Question about Brother Office Equipment & Supplies
Stack copies on a brother mfd and machine won't print
5 Suggested Answers
  • 77 Answers
SOURCE: Problem in Kyocera Mita 2035 MFD
when you send a print job it delivere prints without pressing any button. just try it.
Posted on Feb 10, 2009
  • 67 Answers
SOURCE: Will not print. Brother model MFD-665CW. Fault 5A
fuser assembly error need replacement
Posted on Aug 22, 2009
  • 17130 Answers
SOURCE: my phillips laser mfd 6020
The paper feed is detected with a INDETECT sensor/switch and if this is faulty the message will be shown. Also if there is a fault or error in the main board or processor this can be seen.
You can try and remove the panel and get access to the inner tracks to check the sensor , make sure that all connections are tight and there are no loose connections.
Posted on Mar 23, 2011
  • 105 Answers
SOURCE: brother fax machine MFC 495 CW won't print a received fax
This could be issues with your driver. Try to reinstall it (you can download it from the official HP website). If everything fails, try to consult with the users manual
Posted on Nov 30, 2013
I use a Brother printer. It says stack copies and won't print. How do I get it to print?
Follow this earlier link to Fixya
Oct 06, 2017 | Brother Office Equipment & Supplies
How to make duplex copies with a Brother MFC-240C printer
The Brother MFC-240C is a well-performing multifunction color printer. There is a lot that it can do, but one limitation it has is the inability to make double-sided copies. If you need to make a duplex copy of something, you can do it manually by re-feeding the paper once you've copied the first side.
After the first side of the page has been printed, let the paper sit for a minute or so to make sure the ink has dried. Then, put it back into the paper tray on the top of the stack. Make sure the back side of the page (the side that has not been printed on yet) is facing down, and the lead edge of the page (the edge that was fed out of the printer first) is facing toward the inside of the printer, rather than toward you.
Once the paper is set, push the tray back in and print the document or image that you want to appear on the back of the page. If you are printing multiple pages, position the paper so that the page you want printed on first is on the top of the stack.
The MFC-240C was not designed for duplex printing, so you may run into some issues with it, especially when you are using very thick or very thin paper. With very thin paper, the ink may bleed through to the other side of the page. With very thick paper, you may have to let the paper sit for a longer time after the first side is printed, because the ink could take longer to set and dry.
on Jul 06, 2010 | Brother MFC 240C All-In-One InkJet Printer
What do you mean by "stack copies" in brother
Sorting copies using the ADF
You can sort multiple copies. Pages will be
stacked in the order (1, 2, 3), (1, 2, 3)
and so on.
1 Press (Copy) to illuminate it in
2 Load your document.
3 Use the dial pad to enter the number of
copies you want (up to 99).
4 Press Options and ? or ? to select
Press Menu/Set.
5 Press ? or ? to select Sort.
Press Menu/Set.
6 Press Start.
Jun 28, 2011 | Brother MFC 7420 All-In-One Laser Printer
My printer displays Stack Copies constantly and will not print from my computer.
I have a brother hl-2280dw printer with same issue. Happened after I installed a new toner cartridge.
Brother advised re-installing driver. Did not fix problem.
Any ideas....anyone
Jan 19, 2011 | Brother DCP-7020 All-In-One Laser Printer
How can I take off the "stack copies"....slows printing process?
load item to be copied on the top feeder panel and click copy, options, arrow down to stack/sort and select set.
Apr 15, 2010 | Brother MFC-9420CN All-In-One Laser...
How to print using ADF feeder?
You take the paper with face to print Up and the top of the paper towards the interior of the ADF. You can also put a stack of papers. When you press the copy/scan command from the machine console or the computer, the automatic document feeder starts.
Jan 06, 2010 | Brother MFC 6490CW InkJet Printer
All of a sudden, our printer won't print. Won't copy. Was working just fine the day before. Have installed new black cartridge.
We bo't a refurbished machine of the same model for $60 from Staples. We're hoping it lasts long enough to use up all the ink cartridges we have. However that works out, it will be last Brother printer we'll own.
Aug 07, 2009 | Brother MFC-5840CN All-In-One InkJet...
Double sided copying
here is the manual p4 and p16 discuss the topic:
Duplex printing 1
The supplied printer driver supports duplex printing.
Guidelines for printing on both sides of the paper 1
�� If the paper is thin, it may wrinkle.
�� If paper is curled, turn over the stack, straighten it and then put it back in the paper tray or the Manual Feed
�� If the paper is not feeding properly, it may be curled. Remove the paper, straighten it and turn over the
�� When you use the manual duplex function, it is possible that there may be paper jams or poor print quality.
If there is a paper jam, see Paper jams in the User’s Guide. If you have a print quality problem, see
Improving the print quality in the User’s Guide.
Manual duplex printing 1
The machine prints all the even-numbered pages on one side of the paper first. Then, the Windows® driver
instructs you (with a pop-up message) to reinsert the paper. Before reinserting the paper, straighten it well,
or you may get a paper jam. Very thin or thick paper is not recommended.
Simultaneous scanning, printing and faxing 1
Your machine can print from your computer while sending or receiving a fax in memory, or while scanning a
document into the computer. Fax sending will not be stopped during PC printing. However, when the machine
is copying or receiving a fax on paper, it pauses the PC printing operation, and then continues printing when
copying or fax receiving has finished.
�� Manual Duplex
Check Manual Duplex. In this mode, the machine prints all the even numbered pages first. Then the
printer driver stops and shows the instructions required to re-install the paper. When you click OK the odd
numbered pages are printed. There are six types of manual duplex binding directions available for each
�� Booklet Printing
When you want to print a booklet, use this function. To make the booklet, fold the printed pages down the
�� Binding Offset
If you check the Binding Offset option, you can also specify the offset for binding in inches or millimeters
May 14, 2009 | Brother MFC-7440N Laser Printer
Apr 11, 2008 | Kyocera Mita Kyocera 2035 Earbud Hands...
Brother MFC-440CN won't print color
Did you use generic carts?
Do use only original brother ink carts!
Only these have special cleaning fluids mingled with the ink.
There are several advantages, too:
You can run a special cleaning mode (DO insert original carts at first!!!)
Press menue then start bk copy then fourtimes arrow-up.
machine should switch to maintenance mode (buttons will flash).
press 7 then 6 then 4 then start bk copy. machine will refresh ink within the tubes and the print head and run a special cleaning routine. when finished press 7 then 6 then 3 then start bk copy to run a power cleaning. leave the maintenance mode by pressing 9 then 9.
The machine should print without proböems. If there is a poor quality left, the printhead is affected by bad ink and cant be fixed anymore.
Jan 24, 2008 | Brother MultiFunction Center MFC-440CN...
James Cagle
James Cagle
Jim Keysor
