Question about Dishwashers
My dishwasher wont start
My dishwasher was working fine until yesterday. But today nothing! I have checked the fuse box and the door switch seems to be fine. Any ideas??
    Scholar:
  • 117 Answers
Sounds like you need to check for power to the unit. Access is at bottom of dishwasher under panel. Next you will see the wiring coming into an enclosed electrical box. you will need to get to wires and check voltage on black hot wire to neutral with a voltage meter. If you have power but still doesn't work then at least you know the problem is with the unit and not the incoming power.
Posted on Jul 25, 2009
My roper dryer worked fine yesterday. It won't work today
remove back cover then locate the blower housing in the back,its round on this is a thermal fuse appx. 1" X 1/4" with 2 wires from it,this is the thermal fuse test it,if its open on continuity its bad and the dryer wont operate the pat number is FSR# 3392519
May 21, 2012 | Roper REX3614KW Electric Dryer
I have a servis easi logic 1300 working fine yesterday but today when i press the start button nothing i have checked the fuse and that is fine
It could be many things but the most common is the door lock ( electrical switch with three wires )
Jan 22, 2010 | Washing Machines
Frigidaire dishwasher fdb2415lf will not turn on. Was working fine, no fuse blown, not disconnected.
I have one of these modles and yesterday after it finished I noticed a lilttle green light on below the main options, a little lock that is telling me to "hold to unlock" not sure what that means, so tried this morning to "hold" nothing happened as need to run the machine, and right now there is no response. HELP!!!!!!!
May 31, 2009 | Frigidaire 24 in. FDBB944C Built-in...
My dishwasher will not start
Hi!
Most common d/w power is 120 volts, check for 120 volts with a volt meter at the main power harness where it enters into the dishwasher, you will have to remove the lower access panels to get to the power box. Dishwashers also have at least one and most newer dishwashers have two door switches that must be checked. You will find then behind the console at the door latch area. Please see this picture of what the dishwasher switch looks like.
Please rate this solution as Fixya if found useful.
Please ask for any clarifications.
Thanks
Rylee
Mar 13, 2009 | Frigidaire Dishwashers
Maytag dependably quiet plus not starting
check connections to the door switch.
Nov 04, 2008 | Dishwashers
PDW7880G-No power to control panel. Just stopped at the end of drain cycle
Solution Found!!
Checked for power to dishwasher. According to the manual, shutting off the breaker for more that 30 seconds resets the dishwasher. It did!!! The dishwasher works fine now. THANKS!!!
Feb 19, 2008 | GE 24 in. Profile PDW7880G Built-in...
No power to control panel after power surge
1. No power to the dishwasherMake sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
2. Door switch
Replace if defective.
3. Timer
Replace if defective (note: uncommon problem).
4. Selector switch
Jan 05, 2008 | Maytag MDB7100AWB Dishwasher
Wont start
Give it a firm push over the door latch once you've closed the door..it might be the door switch not activating. oops.... first and formost isolate from power for 5-10mins and try
Dec 28, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
115 people viewed this question
Top Dishwashers Experts
