Question about Cell Phones
How do i pair my phone to my 2005 s type have no idea how to begin
Bluetooth in Mercedes CLK 500 Dropping
Do you need to have an app that it has to be connected to?
Jul 31, 2014 | Motorola Mobility Droid RAZR HD
What is the passcode for the Scala LX700 bluetooth?
Four zeros is the PIN you want to use for pairing
  • 0000
That's also the default code for a majority of bluetooth headsets.
Here is the entire pairing process broken down:
1. Turn on your phone and make sure that its Bluetooth function is activated.
2. While the Headset is turned off, press the Wheel inwards for at least
8 seconds. The Status Light will begin rapidly alternating red and blue,
indicating that the Headset is in Pairing mode.
3. Using your phone, search for Bluetooth devices by following the
phone’s instructions.
4. After a few seconds the phone will list the scala-700LX as a “discovered
device”. Select it and follow your phone’s instructions to accept the pairing.
5. When prompted, enter 0000 (four zeros) as your PIN or passkey.
6. Your phone will confirm that Pairing was successful and the Headset’s
Status Light will begin flashing slowly in blue.
Apr 22, 2010 | Cardo scala 700LX Bluetooth Headset
I have a new phone nokia 6303 and tried pairing with my parrot ck3100 and it will not connect. It asked for a passord on the phone I typed in 1234 but it comes back with pairing rejected by other device?
you need to go to settings / paired devices / delete any old phones that are still stored as the parrot will only allow 5 paired devices. then try again. You may want to check your software and if your software is over 12 months old it will be a good idea to update your parrot, try parrot.com/support for more.
Dan
Mar 02, 2010 | Parrot SA Parrot Ck3100 Lcd Handsfree...
PAIRING CODE FOR MOBLIE PHONE
The 2004 X type is before the Bluetooth technology they didn"t start till late 2005, However you can have the wiring harness and module adapted to your 2004 radio for a low cost of about $1,600 dollars from the dealer.
Feb 22, 2010 | 2004 Jaguar X-Type
Need set-up Information for Blue Tooth phone in Chrysler Pacifia 2005
I found the link below containing a download of the .pdf file and also pasted the phone pairing portion below it. These instructions are exactly the same as when pairing to my system in my '08 Caliber,so they're probably universal. Keep in mind, though, that the system just may not be fully compatible with your phone. EVERYTHING that Chrysler makes is EXTREMELY finicky-and you may be doing everything right! Before you begin, set your phone into its pairing or "find me" mode, then press the UConnect button. I hope this helps! Good luck.
http://dcxtraining1.com/dcxtraining1/docs/ExperienceFreedom_UConnect.pdf
Linking to UConnect – Required for First-time Use of Each Mobile Phone
To complete the pairing process, the mobile-phone owner’s manual will need to be referenced. One of the following vehicle-specific Web sites will also provide detailed instructions for pairing with the phone: www.chrysler.com/uconnect, www.dodge.com/uconnect and www.jeep.com/uconnect.
• Press the Phone icon button to begin
• After the Ready prompt and subsequent beep, say Set Up Phone Pairing
• When prompted, after the voice or beep, say Pair a Phone
• You will be asked to say a four-digit PIN that will be needed later to enter into your mobile phone. You can use any four-digit PIN. You will not need to remember the PIN after the initial pairing process
• For identification purposes, you will be prompted to give the UConnect system a name for your mobile phone. Each mobile phone that is being paired should be given a unique phone name
• You then will be asked to give your mobile phone a priority level between one and seven, one being highest priority. The priority allows the UConnect system to know which mobile phone to use if multiple mobile phones are in the vehicle at the same time
Making a Phone Call
• After the Ready prompt, say Dial
• The system will prompt you to say the number you wish to dial
Making a Phone Call Using Your UConnect Phonebook
• After the Ready prompt, say Call followed by the name and designation of a phonebook entry you wish to dial – for example Call, then John Doe, then Work
Terminating a Phone Call
To end a call in progress, press the Phone icon button. All calls in progress will
be terminated.
Phone Redial
• After the Ready prompt, say Redial
• The UConnect system will call the last number that was dialed on your mobile phone. This may not be the last number dialed by the UConnect system
Answering or Rejecting an Incoming Call - No Call Currently in Progress
When you receive a call on your mobile phone, the UConnect system will interrupt the stereo audio to ask if you would like to answer the call. Press the Phone icon button to answer the call. To reject the call, press the Phone icon button until you hear a single beep indicating that the incoming call was rejected.
UCONNECT
CHRYSLER GROUP TECHNOLOGY 17
Dec 29, 2009 | 2005 Chrysler Pacifica
Can't switch bluetooth to my phone!
you need to reset your bluetooth to factory setting.
to reset, press and hold the call button while turning it on.. you'll see the light will flash and ready to pair.
Mar 28, 2017 | Samsung Cell Phones
2005 Jaguar S-Type pairing
Here you go:
http://www.jaguar.co.uk/uk/en/owners/owner_information/bluetooth.htm
Mar 20, 2009 | 2007 Jaguar S-Type 3.0 Sedan
My blackberry bold does not recieve data via bluetooth
I think you read wrong praky, capt said already paired. The correct solution would be as follows:
1. Open the Media app.
2. Select a media type (e.g. Music)
3. Press Menu.
4. Select Receive Using Bluetooth.
5. Select Yes. (It will then ask you the location you want to save to but of course by default it will select the proper folder)
6. Select Save. (Transfer will begin
Feb 09, 2009 | RIM BlackBerry Bold Smartphone
Pairing phone with 2005 s type noika phone
I had te same kind of problems with my car. take it to the dealership. my antennae was broke! once that wa fixed........my car works with every phone I have had.
Oct 27, 2008 | 2007 Jaguar S-Type 3.0 Sedan
Pairing b.t. devise
u mean while pairing bluetooth device? well, u can type any number as 1234 or 0000, the idea is, u have to type 4digit number that you and receiver know only, so that nobody can hack your connection in the middle of sending data. after you put the four digit number, the receiver must type the same to receive the data you send. that's all..take care
Sep 21, 2008 | Nokia 6126 Cellular Phone
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
