SOURCE: Mitel superconsole 1000
Yes, there are things you can do to clear the locked out phone.
~ The locked means something is wrong with the phone -or- wiring to the room from the Mitel system...
Locked out is like leaving your phone off hook too long, you get that irratating beeping noise, then when the beeping stops, the phone is locked out to save power going to the set.
Ok ~ the first thing I would try, go to the set and play with it, hang everything up and test to see if you can get dial tone... the next thing is change out the telephone set, and test.
If you changed out the telephone set, and there is still a trouble, there maybe a wiring issue, in which case you will require a cable tech to test connectivity...
We have the same problem at our hotel.
You can't fix it at the console, you need to go to the room and unplug the guest's phone from the wall for 10 seconds... reconnect and it is fixed.
SOURCE: Mitel Superconsole 1000 switchboard in a hotel.
Do you know if this is on an SX2000 or SX200? If it's on an SX2000, it is a software glitch and requires upgrade to the latest software. As a work-around, you can de-program and re-program the console. It should clear the problem for a while.
SOURCE: we have a set of
4015 is not part of the ring group and if it is not ringing when the call come in, then you will not be able to answer it unless you enter the code and then the group number that is ringing in If you want to be able to answer on that phone, Have your phone vendor add it to the ringing group.
SOURCE: Mitel Superconsole 1000 not showing alarm when dialing 911
Love your song 'Boys of Summer', and heard it on boom FM today!
How many people phone 911 where you are!
Mitel Superconsole 1000 User Guide - Business ...
https://bcstel.com > doc > Mitel-2ICP-SC1000-UG
PDF
When the console is locked out, it cannot be used to place outgoing trunk calls or to access console functions, except 911 Call alarms. You can still use the ...
94 pages
Viewing 911 Call Alarms - Mitel SUPERCONSOLE 1000 SX ...
https://www.manualslib.com > ... > User manual
Mitel SUPERCONSOLE 1000 SX-200 Manual Online: Viewing 911 Call Alarms. ... When a 911 Call alarm is raised, the console rings and the display shows.
Hi,my mitel superconsole 1000 is not working,on display is
https://www.fixya.com > Forum > Lands Phones > Mitel
Apr 25, 2017 - Hi,my mitel superconsole 1000 is not working,on display is show blinking ALARM above F5 and ... To read a 911 Emergency Call alarm message:
20 Most Recent Mitel Superconsole 1000 Questions & Answers
https://www.fixya.com > ... > Mitel
Press Function 2.Press [ALARM] 3.Press [SHOW 911] This will show what extension calls the 911. 4.Record the number of the extension from which the 911 call ...
Testimonial: "That is the problem. This is a hotel and a guest called 911 but the console did not show any alarms and when we went function to alarms it said "No Alarm"."
