Question about The Watches
I don't know the brand, but its a30m watch. I set the time and seconds. my problem is setting the day. left side is (light/mode) and the right side is (reset/start). Can u help. Thanks
SOURCE: How do I determine which Fossil Model I have.
This may sound obvious, but if you haven't tried it, look for markings on the back of the watch.
Posted on Apr 03, 2008
SOURCE: GapKids Digital Watch - Need to know how to set
Light button is A
Mode button is B
Start button is C
Reset button is D
Standard Time Adjustment:
1) To set time, date, etc. press button B three times (assuming you start in standard time display mode)
2) Press button D until the area you'd like to change is flashing. (i.e.: minutes, date, day, etc.)
3) Press button C to change. Press once for one unit increment of change. Hold for 3 seconds for speedy advance.
4) Press D again until the next area you'd like to change is flashing.
5) At completion of changes press Button B to resume standard time display mode.
Posted on Dec 19, 2008
SOURCE: I cant set the correct day on my digital watch ,The watch has CG onit and is WR 100FT
press mode 3 times to get to time set. then press reset to choose (hour, minute, seconds, day, month, date) and press start to change them. press mode again when finished.
Posted on Jul 08, 2009
  • 183 Answers
SOURCE: Have anAqualite digital watch - and no
Most digital watches set by holding down the mode or restart button until the display begins to flash. You can then cycle through the display and set on the right time.
Posted on Sep 17, 2009
gemineye61
  • 831 Answers
SOURCE: I bought the water resist
Thank you for contacting FixYa.
  • There should be four buttons: mode, reset, start and light. Find the mode button and press it three times until it is in the set time mode.
  • 2 Find the reset button, which usually is located on the bottom right side of the watch face, and hold it until the time starts blinking.
  • 3 Press the start button to change minutes.
  • 4 Press the reset button again to switch to hours. You will know it worked when the hour starts blinking instead of the minutes.
  • 5 Press the start button to change the hour. The watch can handle two modes: standard and military. As you press start, the hour will change from AM to PM, noted by an "A" or a "P" in the top right. When you get through 24 hours, the watch will change to military time and an "H" will be displayed instead of "A" or "P." Keep pressing start to go through another 24-hour cycle and it will revert back to standard time.
  • 6 Press the reset button to switch to the date, starting with the month, and press start to change it.
  • 7 Press reset one last time to switch from month to the day, and again press the start button to switch days.
  • 8 Press the mode button to finish the changes.
  • Posted on Sep 14, 2010
    How to set time on a Lorus watch Z001 X001
    Digital
    Press the button on the bottom left-hand side of the watch to change between the modes on the watch.
    Press and hold the button on the bottom left-hand side of the watch for two seconds until the seconds begin to flash.
    Press the button on the top right-hand side of the watch to set the seconds to "00" and press again to set.
    Press the button on the top right-hand side of the watch again until the hours flash. Press the button on the bottom right-hand side of the watch to change the hour display. Press the button on the top right-hand side of the watch to set.
    Repeat step 4 to set the year, month and day on the watch.
    Analog
    Pull the small knob on the right-hand side of the watch, also known as the crown, out one click.
    Turn the crown until the previous day's date is displayed.
    Pull the crown out one more click. Turn until five minutes ahead of the correct time and then turn back to the correct time.
    Push the crown back to the side of the watch. The watch is now set.
    Mar 31, 2018 | Lorus Watches
    I have a watch that I got from Sears Canada?. I need to know how to change the time. I got it in the summer of 2012. It had 4 buttons, mode (top left), indiglo (bottom left), set (bottom right), and s
    My watch has 4 buttons (2 on the left, 2 on the right) plus the "Indiglo" button. Use the "Mode" button (lower left) to move between the time and the stopwatch. When seeing the stopwatch, hold the "Mode" button. This will get you to the alarm setting mode. Press the "Mode" button again to switch to the time setting mode. Use the "Start/Stop" button (upper right) to move from seconds > minutes > hour > date > day of week. Use the "Spl/Reset" button (lower right) to change the numbers
    Nov 04, 2012 | Watches
    Howdo I set time on a puma watch pu910222003 blockbuster circuit touch screen
    Setting the time on the PU910222003 Puma ladies watch.
    The process is actually less complicated than you would think.
    First, a couple things you need to know and remember.
    1. The watch has a safety feature which requires you to press the touch button on the right side of the watch before you can do anything as far as touching and changing anything. If it did not, every time you accidentally touched the dial something would change.
    2. Touch means you are touching the dial and the (stones or outer edge)
    To change the time, day, date etc, on your PU910222003 you must first press the touch button on the side. The word touch will light up (display) inside the watch on the right side of the dial.
    Now you are ready to change stuff.
    Touch the dial and the little what looks like bling at the bottom of the watch. You need to be touching the watch dial and these stones at the same time to do anything we are about to do.
    While touching and holding the bottom of the dial you may see the back light turn on.
    That is actually how you do that.
    By continuing to touch and hold the bottom of the dial, you will then see the word hold at the top and then the hour of the time flash.
    To increment the time or decrement the time, touch the right side of the dial or the left side of the dial. When you have arrived at the current hour, touch the hour at the top again and the minutes will begin to flash.
    Continue to set all settings in this manner until you are satisfied. Touching the top to move to the next setting and right or left of dial to go up or down.
    When you are done. Touch the bottom of the dial to exit this setting mode.
    Day to day use,
    Touch the time at the top of the dial to scroll through the time, chrono, alarm etc. To see time if the screen saver is on, touch the left side of the dial. Touching this repeatedly will also scroll through all the phrases programmed into the watch.
    While touching and holding the bottom of the dial you will see the back light turn on.
    Cool feature,
    This watch actually has two displayable times you can use if you travel often to a second time zone. Press the touch button on the side and touch the right side of the dial. Touching it for a second or two will display the time of the second time zone. Touching and holding for a couple more seconds will cause the T2 on the display of the left side of the watch to flash and eventually switch to the second time. I am thinking that touching the bottom of the watch while displaying the second time should allow you to set this time also.
    Feb 20, 2011 | Watches
    I have Puma-Time touch screen watch (PUMA men's Blockbuster Circuit Touch Screen Black Watch but unable to set the time.
    Dont have that particular watch, but see if this works.
    The process may be less complicated than you would think.
    To change the time, day, date etc, on your watch you must first press the touch button on the side. The word touch will light up (display) inside the watch on the right side of the dial.
    Day to day use,
    Cool feature,
    Feb 12, 2011 | Puma Active Collection Dynamic Posh Black...
    How to set time on a timex 1440 sports watch
    1. Press mode button (bottom button left side) until the time and day appears.
    2. With time and day showing press and hold set button (bottom right side).
    3. City codes will flash. Press start/stop to select city that represents your time zone.
    4. Press mode daylight saving time setting flashes. press start/stop to obey or disregard radio signal for atomic time.
    5. Press mode hour flashes. Press start/stop to change hour (include AM/PM)
    Repeat the above step for the remaining values ( minute, seconds, month, day etc)
    Press set an any step when finished.
    Oct 20, 2010 | Watches
    I have Puma-Time touch screen watch (PUMA Women's PU910222002 Blockbuster Circuit Touch Screen Crystal Accented Black Watch but unable to set the time.
    Dont have that particular watch, but try this.
    Day to day use,
    Cool feature,
    Sep 17, 2010 | Puma Active Collection Dynamic Posh Black...
    I bought the water resist watch from walmart this evening it doesnt have a name brand on the watch but i think its a casio but it didnt come with the instructions on how to use it, the number on the back...
  • Sep 14, 2010 | Watches
    I bought an old timex indiglo watch it has a button on the right middle and left bottom, how do i adjust the date?
  • Press the button on the lower right side of your Indiglo watch to unlock the mode function of the watch.
  • 2 Press the button on the lower left side to move through the modes. Each time you are in a mode, the digital display will flash. For example, when the time display begins to flash, you are in the correct mode to set the time.
  • 3 Change the time (or date) by pressing the button on the upper right side to advance the numbers or the button on the left side to move the numbers down. When you do this, you will be changing the first set of numbers (the hour or month, for instance); to change the minutes, press the button on the right side of the face until the second set of numbers is flashing and begin the process again.
  • 4 Press the button on the lower left side of the watch to save your settings. The button on the upper left side of the watch is not used in this process--it is the switch to turn on your Indiglo light.
  • Best regards. Jewel
    Sep 08, 2010 | Timex Watches
    We don't know how to set the 1440 sports watch
    Hi katbil1,
    To set the digital time and date on your Timex, please follow the steps below.
    Timex Digital Watch
    1. Press and hold the "Set" button for 2 seconds. The "Set" button is on the lower right side.
    2. Press the "Date Advance" button on the upper right side. This will reset the seconds.
    3. Press the "Change Mode" button on the lower left to set the hour. The hour will flash. Press the "Date Advance" button until the correct hour is displayed.
    4. Press the "Change Mode" button again to set the correct 10s unit (first digit 1 or 0) for the minutes. Press the "Date Advance" button until the correct first digit of the minutes is displayed. Repeat this step to set the second digit of the minutes.
    5. Repeat Steps 1 through 4 of this section to set the year, month, date and day and whether to use 12- or 24-hour time for your watch.
    6. When finished, press the "Set" button (on the lower right) to return to the current time view and lock in your settings.
    Hope it helps.
    Thank you for using FixYa.
    Oct 24, 2009 | Timex 1440 Nylon watch
    Oct 16, 2008 | Freestyle Digital 79801 Watch
    Watches Logo
    15 people viewed this question
    Top The Watches Experts
    D. E. Hev
    John mullen
    vince
    Are you a The Watch Expert? Answer questions, earn points and help others
