Question about Vacuums
Vapour mop x700 black button lower part back of mop body is loose, problem.
Low power from steam mop
Try to be a little more vague! Model? Age of steamer? Rate of use?...Try a couple of drops of vinegar in with the water you use to fill your steam mop. The heating element that heats the water is probably oxidized, especially if you use tap water to fill it. You should only use distilled water in these mops. Some lower end steam mops have a handle that compresses, as you push the mop forward, which essentially makes the mop steam more, the more you "pump" the handle. Hope this helps!
Jan 29, 2015 | Vacuums
Cancel last order for Steam mop pads
-No body here know the phone number. You have to look inside your receipt.
Good luck
Mai
Jan 12, 2015 | Euro-Pro Shark Steam Mop - Gray/ Purple...
O-Cedar Pro-Mist trigger doesn't work
This person is asking about an O'Cedar Pro Mist Mop. Not a vacuum or steam mop...
I too have problems with the pro mist handle not working... I called the customer care line at 1800-543-8105 and they are replacing my mop for free. You can also try to take it apart and fix it yourself, but I did that and I cant remember how it goes back together! lol Basically a spring comes loose from the pole inside of the mop handle, and that is why there is no tension in the trigger.
Feb 19, 2012 | Vacuums
The body of the mop does heat up; but the heat does not extend to the mop head.
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the
Shark Manuals that you need.
heatman101
ll;'
Feb 02, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Hi, My Shark Pocket Mop steamer isn't getting steam to the head, and when I removed the head I found that there is calcium build up on the opening of the body. What is the best waytto remove it? gnc
heatman101
Jan 17, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
I bought a reconditioned mop 7 months ago. It worked fine until tonight. The light comes on, but the steam is not hot, well, the pad didn't get hot at all. I heard like a small explosion of some sort....
heatman101
Nov 13, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Will not release steam. Body of steam mop gets hot, but no results
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Here also is a link to get any of the Shark Manuals that you need.
heatman101
5r
Aug 16, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
I just got the steam mop but it came without instructions, I don´t know how to assemble it. I´m not sure if I´m missing pieces
There should only be 3 basic pieces to this machine. The body housing, the top handle and the floor nozzle. The handle attaches to the body with a bolt and a nut and then the floor nozzle is just pushed into the body housing. That should be it.
Nov 30, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Steam Tek mop doesnt steam anymore
We had a similar experience. I opened the head to look if the steam line was clogged. There was no sign of dirt or calcium build up, so I opened up the body. Found that one of the heater wires had come loose. The connector, which is crimped to the wire, was charred. Could be a potential fire hazard!
I notice that a similar product marketed under the Thane brand has been recalled for wiring issues.
We will try to return this mop for a refund.
Jul 29, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Vacuums Logo
43 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
