Question about Sylvania SRPD442 42 in. EDTV-Ready Plasma Television
Sylvania SRPD442: picture has lines and particles in it, can't make picture out
The screen is not cracked as can be seen with the eyes but has vertical lines and particles in it and you can not make the picture out. It also has a horizontal lines (1 inch wide!) but all the lines (vertical & horizontal) move somewhat. Is this a replaceable board problem or a badly aged screen? I am looking into buying another unit with a busted screen to repair it but don't want to spend the money if this screen is bad. Also, can the bulbs / back lights be replaced in this screen? Any help would be appreciated!
  • jmgrizzle82 Jan 04, 2009
    My picture flickers a horizontal line across the screen, sometimes more frequently than others, but dosent affect sound at all. Tv repair people said the boards are fine and cannot find a problem. Worked fine for a couple of days when brought back but is at it again. Any help would be appreciated
  • Sylvania Master
  • 1,689 Answers
The fault can be the screen itself, or one of the driver boards for the screen. This has to be verified by trying the boards.
I don't know for your model if the backplane lamps can be replaced. In most of the models they can be.
Jerry G.
Posted on Apr 18, 2008
When you start light turns green but go's back to red . sylvania 6842thg
Mar 18, 2011 | Sylvania SRPD442 42 in. EDTV-Ready Plasma...
My sylvania monitor is say format not suppoted when i connect it to my mac
You did not specify Mac model nor connection cable. Let me make a stab at it. ED means this is a 480-line interlaced or progressive, not sure. So you will need to select 640x480 plain or stretched. This based on what my MacBook Early 2009 white allows. I assume you are using an HDMI or DVI connection from a mini-DVI (mine) or the newer mini-DisplayPort. (I bought an ~$10 adaptor from monoprice.) -Ken
Apr 10, 2010 | Sylvania SRPD442 42 in. EDTV-Ready Plasma...
I have a Sylvania 42 inch Plasma HD TV. It is 3
Before taking this to a local repair person, I suggest you check with your cable provider. See if they are having trouble with their HD transmission and then have them test your lines. Out here in Arizona with have constant problems with HD due to heat, rodents and poor installations. Your DVR only recorded the problems that were on your set. If these prove fruitless then take the TV to a reputable repair person.
Good Luck
Sep 24, 2009 | Sylvania SRPD442 42 in. EDTV-Ready Plasma...
My Crystal Eye shows horizontal lines when taking pictures
this lines are came from touching the crystal eye ! so use your warranty to go to repair your crystal eye or they will change it. your fixer ,
fixer lover
Feb 21, 2009 | Acer Aspire 3610 Notebook
If the line is vertical in nature then most likely then the plasma display panel is bad and won't be worth fixing because of cost. If the line is horizontal then the issue might be a lower or upper Y-buffer module.
Jun 08, 2008 | Sylvania SRPD442 42 in. EDTV-Ready Plasma...
Samsung 46" LED flat screen TV cannot acsess Caption.
Call the tech support for your TV set. There may be a servcie setup fault, or a component failed that controls the placement of the text, or it may even be a user setup that can be done.
If there is a failure, the set will have to be serviced.
I would guess that you refered to the user manual for any possiblity that there is a setup for the placement of the text...
Jerry G.
Dec 03, 2007 | Sylvania SRPD442 42 in. EDTV-Ready Plasma...
This can be many types of faults. The set will need shop service. There may be cold solder connections on one or some of the boards, or there may be come components that are intermittant. In anycase most of the time, there will be the need for board replacments.
The cost for this type of repair can be fairly expensive. I would consider investing in to a new set because after having this serviced, there will still be many older components in the set that can potentialy fail.
Jerry G.
May 22, 2007 | Sylvania SRPD442 42 in. EDTV-Ready Plasma...
in this model, the ribbon cable conection fail many times, and tis sound to be the problem, just open it and secure all sokect conection better get a tech to do it ...good luck
Aug 09, 2006 | Sylvania SRPD442 42 in. EDTV-Ready Plasma...
Sylvania SRPD442 no picture
Your problem is probably in the power supply as theres a voltage called the sustain voltage that is always keeping the screen charged so the address lines will activate the screen and make it light up Via the Microprocessor and the video processor. This is not a repair for a handy person as this set, you can cause more problems Please seek out a trained tech for this set. Good luck
Jul 24, 2006 | Sylvania SRPD442 42 in. EDTV-Ready Plasma...
TV goes on for minute, and then goes to standby
This could be anything but is more than likely a problem in the power supply or control board. There really are not any user serviceable parts in these units and they have dangerous voltages. Repair is best left to a professional.
Jun 15, 2006 | Sylvania SRPD442 42 in. EDTV-Ready Plasma...
Sylvania SRPD442 42 in. EDTV-Ready Plasma Television Logo
280 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
