Started leaking under washer on drain cycle,need instructions on access to check hoses.
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 6 Answers
Pull front cover off 2 clips on top each corner back near lid
the hose came off or its leaking if the drain line could also be clogged and its backing up threw line
Posted on Apr 25, 2017
My GE washer leaks water during spin cycle only, seemingly from bottom of valve(?) where water hoses hook up, hoses look to be in good shape, only a year or so old.
If it is leaking at where the drain hose comes out of the wash machine, make sure the plastic spider clamp is seated securely in the groove on the drain hose. If that's not it, then, yes, you'll need to open up your washer to gain access to the inside of it. I don't know which model GE wash machine you have, but most of the GE top loaders can be opened by following the instructions in this youtube video:
Oct 19, 2014 | Washing Machines
Have an f21 code everything shuts dow
"F21" is a Drain Problem error. This can occur if the drain pump or hoses have become clogged, the drain hose is kinked, or if the drain pump is too long. If you haven't had any problems until now, I would bet you have an obstruction in your drain pump. The check the pump, follow these steps:
  1. Unplug the washer while servicing inside the unit.
  2. Remove the lower kick panel under the door by removing the three 7mm screws under the bottom edge of the panel. HINT: Use a couple of blocks of wood to prop up the front feet of the washer to gain better access to the screws. Once the screws are removed the panel should drop down, and then pull off. If the panel becomes stuck, a slight tap on either side will dislodge it.
  3. Locate the drain pump. It will be located directly under the wash tub (it is the only pump this washer has).
  4. There is an access removal cover on the pump that can be removed to clean out the trap.BEFORE doing this, it is strongly recommended that you remove all residual water from the wash tub & drain line or you will have about a gallon or so inside your washer and on the floor to clean up.
  5. Here's a helpful way of quickly removing the residual water. If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall and pull a vacuum with the shop vac. This will empty the wash tub, pump and drain lines. If you don't own a shop vac, grab a bunch of old towels and open the access on the pump slowly so that it comes out at a trickle. Allow the towels to soak up the majority of the water. Close the access and stop the water if you need to get additional towels.
  6. Open the pump access and remove once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there's nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
  7. Clean out the pump thoroughly and reinstall the access cover. Make sure the cover is snug, but do not over tighten.
  8. Place the drain hose back in the standpipe (IMPORTANT - DO NOT FORGET!).
  9. With the bottom panel still off, plug the washer back in and start a normal wash cycle.
  10. Check the drain pump for leaks as the washer fills. The pump is gravity filled and will hold water even it is not pumping. Allow washer to run through diagnostics until it begins the wash tub tumble cycle.
  11. At this point, you can stop the cycle by pressing PAUSE/CANCEL 2 times. The drain pump should energize and the washer will begin to drain.
  12. If the drain pump works normal and there are no leaks detected, reinstall panel and tighten screws.
If you check the pump and the problem still persists, replace the drain pump. You can find the necessary parts for your washer at searspartsdirect.com. Just type in your complete model number (located around the door opening) and follow the links. If the pump is not available there, I would also recommend repairclinic.com and pcappliancerepair.com. I hope you find this information helpful.
Jun 27, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My Gallery series Front load washer was making a loud buzzing noise and was not spinning. when i took my soaking wet clothes out there was a puddle of water inside. I tried the drain cycle and a new wash...
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine.In this case you need to check the free running off the mottor manually, check the voltage on the motor,If absent the controller is a suspecct. check the capacitor of the motor. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occurs. Removing and Cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there is gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
May 03, 2011 | Frigidaire ATF6000ES Front Load Washer
Water has started pouring out from under my washer
Hello, you've indicated this problem only arrises during the rinse cycle, is that correct ? The leak doesn't occur during the wash cycle initial fill level ? I want to distinguish the difference because there has been a repair tip issued by whirlpool for the duet and sport washer's. This may be applicable to your machine. If it is indeed only during the rinse, the problem is within the door assembly. Specifically the glass and it's "seat" to the frame. Let me know, I'll watch for your reply. macmarkus :)
Mar 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Water Everywhere
Look for loose, cracked, pinched, broken hoses to and from the water pump or leaks from the water pump itself. The outer drum could have a rust-through that leaks. This can be repaired with epoxy, but the inner drum must be removed to access it. The cabinet top is opened by using a putty knife or similar tool to push straight back under each front corner which releases a spring latch. Sometimes, the drain hose outlet is pushed from the house drain by high water flow. Tie the hose to the drain with tape or cord. Fill the tub with water, then stop the cycle and watch for leaks.
Aug 07, 2009 | GE WBSR3140DW Top Load Washer
Kenmore 800 series washer stopped draining
If you experience a problem where the washer does not drain properly or the drain pump makes excessive noise, here's the information you need to check the drain pump:
Symptom: PUMP IS RUNNING, BUT NOT DRAINING PROPERLY.
4. There is an access removal cover on the pump that can be removed to clean out the trap. BEFORE doing this, it is strongly recommended that you remove all residual water from the wash tub & drain line or you will have about a gallon or so inside your washer and on the floor to clean up.
9. With the bottom panel still off, plug the washer back in and select the following on the operator console - DRAIN SPIN, NO SPIN, and then press any button under OPTIONS 4 times (it must be the same button). "C00" will show on the console display as the washer begins diagnostics mode.
11. At this point, you can stop the diagnostics procedure by pressing PAUSE/CANCEL 2 times. The drain pump energizes and the washer will begin to drain.
12. If the drain pump works normal and there are no leaks detected, reinstall the bottom panel and tighten screws.
NOTE: It is normal to have residual water left inside the wash tub under the wash basket. This is why it is important to leave the door ajar when not in use so this water does not become sour.
http://media.fotki.com/1_p,wktwwdgrkbbfrdgxgtqsskgwtqkq,vi/kstdgfskbxktqtggsqb/1/1303472/5961857/image64920img-or.gif
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 04, 2009 | Washing Machines
Leaking wash machine
Depending on where exactly the leak is coming from, it could be a drain hose, drain pump, or tub seal. If this is a top-loader, here's how you can tell:
1. If the leak is coming from the BACK area under the washer, this can be caused by a leaking fill hose, dispenser hose, drain hose, or fill valve.
2. If the leak is coming from UNDER the center area of the washer, this could be your tub seal, a crack in the tub, or an air dome hose leak. NOTE: If the air dome hose is leaking, the washer will fill continuously and not turn off.
3. If the leak appears to be coming from the FRONT under the washer, this could be your drain pump, or drain hoses.
Posting a model number, could assist with determining how your washer is configured. I suspect you may have a drain pump leaking as this is the most common cause, but I want to be sure.
Apr 27, 2009 | Washing Machines
Kenmore elite dishwasher model 665.16293402 will not start cycle
Mar 15, 2009 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
