Question about Vacuums
Finding rugs area rugs - Vacuums
Remove rug tool
I can't say how to do it on your model because you did not say what vacuum you have. On most vacuums the hose is held onto the rug tool by friction and can be pulled out with a twist. Dirt and rust can cause them to stick.
Feb 03, 2017 | Vacuums
WILL i HARM the hardwood floor under my Area rug to be shampooed. No pad underneath
Simple answer: YES
Anytime you are sampooing anything the under surface will be exposed to the cleaner. Move throw rugs to a location safe for the cleaner. Kitchen floors are usually good for this or a concrete floor. Remember to let carpet dry completely before replacing it. It will be lighter when dry so easier to move. But as a glass on a wood side table leaving a ring a wet carpet can leave a shaped stain.
Jan 22, 2016 | Bissell 9500 ProHeat 2X CleanShot Upright...
Why am I unable to push vacuum forward on new area rug. But will work pulling backward. Works fine on old rugs and floor
It might be that the new rug has a backing that is not as stiff a the other rugs which can cause a rug to bunch up making it hard to push the vacuum forward.
Feb 23, 2015 | Dyson DC25 Animal Upright Ball Bagless...
Cannot push vacuum forward on new area rug. But will work pulling backward. Still works on old area rugs and floors.
Hi there, it's Jack at Dyson.
I'm sorry to hear you're having difficulty using your DC25 on this particular new area rug. As you've confirmed the vacuum works as normal on other rugs and hard floors, it doesn't sound like there's a fault with the vacuum itself.
As lightweight area rugs are not fixed to the floor, it's possible for the rug to lift and seal against the soleplate of the cleaner head, due to your DC25's powerful suction. As this will reduce the amount of airflow entering the cleaner head, you may need to use more push force than usual when vacuuming this type of flooring.
We would encourage you to check directly with the rug manufacturer, as they'll be best placed to provide information on correctly caring for this particular floor type.
If you'd like to discuss the issue you're experiencing with our experts, you're welcome to call us directly on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Find water pump rug doctor
is it your own machine or a hire machine?
Your best bet would be your nearest rug doctor distributor or try ebay.
Tony from DirtMaster
Feb 25, 2013 | Rug Doctor 95730 MP-C2D Mighty Pro Carpet...
I ran over a big floor rug with my vacuum and some of the strings from the rug got tangled in the roller on the vacuum. It makes a terribly loud noise even now after I have cleared the strings from the...
You will need to pull the roller out and clean it. I think some of the strings are tangle up at the end of this roller. (Most rollers will come apart at the end for cleaning.) Make sure that the strings are not tangle up on the belt pulley as well. I hope this will help you.
Jan 25, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
Can I shampoo a couch?
Yes<br /> <h2 class="Heading1a Underline header"><span>Instructions</span></h2> <!-- google_ad_section_start() --> <div class="thingsYouNeed"> <h2 class="Heading5a">Things You'll Need:</h2> <ul> <li> <span>Vacuum and its hose attachments</span> </li> <li> <span>Shampoo specific to the couch's fabric</span> </li> <li> <span>Rug shampooer</span> </li> <li> <span>Steam cleaner, possibly</span> </li> <li> <span>Rag and cotton swabs</span> </li></ul> </div> <ol id="intelliTxt"> <h4 class="Heading4a">Preparing the Sofa</h4> <li id="jsArticleStep1"> Vacuum the sofa, its pillows and its cushions with the hose attachments. Do not forget the arm rests and backing of the couch. This will clean loose dust and dirt.<br /> </li> <li id="jsArticleStep2"> Dust the wood areas with a soft rag and a cotton swab for the area between the material and wood.<br /> </li> <li id="jsArticleStep3"> Find your warranty. If it is still in effect, the warranty may be null and void if you apply any cleaning solutions. Call the company for cleaning instructions.<br /> </li> <li id="jsArticleStep4"> Determine the sofa's fabric. This tag is typically found under the cushion area.<br /> </li> <li id="jsArticleStep5"> Buy shampoo specifically for your sofa's fabric.<br /> </li> <li id="jsArticleStep6"> Rent a rug shampooer.<br /> </li> <h4 class="Heading4a">Cleaning</h4> <li id="jsArticleStep1"> Assemble the shampooer according to its directions.<br /> </li> <li id="jsArticleStep2"> Test a small area of the sofa. The best place may be the back of the couch or under the couch if possible.<br /> </li> <li id="jsArticleStep3"> Clean the entire couch. This will prevent watermarks.<br /> </li> <li id="jsArticleStep4"> Allow it and all its parts to dry before reassembling the cushions and pillows.<br /> </li></ol> <div style="overflow: hidden; color: rgb(0, 0, 0); background-color: transparent; text-align: left; text-decoration: none; border: medium none;"><br /></div><br /> <!-- from fixya rte -->
Jun 12, 2010 | Kirby G6 Bagged Upright Vacuum
Noisy on rugs!
Are the rugs long haired or short haired? Most likely the suction is just causing the noise when it picks up the rug and the buzz saw could be the beater bar hitting the rug then. I actually own a DC14 and it does the same thing and the rugs like to be dragged along. Nothing really to fix this, just the way it is. You could try it with the beater bar raised and see how well it works then but this sounds normal.
Have a good day
bestdarngood
Feb 10, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Loud noise
This is the clutch as it jams up in the brush. Usually happens with rugs that are not secured to the floor.
Dec 11, 2008 | Dyson DC14 Animal Bagless Upright Cyclonic...
Vacuums Logo
24 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
