/ohm meter.
Be sure the power is off and no power on any of the socket pins. Then clean the light socket and connection pins with a stiff brush or steel wool.
First, measure all the light socket pins for power. If you don't see any voltage, must be a fuse out or a broken wire or you aren't getting a good solid ground reference.
Turn power off and make sure the socket ground is really ground by using the ohmmeter between the socket ground and a known good ground. If the ohmmeter reading is 1 or 2 ohms the socket is probably good. If the ohmmeter measures higher, then the ground connection is bad or ground wire is broken. Try to trace the ground wire, run your own wire if you have to.
Once the the socket ground measures ok, then you have to determine which hot pin is bad.
There are two hot pins, one for each filament, tail and stop light.
Pick one and measure the voltage referenced to the, now good, socket ground.
You should have power now, so try a bulb in the socket.
Feb 08, 2015 | 1992 Toyota Pickup
Zanussi tempoline not working, son twisted nob mid cycle it then stopped and wouldn't drain. Now not doing anything! Any ideas? I assume its a error code flashing up
The first step of a dishwasher is a drain / rinse drain. I would turn the dishwasher off at the socket, turn the nob to the off position only turn this in a clock wise direction IE: the direction the nob would naturally move. Turn on back at the wall and start as you would normally. The dishwasher will empty the water out in its first step then should cycle through as normal.
Feb 08, 2013 | Dishwashers
End of program?
check with Zanussi website tech support .
Dec 02, 2017 | Zanussi Washing Machines
Hi, my zanussi izzi dishwasher has started acting up, it will start a cycle but after a couple of minutes it trips out the main RCD in the fuse board, now i have isolated it to the dishwasher itself and...
If it trips after a few minutes of coming on , it is probably the heater which is faulty , disonnet it and try , if it doesn't trip you need a new heatee
May 02, 2017 | Zanussi 24 in. IZZI ALU Built-In...
Live in Bulgaria bought a zanussi tempoline 45cm dishwasher zds105 but need a manual that is in english as I cannot read Bulgarian,Please can you help
Good luck,
John C
Feb 26, 2011 | Washing Machines
Dishwasher won't power up; have checked fuse; no lights coming on, on front panel
Check the house electrical panel for tripped breaker or blown fuse. Check power wiring from washer to wall outlet. Is it a cord that is plugged into a socket, or is it direct wired? If it is a socket, make sure a lamp will light if plugged into the same socket.
Jul 16, 2009 | Dishwashers
Dishwashers Logo
185 people viewed this question
Top Zanussi Dishwashers Experts
Owen Barnes
Paul Carew
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
